Modules are not starting Hi, i had the infinity box and software running fine before, then i got troubles with a anti virus update and installed everything new. SOftware drivers... Now, when I install an old version of the Main installation Package (aprilī07) the modules like the Moto1 are starting. But are not supporting phones like W375. When I install the new package and want to start Moto1 the prozess is starting and running at 50% CPU usage in background and doing nothing. Did anyone have a solution. :confused: thx |
did u uninstall new modules and then install new package ? |
hello! try fo uninstall it via "add/remove programs" delete folder infinitybox and then instal latest Main installation Package from our support site |
i did like almost everything, deleted it, deleted it with uninstall, deleted driver and everything else...same problem. Old version is working perfect, the new one wonīt start |
could u send a screenshot ? |
Hello, Did you tried to run other modules, not only Moto01? What is the results ? What OS installed on your PC ? Install latest "Installation package" and download and install lates separate updates. |
I have the same problem with new Installation ,v2.10a,with the old everythink is ok... |
What OS installed on your PC ? |
Dear Sir. I have a strange problem with infinity.I have one PC at my work place and it is P-3 850MHz Via CLE266 motherboard and 512MB ram.Infinity works OK.Another PC at my home I use to download updates at night as it is cheaper at night.P-4 core2 Duo with 512MB ram. some modules are not running screen shots are attached.I use WIN XP SP2 on both PCs. |
I think one Module was working, but i donīt know which one. Yesterday I deleted everythink from infinity box, I even searched the registry and deleted every record with infinity box. Now when Im installing the egate drivers and then plug in the Box he gives me an errormessege "code thre in systems.exe" and windows XP is shutting down with a counter "1 min". So now I canīt even install the box. I had this problem before, I am running Smart Clip on this computer to and this box uses the egate driver, maybe its a conflict between those two programms? but before it was running fine. |
The same e-gate drivers used for Infinity-Box and other e-gate smart-card based protection systems. If you have installed one box with smart-card protection lready you don't need to install e-gate drivers again. |
Why don't u format your pc and then download the latest packages once again as sometimes while downloading some files are missed out; and then install the new packages. |
Formating PC is no solution, it would take hours to get everything running and I need my Programms. So anyone has a solution for this problem? because now I even cant install the boxdrivers |
i have same problem, but this problem when i install to same pc which JAF installed before. i try with moto01, modules not run. tommorow i will try another module. @infinity support. if i unistall "usb serial port", the module immediatly running. if i try another module, and still not run, what should i do. thanx. sorry for my bad english. |
