Moto V171 New Hardware: E68 INFOR V171 New Hardware: MODEL:V171 HW: E68 SW:7.5.63 CODE:90.01 FMGM:90.43 FLEX:90.61.1106 ......................... I HAVE CHOOSED V171 MODEL AND SELECT FILES OF V170: Loading file v.01... V170_7.5.63_Main_TracFone.20M.bin loaded Loading file v.01... V170_7.5.63_LPNA_Fr_Pt_Es.20P.bin loaded Loading file v.02... V170_Flex_90_61_1106.20F.bin loaded .......................................... WHEN I PRESS WRITE BUTTON IT SHOW: PROBADLY WRONG MODEL SELECT AND I PRESS YES IT IS:COM9 [Serial2] selected "repair mode" active "smart write" active "soft restore" active "safe mode" active Action: flash Write: Firmware Write: Language Pack Write: Flex Skip: Eeprom continue w/o "safe mode" Device: V170,V171,V172,V173 Checking data, wait... Connect... Press and HOLD Power button... Release Power button ! Connect Done Boot... Boot Done Set Baud... 230400 Set Baud Done Check Flash-1... SW version: HW version: Flex ver: Check Flash-1 Done Check Flash-2... reading ... file saved: backup_eeprom_calibration__20070925-234646.20E.bin Check Flash-2 Done Write... Writing: Firmware "safe mode" active retry[01] at: 00020000 retry[02] at: 00020000 retry[03] at: 00020000 retry[04] at: 00020000 retry[05] at: 00020000 retry[06] at: 00020000 retry[01] at: 00030000 retry[02] at: 00030000 retry[03] at: 00030000 Write Done Failed ! Finished, time used: 327 sec Remove/Install battery now ! AND NOT POWER ON THE PHONE. NEED HELP SUPPORT TEAM.THANKS |
hello! to rescue this phone you must cut now test point. also when you unlock phone for that- pay attention to hardware, especialy to flash IC, because this error is caused by hardware defect |
Thanks infinityHelp BR |
