Old 03-29-2009, 02:34   #1 (permalink)
bencebacsi's Avatar
Member: 829361
Thanks Meter: 107
White screen after flashing
I flashed this phone with the same firmware but it starts up with a white screen. I've got 2 pcs. of this phone and downlowded the firmware from both, but the results are the same. Maybe a new flash chip again. The phones worked properly before the flashing.
COM14 [VCP1] selected
module v2.79
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: write NOR flash
"smart write" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:B203:000D
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 98000300000000:18E59F00000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
460800
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
New firmware detected (v.2.79, database date: unknown):
E806_PH1_EVCOM_MT6225S00.01_1_20090116.BIN
This firmware is missing in support area. If this phone is good and working:
- make "Read full flash" operation
- send flash backup files to support: [email protected]
- include in your e-mail full text from phone back label (phone name etc.)
identification#1 detection finished
identification#1 protocol ver: 04
ver. sw 1: E806_PH1_EVCOM_MT6225S00.01_1_20090116.BIN
ver. sw 2: E806_PH1.01.1, 00000000
ffs offset/size: 01C00000/00400000
detect device identification#2...
detect device identification#2 finished
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
detecting security area (code #2)...
security area (code #2) is absent
Area: Firmware
Write: Firmware
Write Done
Finalization ...
Finalization Done
Finished, time used: 637 sec
Remove/Install battery now !
The flash file can be downloaded from here: http://rapidshare.com/files/21476568..._.B0M.bin.html
Old 03-29-2009, 02:42   #2 (permalink)
Member: 411486
Thanks Meter: 68
you should try do a efs and full reset.the china mobile flash are very strange....
Old 03-29-2009, 19:55   #3 (permalink)
bencebacsi's Avatar
Member: 829361
Thanks Meter: 107
Thank you, but I know the features of CM after flashing more than a thousand chinese phones. This is a compatibility problem caused by a new flash chip. Other tools absolutely can not handle the flash chip of these phones. Only Infinity CM can read, but actually not properly write it. I wrote this message for CM developers.
Old 03-29-2009, 20:31   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
@bencebacsi
You are completely wrong regarding problem reason.
Flash chip type is NOT important for this situation !
Problem is: you have flashed phone with firmware that is not good for your phone LCD type. You must use other firmware that support your phone LCD type.
Old 03-29-2009, 22:56   #5 (permalink)
bencebacsi's Avatar
Member: 829361
Thanks Meter: 107
I flashed the phone with the same firmware what I downloaded from that phone earlier. The phone (both) worked properly before the flashing. So, that's simply impossible, that I flashed the phones with wrong version firmware. Even if I check "Smart" write and load the unmodified firmware, CM always rewrite some parts above 90%.
Old 03-30-2009, 00:07   #6 (permalink)
Member: 411486
Thanks Meter: 68
i had this problem to with a china.i flashed the phone with same firmware and the phone was blank lcd but i made a backup before and a managed to write itback and returned the phone to the client.thatīs why in the present i avoid to make any flashes without reading the original flash and make a backup.....the CM have a lot of problems.I hope you will resolve your problem my friend.good luck
Old 03-30-2009, 19:36   #7 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
what was a reason to flash? what was a problem with phone?
do you have orginal flash backups?
Old 03-30-2009, 21:17   #8 (permalink)
bencebacsi's Avatar
Member: 829361
Thanks Meter: 107
The reason was language translation, as almost always at me. Yes, I used always the original flash backups only. The file, what I uploaded to rapidshare, is one of them. I used smart write first time with the original, but modified flash file. Than I tried the original (downloaded from the same phone) unmodified flash with smart write again, than without smart write.
Old 03-30-2009, 23:03   #9 (permalink)
Member: 411486
Thanks Meter: 68
hello!
nop.i'm sorry but i don't have it anymore cu'z it was a long time ago.maybe next time i will remember to save it and upload it for support.
Old 03-31-2009, 20:20   #10 (permalink)
Member: 148515
hello!
i affraid that now your phone will rescue only full backup taken from another working phone.
c1300 displays white screen after flash gorgans VygisToolbox 5 12-12-2009 18:06
3650 blinks white screen after flash with latest version mailhassan WD2 & APE (Symbian Phones) 13 12-19-2008 08:00
Auto shut off V3 turns white screen after flashing flash... scion Motorola P2k 10 09-19-2007 10:31
7610 white screen after flashing a ppm MELME UFS2 + UFS3-Tornadoflasher 29 05-05-2006 01:53
E720 - white screene after flashing QMaro NSPRO 3 10-22-2005 11:45
Page generated in 0.21582 seconds with 9 queries
