09-23-2008, 14:53 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: NEAR YOU
Member: 205427 Status: Offline Sonork: 100.1580937 Thanks Meter: 1,162 | >>> Moto W370 Trancefone Sim Not Valid Solved <<< Solution >>> 1. Flashed with W375 flash files from support. W375_0[1].0.64_Main_H80S_1165475254.34M w375_0[1].0.64_LP_A03_En_Indonesia_Tagalog_Th_Vn.34P w375_Flex_AN_005_retail[1].34F 2. After flash phone shows " phone hacked 68 " 3. Just do sp unlock. Moto 01 software will say " Phone not locked ". 4. Continue with unlock procedure. 5. Now you have fully working phone. But In India it will get Airtel network (1800 Mhz). Big Thanks to Infinity Team >>>>>> Here is the log both flashing and unlocking >>> Current model: W375 Loading file v.02... W375_0[1].0.64_Main_H80S_1165475254.34M.bin loaded Loading file v.02... w375_0[1].0.64_LP_A03_En_Indonesia_Tagalog_Th_Vn.34P.bin loaded Loading file v.02... w375_Flex_AN_005_retail[1].34F.bin loaded COM15 [Serial2] selected "smart write" active Action: flash Write: Firmware Write: Language Pack Write: Flex Skip: Eeprom Device: W375 Checking data, wait... Connect... Press and HOLD Power button... rom version: 0411 Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 921600 Set Baud Done Check Flash-1... SW version: 6.9.75 HW version: MOTOROLA_H80S LP ver: Flex ver: FLEX_A0_00I cpu id: 08B6 imei eeprom: 3545130131879470 required SW version: 6.9.75 Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration _35451301318794_20080923-162017.34E.bin Check Flash-2 Done Write... Writing: Firmware Writing: Language Pack Writing: Flex Write Done Finished, time used: 319 sec Remove/Install battery now ! Current model: W375 COM15 [Serial2] selected Action: unlock Device: W375 Checking data, wait... Connect... Press and HOLD Power button... rom version: 0411 Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 921600 Set Baud Done Check Flash-1... SW version: 0.0.64 HW version: MOTOROLA_H80S LP ver: 0064_A03 Flex ver: FLEX_AN_005 cpu id: 08B6 imei eeprom: 3545130131879470 required SW version: 0.0.64 user confirmed unlock for non-locked phone Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration _35451301318794_20080923-163918.34E.bin unlock step-1 Ok unlock step-2 Ok unlock step-3 Ok unlock step-4 Ok unlock step-5 Ok finished Ok Finished, time used: 29 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to zeel_zeel For This Useful Post: |
07-08-2009, 08:21 | #4 (permalink) |
Freak Poster Join Date: Jul 2007 Location: ctg ,bangladesh Age: 42
Member: 538272 Status: Offline Sonork: 100.1589159 Thanks Meter: 71 | i m tested phone unlock Loading file v.02... W375_0[1].0.64_Main_H80S_1165475254.34M.bin loaded Loading file v.02... w375_0[1].0.64_LP_A03_En_Indonesia_Tagalog_Th_Vn.34P.bin loaded Loading file v.02... w375_Flex_AN_005_retail[1].34F.bin loaded COM15 [Serial2] selected "smart write" active Action: flash Write: Firmware Write: Language Pack Write: Flex Skip: Eeprom Device: W375 Checking data, wait... Connect... Press and HOLD Power button... rom version: 0411 Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 921600 Set Baud Done Check Flash-1... SW version: 6.9.75 HW version: MOTOROLA_H80S LP ver: Flex ver: FLEX_A0_00I cpu id: 08B6 imei eeprom: 3545130131879470 required SW version: 6.9.75 Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration _35451301318794_20080923-162017.34E.bin Check Flash-2 Done Write... Writing: Firmware Writing: Language Pack Writing: Flex Write Done Finished, time used: 319 sec Remove/Install battery now ! thanks brother ////////// |
07-15-2009, 22:25 | #5 (permalink) |
Freak Poster Join Date: Apr 2007 Location: nigeria
Member: 487753 Status: Offline Thanks Meter: 4 | help,i got this error "smart write" active Action: flash Write: Firmware Write: Language Pack Write: Flex Skip: Eeprom Device: W370 Checking data, wait... Connect... Press and HOLD Power button... rom version: 0411 Connecting... error: incorrect certificate Release Power button ! Connect Fail Finished, time used: 10 sec Remove/Install battery now ! |
07-15-2009, 22:51 | #6 (permalink) |
Member: 487753 Status: Offline Thanks Meter: 4 | i got this error "smart write" active Action: flash Write: Firmware Write: Language Pack Write: Flex Skip: Eeprom Device: W370 Checking data, wait... Connect... Press and HOLD Power button... error: wrong sertificate Release Power button ! Connect Fail Finished, time used: 7 sec Remove/Install battery now ! |
12-08-2009, 11:56 | #8 (permalink) | ||
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,421 | Quote:
select W375 and post me results BR Faisal_Computer | ||
Moto V176 Net10 error sim not valid | GSMBALOCH | Infinity-Box | 14 | 12-15-2011 17:41 |
e65 sim not valid[SOLVED] | nasir0133nasir0 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 03-05-2010 07:31 |
E71 sim not valid [ Solved ] | ham_sang | Cyclonebox | 15 | 02-06-2010 12:33 |
Moto C261 Sim not Valid | eko_java_cell | Infinity-Box | 6 | 05-28-2008 05:52 |
>>>f1: N70 Sim Not Valid <<< | RNC_EBM | Federal One | 0 | 01-21-2007 11:05 |
