04-07-2008, 16:48 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Pleasae, never try to connect USB cables to Infinity-Box because if you will try to connect USB cables to RJ45 box connector you may have box damaged ! You can try to connect usb cables somwhere else (f.e. into your PC or PC of your friends). |
04-07-2008, 16:52 | #3 (permalink) | |
No Life Poster Join Date: Aug 2005 Age: 71
Member: 174094 Status: Offline Thanks Meter: 74 | Quote:
thank you for the advice | |
04-07-2008, 23:13 | #7 (permalink) |
No Life Poster Join Date: Sep 2005 Location: algeria BBA BELIMOUR Age: 46
Member: 184351 Status: Offline Thanks Meter: 263 | look the usb cable is plugged in the usb port of your pc and the infinity box in this case is used to authorize the software to work with this phone (smart card authorization ) |
04-10-2008, 06:35 | #8 (permalink) |
No Life Poster Join Date: Sep 2007 Location: In front of my pc
Member: 586318 Status: Offline Thanks Meter: 112 | as far as i understand the question is the following: Can the usb be cable change into rj45 system in order to be able to use them with infinity box. I think you can do it, the only thing you have to keep in mind is tx, rx, v+, gnd. there's a picture in the main infinity software which give you the 1 to 8 pin rj45 connections |
NEC n930 usb cable and charger needed | przemekj | NEC | 0 | 03-29-2010 15:21 |
Cables to Go Multi-Color - USB cable - 4 pin USB Type A (M) - 4 pin USB Type B (M) - | IPMART | ipmart WebShop | 0 | 07-01-2009 06:40 |
New Flasher in town - N BOX USB Flasher + 38 Cables + USB Cable + FREE shipping | I-phone Team | Main Sales Section | 0 | 08-24-2004 01:54 |
WANTED: Sonyericsson connector with wire, USB cables or sonyericsson <-> USB cables | Mizar | Wanted Products | 1 | 06-25-2004 11:53 |
