12-12-2015, 15:44 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: inside forum
Member: 759477 Status: Offline Sonork: 100.1618763 Thanks Meter: 111 | SPD 7731G firmware read issue 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 17 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Detected eMMC Flash , Structure detect Ok! [FW_READER] : Step #1 Passed! [FW_READER] : Step #2 Passed! [FW_READER] : Step #3 Failed! Error_Info : DVL Failed , If it Android 5.x - Root Required |
12-12-2015, 16:43 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Some Android 5.x phones require root right now. I keep looking for other way, but it still require time. |
04-16-2016, 05:49 | #3 (permalink) |
Junior Member Join Date: Apr 2014
Member: 2170299 Status: Offline Thanks Meter: 0 | Qmobile M95 required root while reading flash file with CM2 any solution? Chinese Miracle II [SPD module] v 1.16 Operation : Read FullFlash [ v1.16 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 42 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Detected eMMC Flash , Structure detect Ok! [FW_READER] : Step #1 Passed! [FW_READER] : Step #2 Passed! [FW_READER] : Step #3 Failed! Error_Info : DVL Failed , If it Android 5.x - Root Required |
04-16-2016, 07:32 | #4 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Yes, as log says root required for Android 5.x. Team is working on this direction. Br. Infinity Box Support Team. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
06-04-2016, 20:34 | #6 (permalink) |
Freak Poster Join Date: Sep 2007 Location: algeria
Member: 581441 Status: Offline Sonork: 100.1656898 Thanks Meter: 33 | Is there any solution for this situation? I need it, most of new phones this days have android 5.x please team fix this in the next update and keep it up, you'r the BEST |
