Old 10-06-2009, 21:48   #1 (permalink)
toutou_gsm's Avatar
Member: 628112
Sonork: 100.1589052
Thanks Meter: 3,726
:: more informations how to enter code in blackberry phones::
informations on how to enter codes in bb phones:
Model : BlackBerry 8700
Go to the Menu -> Options -> Advanced Options -> Sim card press select, while holding the Shift key (bottom right corner CAPS), type mepd. You should now see the five locking categories listed, while holding the alt key, type mep2. Release the alt key. You are now prompted to enter the Network MEP code. Enter the code, enter Return/Enter, the device should then be unlocked.
Model : BlackBerry 8800
You must have a SIM card in your phone to complete these steps ( Can be active or inactive )
1 - Go to settings menu => and then Options
2 - Select Advanced options => and then Sim card
3 - Type MEPD using your Blackberry keyboard (NOTE: You will not see any text appear on the screen while typing MEPD)
4 - Hold the ALT Key while typing in MEPE on your Blackberry keyboard (NOTE: You will not see any text appear on the screen while typing MEPD)
5 - You should be presented with a prompt "Enter Network MEP Code". Type in the 16 digit unlock code received from UnlockBase.com and press in the track wheel / jog dial to confirm
6 - Your phone is now unlocked
Model : BlackBerry 8220
1. Insert any sim card
2. Turn off all of the wireless connections
3. Go to Options
4. Select Advanced Options
5. Select SIM Card
6. Hit menu select show keyboard (where needed)
7. Type MEPPD or MEPD (you will not be able to see the typed info)
8. Enter MEP2 or MEPP2
9. Now it will say enter network mep code
Model : BlackBerry 8100 Pearl
1 - Go to Options Menu => Advanced Options
2 - In the SIM Card menu, hold down the shift (right of the zero, cap) press meppd
3 - You'll see the unlocking level screen there you hold the ALT key (left side below @) type mepp2
4 - Enter the unlock code.
Model : BlackBerry 8100 (Vodafone Australia)
PLEASE READ THE INSTRUCTIONS CAREFULLY BEFORE YOU ATTEMPT ANY UNLOCK PROCESS
This procedure unlocks the handset from being network restricted from only using SIM cards from Vodafone Australia. In case of difficulties, please refer to the FAQ listed below
1. Take note of the unlocking code shown above
2. Insert a Non-Vodafone Australia working SIM card.
3. Ensure the phone is charged and then switch the phone on.
4. Optional Step: If the SIM card has a PIN, enter your PIN number. (See FAQ below)
5. The phone will then display a message. The most common is ?nvalid SIM card? (Different message? See FAQ below)
6. Select ?urn Wireless Off?
7. Select ?ettings?Menu , then go to Advanced Options > SIM Card
8. Type alt-MEPT by holding the ALT-key and typing the letters MEPT with multitap i.e. type hold ALT, type {M}{ER}{OP}{OP}{TY}
9. When prompted with ?nter Network MEP code (255 left)?on the screen, enter the 16-digit network unlock code provided for your phone, then press Enter. (Unlocking code is shown above)
10. Reset the phone by pulling the battery
11. Switch the phone on and the handset will be unlocked automatically. This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider)
Model : All BlackBerry
1 - Using the menu go to Settings Menu -> SIM card pressselect.
2 - While holding the SHIFT key, type mepd
3 - You should now see the five locking categories listed.
4 - While holding the SHIFT KEY, type mep2.
5 - Release the shift key.
6 - You are now prompted to enter the Network MEP code (it will also state how many attempts left)
7 - Enter the code
8 - Enter Return/Enter
9 - The device should then be unlocked
Model : 9500/9530 Series
Ensure the SIM Card that came pre-installed in the 9530 is inserted.
Go to 'Manage Connections'
Click on 'Turn All Connections Off'
Go to 'Options'
Click on 'Status'
Go back to 'Options'
Click on 'Advanced Options'
Click on 'SIM Card'
Type 'MEPD' (letters will not appear on-screen but a menu will pop up)
Type 'MEP2' (user will be prompted to enter MEP code)
Reboot device
Click on 'Restore Connections'
Device is now unlocked
Please note when entering MEPD, ETC. You need to use caps.
How do I determine if my BlackBerry is "unlocked" ?
To determine if your BlackBerry is "unlocked" for use on carriers other than for which it is branded:
A. On your BlackBerry, go to Options > Advanced Options > Sim Card.
B. At that screen type MEPD (see note below) on your keyboard. A new menu will pop up.
If your BlackBerry has a SureType keyboard (71xx and 81xx devices) you will need to double-tap the P, so the actual keys entered become M E P P D.
C. Look for Network in the list.
D. If your device is "unlocked", it should say Disabled or Inactive. If it says Active, it's still locked to that carrier
regards,
The Following 2 Users Say Thank You to toutou_gsm For This Useful Post:
How To Enter Code In BlackBerry All Video Here MOBIL CLINIC Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 3 01-30-2010 16:41
How To Enter Code In BlackBerry All Video Here MOBIL CLINIC FuriousGold 0 01-28-2010 13:10
how to enter code in blackberry 8100 v4.2.0.42 derk BlackBerry (RIM) 1 09-30-2007 19:13
Page generated in 0.14849 seconds with 9 queries
