Old 10-05-2007, 16:58   #1 (permalink)
Member: 9738
Modules are not starting
Hi, i had the infinity box and software running fine before, then i got troubles with a anti virus update and installed everything new. SOftware drivers...
Now, when I install an old version of the Main installation Package (aprilī07) the modules like the Moto1 are starting. But are not supporting phones like W375. When I install the new package and want to start Moto1 the prozess is starting and running at 50% CPU usage in background and doing nothing. Did anyone have a solution.
thx
Old 10-05-2007, 18:08   #2 (permalink)
Member: 128745
Thanks Meter: 16,875
did u uninstall new modules and then install new package ?
Old 10-05-2007, 18:09   #3 (permalink)
Member: 148515
Thanks Meter: 16,156
hello!
try fo uninstall it via "add/remove programs"
delete folder infinitybox
and then instal latest Main installation Package from our support site
Old 10-06-2007, 15:04   #4 (permalink)
Member: 9738
i did like almost everything, deleted it, deleted it with uninstall, deleted driver and everything else...same problem. Old version is working perfect, the new one wonīt start
Old 10-06-2007, 17:18   #5 (permalink)
Member: 128745
could u send a screenshot ?
Old 10-06-2007, 19:50   #6 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,407
Hello,
Did you tried to run other modules, not only Moto01? What is the results ?
What OS installed on your PC ?
Install latest "Installation package" and download and install lates separate updates.
Old 10-06-2007, 21:02   #7 (permalink)
Member: 137489
Thanks Meter: 68
I have the same problem with new Installation ,v2.10a,with the old everythink is ok...
Old 10-07-2007, 00:57   #8 (permalink)
Member: 130995
Old 10-07-2007, 01:52   #9 (permalink)
baldev's Avatar
Member: 153805
Thanks Meter: 324
Dear Sir.
I have a strange problem with infinity.I have one PC at my work place
and it is P-3 850MHz Via CLE266 motherboard and 512MB ram.Infinity works OK.Another PC at my home I use to download updates at night as it is cheaper at night.P-4 core2 Duo with 512MB ram. some modules are not running screen shots are attached.I use WIN XP SP2 on both PCs.
Old 10-08-2007, 10:03   #10 (permalink)
Member: 9738
I think one Module was working, but i donīt know which one. Yesterday I deleted everythink from infinity box, I even searched the registry and deleted every record with infinity box. Now when Im installing the egate drivers and then plug in the Box he gives me an errormessege "code thre in systems.exe" and windows XP is shutting down with a counter "1 min". So now I canīt even install the box. I had this problem before, I am running Smart Clip on this computer to and this box uses the egate driver, maybe its a conflict between those two programms? but before it was running fine.
Old 10-08-2007, 11:44   #11 (permalink)
Member: 130995
The same e-gate drivers used for Infinity-Box and other e-gate smart-card based protection systems.
If you have installed one box with smart-card protection lready you don't need to install e-gate drivers again.
Old 10-08-2007, 11:46   #12 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,040
Hi,
Why don't u format your pc and then download the latest packages once again as sometimes while downloading some files are missed out; and then install the new packages.
Old 10-08-2007, 14:22   #13 (permalink)
Member: 9738
Formating PC is no solution, it would take hours to get everything running and I need my Programms.
So anyone has a solution for this problem?
because now I even cant install the boxdrivers
Old 05-26-2008, 12:56   #14 (permalink)
Member: 137049
Thanks Meter: 7
i have same problem, but this problem when i install to same pc which JAF installed before.
i try with moto01, modules not run. tommorow i will try another module.
@infinity support.
if i unistall "usb serial port", the module immediatly running.
if i try another module, and still not run, what should i do.
thanx. sorry for my bad english.
Old 05-26-2008, 13:32   #15 (permalink)
Member: 130995
@infinity support.
Please, double check that drivers installed correctly, follow installation procedure exactly like you see in Infinity-Box Installation manual (explanation with pictures).
nokia e 71 more are killed with ub box to not start? us and give someone new a soluti ciopa Universalbox 14 04-16-2009 16:30
FG box module error when starting from program group. benchnix FuriousGold 4 10-25-2007 07:50
Why new environments are not started... dikey Dongle Problems (USB-Smart) 3 06-22-2006 09:27
PHOENIX are not started Fahri Phoenix Black Box 0 11-25-2005 17:35
Page generated in 0.40720 seconds with 8 queries
