Old 05-25-2008, 09:10   #1 (permalink)
Member: 609370
Thanks Meter: 13
Ztc 618 Reboot-got Rx,tx-still Can Not Format
i have a ZTC618 (2*6 connector) reboot problem.as usual find rx,tx using pinfinder-got as below.
software version: 1.06
cable type: 2x6 (L12B)
platform: MT6205, MT6217-MT6228
searching adapter at COM6...
adapter found, version: 2000
pins: 12, plain
power cycles: 1
activation cycles: 7
power-off delay: 20
start Rx/Tx: 1/1
Loading configuration...
Initializing...
Press and HOLD phone Power button now !
detecting pins...
19200
CPU: MT6205
result: Rx:4 Tx:2
time required: 20 sec
Power On !
then did format ffs-an error as below.
OM6 [VCP0] selected
Action: reset settings
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200 autodetect
Initializing[6205:8B00]...
CPU: MT6205
high speed boot enabled
Connecting, wait...
error: can't finalize test mode
repeat operation and HOLD phone "Power" button long time !
error: operation failed !
Finished, time used: 99 sec
Remove/Install battery now !
when power button press-set on-then off ommediatley is the problem.i have faced such problems before.so i open the set and look for first cpu rx,tx.some golden markings on the board.so sure second cpu rx,tx in jack and first cpu on board.(board photo attached).but i tried diffenet combinations in board as rx,tx.but failed.
any friends know this board rx,tx?
or how format second cpu usinf infinity?
help me--thank u
Old 05-25-2008, 10:34   #2 (permalink)
ezysuresh's Avatar
Member: 216081
Sonork: 100.1614205
Thanks Meter: 55
If you cant format ffs safe, use format ffs complete. But before you do make full backup of flash. BR
The Following User Says Thank You to ezysuresh For This Useful Post:
Old 05-25-2008, 12:47   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
@zone2
Is it dual sim phone ?
Old 05-25-2008, 13:20   #4 (permalink)
Member: 609370
Thanks Meter: 13
Originally Posted by InfinitySupport View Post
@zone2
yes..
i tried backup flash-it also can not-an error as below.
COM6 [VCP0] selected
Device: Autodetect 6205-6227 NOR
eeprom backup enabled, it may takes several minutes !
Action: read NOR flash
Boot...
19200 fixed
Connecting, wait...
CPU: MT6205
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 01227E221A2201:18E59F00000000
flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb
detecting chip #01 in region #00...
error: no any expected answer: wrong answer after chip cfi request
error: no any expected answer: wrong answer after chip id request
Initialize Done
Set baud...
115200
error: no any expected answer: set baud_request_not_confirmed
error: can't work at this speed, use lower speed
Set baud Fail
Finished, time used: 23 sec
set is on and working without sim-i have faced similar error messages before.all that suceeded in board rx,tx.
i think again in jack rx,tx for second cpu.but i dont know how format second cpu using infinity?if it possible customer can use second sim slot.am i right?
help me
thank u
Old 05-25-2008, 15:38   #5 (permalink)
Member: 130995
You have found pinout for snd CPU (MT6205), but you need to find now pinout for 1st mani CPU (MT6226 or MT6227)
so try to detect pinout again (but disable in PinFinder 2nd CPU pins that you already have found).
You need to format 1st (main) CPU.
Old 05-26-2008, 05:26   #6 (permalink)
Member: 609370
Thanks Meter: 13
where is this option?
Old 05-26-2008, 14:10   #7 (permalink)
Member: 130995
Hm...
Is it hard to download InfinityUpdate_PinFinder_v1.09.rar from Infinity-Box support area ?
one more link for you: http://www.infinity-box.biz/download..._PinFinder.pdf
You must promise me that you will read this manual before you will ask your next question.
Old 05-26-2008, 17:54   #8 (permalink)
Member: 609370
Thanks Meter: 13
Hm...
thank u-now understood -set ok.
Action: reset
Boot...
19200 fixed
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
high speed boot disabled
chip: 0031:A8B8094
high speed disabled
boot step size: 0002
Boot Done
Initialize...
flash: 01227E22202200:29EA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
115200
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area#1 is Ok
security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.626F5431.[MTK26_05C_MASTER_PCB01_GPRS_MT6226_S01.MAUI_05C_W0 6_16.BIN_2B451ED7].rpl
New firmware detected:
- make "Read full flash" operation
- send "backup_system_log_..." file to support: [email protected]
- send flash backup file(s) to support: [email protected]
- include in your e-mail full text from phone back label (phone name etc.)
identification#1 detection finished
device-id: 626F5431
identification#1 protocol ver: 04
ver. sw1: MTK26_05C_MASTER_PCB01_GPRS_MT6226_S01.MAUI_05C_W0 6_16.BIN
ver. sw2: MAUI.05C.W06.16, 28E1BAD4
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading [eeprom[MTK26_05C_MASTER_PCB01_GPRS_MT6226_S01.MAUI_05C_W0 6_16.BIN]]...
file saved: C:\Documents and Settings\Zone\Desktop\backup_eeprom[MTK26_05C_MASTER_PCB01_GPRS_MT6226_S01.MAUI_05C_W0 6_16.BIN]_20080526-213650.B0E.bin
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
Write Done
Finalization...
formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _626F5431_MTK26_05C_MASTER_PCB01_GPRS_MT6226_S01.M AUI_05C_W06_16.BIN_2B451ED7_20080526-213716.B0X.bin
Finished, time used: 363 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 05-26-2008, 19:07   #9 (permalink)
Member: 130995
One more request: please, if possible, follow the next instruction given by software
cpf box detects rx tx automatic or not? smr29126 CPF-BOX Ⅱ 1 03-10-2009 15:21
i got new cruser and can not work with cruiser suit melgsm Cruiser Suite 2 10-18-2008 18:40
Griffin Access still can not unlock LG8120 :(((( KUBAT1 Griffin 1 01-17-2005 18:33
Griffin server can unlock C2200 but BLAZER still can not :-(( foony Blazer 8 12-13-2004 05:05
Page generated in 0.33579 seconds with 10 queries
