06-26-2010, 13:05 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: chennai Age: 38
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | model :i9++i after flash not power on COM4 [VCP0] selected module v3.15 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: "repair imei" imei write channel: imei #1 (default imei inside firmware) new imei: 363297009060388 ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:1703:000D status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #02 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #03 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 230400 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished ==================== New firmware detected (v.3.15, database date: 14.06.2010): M5120_HRD_UI2_EN+FR+SP+PR+GE+GR+TU_128+32FLASH_A03 .BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info ver: 04 sw version: M5120_HRD_UI2_EN+FR+SP+PR+GE+GR+TU_128+32FLASH_A03 .BIN project-id: M5120_HRD_UI2_EN+FR+SP+PR+GE+GR+TU_128+32FLASH_A03 , 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: EC240200000000:18E59F00000000 checking area [00000000]: 00080000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: EC240200000000:18E59F00000000 Backup required data Done ====> Patch required data ... detecting ffs/eeprom structure pass 2... .................................................. ...... ffs/eeprom: can't detect record name location error: ffs/eeprom detection failed element #2 error: can not detect default imei value Patch required data Fail Finished, time used: 2 min 15 sec Remove/Install battery now ! pls help me |
06-27-2010, 21:04 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! flash with this flash file: flashfiles/ChineseMiracle/_MT6205-MT6227/M5120_HRD_APPLE_UI1_KEY4_EN+FR+SP+P0+IT+GR+TU_V25_ _i9+++_16m_En_Fr_Es_It_De_Tr_Pt.B0M.bin |
06-28-2010, 04:10 | #3 (permalink) | |
No Life Poster Join Date: Jun 2005 Location: Punjab , INDIA
Member: 153805 Status: Offline Thanks Meter: 325 | Quote:
can anyone have working i9++i and read full flash and send to Infinity support. | |
06-28-2010, 05:58 | #4 (permalink) | |
Banned Join Date: May 2004 Location: Mauritius
Member: 64823 Status: Offline Thanks Meter: 439 | Quote:
06-28-2010, 07:54 | #5 (permalink) | |
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | Quote:
module v3.15 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware M5120_HRD_APPLE_UI1_KEY4_EN+FR+SP+P0+IT+GR+TU_V25_ _i9+++_16m_En_Fr_Es_It_De_Tr_Pt.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:1703:000D status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #02 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #03 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 230400 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished ==================== New firmware detected (v.3.15, database date: 14.06.2010): M5120_HRD_UI2_EN+FR+SP+PR+GE+GR+TU_128+32FLASH_A03 .BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info ver: 04 sw version: M5120_HRD_UI2_EN+FR+SP+PR+GE+GR+TU_128+32FLASH_A03 .BIN project-id: M5120_HRD_UI2_EN+FR+SP+PR+GE+GR+TU_128+32FLASH_A03 , 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: EC240200000000:18E59F00000000 checking area [00000000]: 00080000-00FFFFFF... ffs/eeprom found near: 00480000 Detected ffs/eeprom address is non-standard: 00480000 Posible reasons: 1. ffs/eeprom is Ok but address is non-standard 2. ffs/eeprom is damaged and can't be detected 3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make full flash backup for emergency case 3. repeat required operation Are you sure that detected ffs/eeprom address is correct ? autodetected ffs/eeprom address confirmed by user: 00480000 detecting ffs/eeprom size... ffs/eeprom size: 00B80000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00480000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: M5120_HRD_UI2_EN+FR+SP+PR+GE+GR+TU_128+32FLASH_A03 __ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\M5120_HRD_UI2_EN+ FR+SP+PR+GE+GR+TU_128+32FLASH_A03__ffs_20100628-120437.B0E.bin flash: EC240200000000:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Code CRC check error fix... firmware do not have "Code CRC check error" area Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... startup code area #1 fixed detecting startup code area #2... startup code area #2 is absent Area: Firmware flash: EC240200000000:18E59F00000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 28 min 15 sec Remove/Install battery now ! yes it is working so i like infinity i have no words to express my thanks to infinity once again thanks a lot | |
06-28-2010, 14:49 | #6 (permalink) | |
Code: COM6 [VCP0] selected module v3.15 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection disabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:B703:0003 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:FFFFFF00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: EC240200000000:FFFFFF00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #02 in region #00... flash: EC240200000000:FFFFFF00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #03 in region #00... flash: EC240200000000:FFFFFF00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC240200000000:FFFFFF00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 Warning: probably flash chip is empty, erased, incorrectly flashed or damaged ! | |
06-28-2010, 21:56 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! In current situation best move is following: disassemble phone and crefully check PCB. there MUST be short software code printed on board. post it here, i will advice flash file. here is example how this method works for people: help me please mobile chine - GSM-Forum |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
