09-19-2017, 09:21 | #1 (permalink) |
Freak Poster Join Date: Oct 2013
Member: 2043843 Status: Offline Thanks Meter: 39 | Moto M frp manager nor in AST tool. Also tried with Cm2Mtk tool. But failed with boot error . (Secure boot) |
09-20-2017, 12:17 | #2 (permalink) | |
Member: 2043843 Status: Offline Thanks Meter: 39 | No reply from supporter? ?? Quote:
09-20-2017, 12:41 | #3 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Quote:
enter phone to Fastboot mode,connect phone to pc,then Hit ENABLE ADB button.then do what you want | |
09-20-2017, 12:48 | #4 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Quote:
Where is logs,,, and post full model,,, as i knw Moto M is Mtk Cpu so use Mtk module,,if any error start with logs | |
09-20-2017, 13:27 | #5 (permalink) | |
Member: 2043843 Status: Offline Thanks Meter: 39 | logs file Quote:
Start at : [9/19/2017 / 2:20:15 PM] Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : BROM DRAM configured from IDB! Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM41C [eMMC] : FLASH_CID : 150100524331344D420705D7DA501489 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000E8F800000 [eMMC] : FLASH_UCP : 59640 MiB [eMMC 128 GiB] DEV RID : 0xE9D3EF6B32B119090284616C804F0093 INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : FULL-SPEED Boot Ok! Clear FRP ( Google Reset Protection ) Format/Reset Error! | |
09-20-2017, 13:30 | #6 (permalink) | |
Member: 2043843 Status: Offline Thanks Meter: 39 | No info show in fastboot mode Quote:
Infinity-Box Android Service Tool [AST] v1.01 Operation : Identify [ v1.01 ] Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Device not found! Check cable, drivers and conection! Operation : Identify [ v1.01 ] Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! Main Info ============ Model Info ============ SW Info ============ HW Info ============ Lock Info ============ Done! Elapsed: 00:00:05 Operation : Enable ADB (Moto) [ v1.01 ] Waiting for NetInterface arrival ... 1. Power off device. Press and hold 'VOL DOWN' and 'POWER ON' buttons 2. Select by 'VOL DOWN' or 'VOL UP' FACTORY MODE , press 'POWER ON' 3. Connect USB cable, when device boot complete! Device not found! Check cable, drivers and conection! Card found : 9185DB79 , v0136 Infinity-Box Android Service Tool [AST] v1.01 | |
09-20-2017, 13:32 | #7 (permalink) | |
Member: 2043843 Status: Offline Thanks Meter: 39 | Any spacial boot key? Quote:
And also tried with volume + adn down key etc but didnt help me | |
09-21-2017, 23:26 | #9 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | .... and exact model of phone is ? XTxxxx b.r. ALex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
