Old 11-28-2008, 16:03   #1 (permalink)
Blacki's Avatar
Member: 58536
Thanks Meter: 65
Question mot w208 after flashing is dead...
infinity team!
after flashing my motorola w208 is dead..
i flashed it with followig files:
W208_0.0.58_Main_K1.34M.bin
W208_0.0.58_LP_T08_Cz_Mg_Pl_Slovensko.34P.bin
W208_Flex_DF_00T_DEF_retail.34F.bin
and when i will it flashing, always "write error at..."
what is the problem??
please help me infinity team!
thnx!
b.
Old 11-28-2008, 16:30   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
What was with phone before flash ?
Did you checked battery voltage ?
Old 12-01-2008, 12:01   #3 (permalink)
Blacki's Avatar
Member: 58536
Thanks Meter: 65
i will only to hungarian flashing the phone..
the battery voltage is ok!
thnx for reply!
b.
Old 12-01-2008, 13:59   #4 (permalink)
Member: 130995
Hello,
Flash phone with this firmware: W208_0.0.58_Main_K2.34M.bin
Old 12-02-2008, 14:35   #5 (permalink)
Blacki's Avatar
Member: 58536
Thanks Meter: 65
Originally Posted by InfinitySupport View Post
Hello,
always write error...
pls hlp!!
thnx!
b.
Old 12-02-2008, 14:44   #6 (permalink)
Member: 130995
Hello,
Use HModule.exe for flashing.
The Following 2 Users Say Thank You to InfinitySupport For This Useful Post:
Old 01-15-2009, 19:23   #7 (permalink)
abcrino50's Avatar
Member: 68882
Sonork: 1577247
Thanks Meter: 111
phone alive again with hmodule
COM8 [VCP0] selected
Device: Locosto 8m
"advanced chip detection" active
Action: flash write
"smart write" active
Write: Firmware
Skip: Flex
Skip: Language Pack
Skip: FFS/File system
Skip: Images
Skip: Melody
Skip: Eeprom
Checking data, wait...
Boot...
Press Power button now !
rom version: 0502
Connecting...
booting...
finalizing...
Boot done
Check connection...
Check connection done
Set baud...
115200
Set baud done
Check hardware...
flash: 89887400010001:89887400000000
flash: Intel Intel std [def 007Fx010000 0008x002000] 8Mb
Check hardware done
Read data...
Read data done
Check data...
Check data done
Writing...
Area: Firmware
Write: Firmware
Writing done
Finished, time used: 770 sec
Remove/Install battery now !
The Following User Says Thank You to abcrino50 For This Useful Post:
Old 01-15-2009, 19:52   #8 (permalink)
Member: 384775
Sonork: 100.1605469
Thanks Meter: 159
module v1.29
Device: Locosto 8m
Action: flash write
Write: Firmware
Skip: Flex
Skip: Language Pack
Skip: Images
Skip: Melody
Skip: Eeprom
Boot...
rom version: 0502
Connecting...
booting...
finalizing...
Boot fail
error: operation failed
Finished, time used: 11 sec
please help me
Old 01-15-2009, 21:47   #9 (permalink)
abcrino50's Avatar
Member: 68882
Sonork: 1577247
Thanks Meter: 111
it was made this with me let phone without battry for some times or 1 day will work
or use another pinout
Old 01-15-2009, 22:48   #10 (permalink)
Member: 130995
@cemale*****
What is your phone history ?
Old 01-16-2009, 12:08   #11 (permalink)
notgood's Avatar
Member: 355635
Thanks Meter: 53
@cemale*****
i have problem flash mot w208 to i try moto01.exe
phone come to me with white screen n show ffs_formating....
flash get complete but still not solve the white screen n still show ffs_formating
this is the log
Loading data, wait...
Device: W208
Press and Hold Power button...
rom version: 0502
Connecting...
booting...
finalizing...
working, one more step...
flash: 0089:8874 Intel T 8Mb
reading eeprom...
done
file saved: C:\Program Files\InfinityBox\Moto01\backup_W208_eeprom_200901 16-171231.34E.bin
reading ffs...
done
file saved: C:\Program Files\InfinityBox\Moto01\backup_W208_ffs_20090116-171259.34E.bin
Finished, time used: 42 sec
Loading file v.02...
W208_0.0.56_Main_K2_1165853420_2006-Dec-12.34M.bin loaded
W208_0.0.56_LP_H02_Indonesia_En_Th_Vn.34P.bin loaded
W208_Flex_AC_007_102_retail.34F.bin loaded
Action: flash
Write: Firmware
Write: Language Pack
Write: Flex
Skip: Eeprom
Device: W208
loader: default version
Connect...
Press and HOLD Power button...
rom version: 0502
Connecting...
initial boot phase complete
Release Power button !
Connect Done
Boot...
Boot Done
Set Baud...
115200
Set Baud Done
Check Flash-1...
Check Flash-1 Done
Check Flash-2...
Check Flash-2 Done
Write...
Writing: Firmware
Writing: Language Pack
Writing: Flex
Write Done
Finished, time used: 661 sec
btw ... i will try flash with hmodule.exe n will post result
regards
notgood
Old 01-16-2009, 13:02   #12 (permalink)
notgood's Avatar
Member: 355635
Thanks Meter: 53
flash with hmodule.exe, n already try flash with all firmware ini support still can't solve the problem, the phone still white screen n show ffs formating... then restart n white screen n show ffs formating...again...
this is the log
Device: Locosto 8m
module v1.30
Device: Locosto 8m
Action: flash write
Write: Firmware
Skip: Flex
Skip: Language Pack
Skip: Images
Skip: Melody
Skip: Eeprom
Boot ...
rom version: 0502
Connecting...
booting...
finalizing...
Boot done
Check connection ...
Set baud ...
115200
Set baud done
Check hardware ...
Check hardware done
Read data ...
Read data done
Check data ...
Check data done
Write ...
Area: Firmware
Write: Firmware
Write done
Finished, time used: 20 sec
W208_0.0.58_Main_K2.34M.bin loaded
module v1.30
Device: Locosto 8m
Action: flash write
Write: Firmware
Skip: Flex
Skip: Language Pack
Skip: Images
Skip: Melody
Skip: Eeprom
Boot ...
rom version: 0502
Connecting...
booting...
finalizing...
Boot done
Set baud ...
115200
Set baud done
Check hardware ...
Check hardware done
Read data ...
Read data done
Check data ...
Check data done
Write ...
Area: Firmware
Write: Firmware
Write done
Finished, time used: 366 sec
soo... how to solve my problem
thx in advance
regards
notgood
Old 01-16-2009, 16:56   #13 (permalink)
Member: 130995
Hello,
If phone has "formatting" message at LCD, reboot and show "formatting" again it may be a result of damaged or bad soldered flash chip.
Try to flash phone with W208_repair_image_K2_0.4.63.80M.bin then make sp-unlock.
Power on phone and wait several minutes.
If problem still exist you need to open phone and check it's hardware.
Old 01-16-2009, 18:50   #14 (permalink)
Member: 384775
Sonork: 100.1605469
Thanks Meter: 159
phone write allways "phone is hacked" and restart how to solved this problem. ı unlock after phone is hackerd.
sir my log.
COM8 [VCP1] selected
module v1.30
Device: Locosto 8m
Action: flash write
Write: Firmware
Skip: Flex
Skip: Language Pack
Skip: Images
Skip: Melody
Skip: Eeprom
Boot ...
rom version: 0502
Connecting...
booting...
finalizing...
Boot fail
Finished, time used: 12 sec
Old 01-16-2009, 20:38   #15 (permalink)
Member: 130995
@cemale*****
As I can see from your log your phone can not be connected.
What you have tried to do exactly ?
p730 after flash is dead imanpanahi Samsung Hardware Repair 2 08-30-2006 11:00
6270 after flash is dead oki papa Nokia Base Band 5 ( BB-5 ) 2 07-08-2006 12:52
8310 after flash is dead nadeem786 Nokia Digital Core Technology 4 ( DCT-4 ) 4 08-27-2003 17:49
help me my s 40 after flash is dead lelik NON Siemens Brand (ODM Phones) 2 04-24-2003 19:04
Mitsubishi MT-345@i after flashing is DEAD.... -=G3=- Mitsubishi 2 07-06-2002 13:40
Page generated in 0.24158 seconds with 10 queries
