12-26-2012, 13:05 | #1 (permalink) |
Banned Join Date: May 2010
Member: 1308936 Status: Offline Thanks Meter: 88 | moto W377 can't unlock plz help me out module v1.38 Loading data, wait... Device: Motorola-W377 Action: unlock Press Power button now ! rom version: 0411 Connecting... rom version: 0411 booting... finalizing... working, one more step... repeat connection request... repeat connection request... error: incorrect boot answer-1: Finished, time used: 1 min 13 sec Remove/Install battery now ! |
01-02-2013, 16:03 | #6 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Quote:
Actually, this kind of problem was discussed many times and it's possible to find answers in this forum, anyway: 1. Try to adjust COM port settings: C:\InfinityBox\Documentation\FAQ\box_settings_COM_ port.jpg 2. If you have cable - try to use another cable, it may be this helps due to unlock communication goes at high speed and sometemes other cable gives good results. | |
01-04-2013, 10:22 | #7 (permalink) |
Member: 1308936 Status: Offline Thanks Meter: 88 | still COM5 [VCP0] selected module v1.38 Loading data, wait... Device: Motorola-W377 Action: unlock Press Power button now ! rom version: 0411 Connecting... booting... finalizing... working, one more step... repeat connection request... repeat connection request... error: incorrect boot answer-1: 52 Finished, time used: 53 sec Remove/Install battery now ! |
02-07-2013, 02:00 | #10 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,861 | Hello, If you have another cable, please, try with another cable. Unlock process running at high baudrate and some cables may gives problems for this operation. |
02-22-2013, 06:33 | #13 (permalink) |
Member: 1308936 Status: Offline Thanks Meter: 88 | i note one thing every opration (reset/read flash/reset user data) etc it show this ERROR module v1.38 Device: Motorola-W377 "advanced chip detection" active Action: reset settings Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0411 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 812500 Set baud done Check hardware ... flash: 20880DFFFFFFFF:20880D00000000 flash: ST Intel/Sharp ext [def 00FFx020000 0004x008000] 32Mb software version: 0.0.32 software version: MOTOROLA_H58S Check hardware done Read data ... reading Motorola-W377_eeprom_calibration-1... warning: wrong cs at 0x05FE0C00, retry... warning: wrong cs at 0x05FE0C00, retry... warning: wrong cs at 0x05FE0C00, retry... warning: wrong cs at 0x05FE0C00, retry... warning: wrong cs at 0x05FE0C00, retry... warning: wrong cs at 0x05FE0C00, retry... warning: wrong cs at 0x05FE0C00, retry... warning: wrong cs at 0x05FE0C00, retry... warning: wrong cs at 0x05FE0C00, retry... error: too many retries during read operation Probably errors exist during flash read operation. Do you want to repeat read operation ? aborted by user whats mean this error? |
02-25-2013, 13:08 | #14 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,861 | Hello, it may be a result of: 1. bad PC/Phone communication (bad cable) 2. it may be that phone has damaged (semi-damaged) flash chip and data can not be read from phone memory well. If phone has a semi-damaged flash chip - it may be a reason for unlock fail. If you ready yo fight with this phone you should open it, check it hardware, check water inside etc., but be careful due to this phone can stop to power-on at any time. |
03-04-2013, 16:48 | #15 (permalink) | |
Member: 1308936 Status: Offline Thanks Meter: 88 | Quote:
i buy code problem solved | |
