07-04-2006, 18:34 | #1 (permalink) |
No Life Poster Join Date: Mar 2005 Location: gsmwebstore
Member: 125366 Status: Offline Sonork: 100.1602649 Thanks Meter: 108 | Motorola 168 After Flash DEAD COM6 selected Device: C168 Checking data, wait... Action: Flash write Write: Firmware Write: Flex Write: Language Pack Skip: FFS/File system Write: Images Write: Melody Smart Write active Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... SW ver: 1180-000 HW ver: TCT-7- Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0089:886400010001 Check Space Done Check Data... Check Data Done Erasing... Erasing Done Writing... Write: Firmware Flash: 0089:886400010001 try to recovery erase error [43] try to recovery erase error [5D] try to recovery write error [00:45:00000000] Writing Fail Finished Remove/Install battery now ! Time used: 30 sec moto is dead i also Read backup But How we can write Backup file ? |
07-04-2006, 21:26 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Hi, Download latest Moto02 v1.14 from support area and try again. Also for info: flashing main+lp+flex+images+melody dont have any effects for removing phone code. |
07-05-2006, 15:39 | #3 (permalink) |
Member: 125366 Status: Offline Sonork: 100.1602649 Thanks Meter: 108 | COM5 selected Device: C168 Checking data, wait... Action: Flash write Write: Firmware Write: Flex Write: Language Pack Skip: FFS/File system Skip: Images Skip: Melody Smart Write active Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... SW ver: HW ver: Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0089:886400010001 Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Firmware Flash: 0089:886400010001 Err: error flash command try to recover erase error#43 (Same Condition) |
07-05-2006, 17:49 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Hi, it's not a problem with backup or wrong firmware or something like this. The problem is: flash can't be written. I don't know the reason for sure but my advice: open phone, check flash chip. maybe water, maybe need to rehot it. Of course it can be something else but can't imagine right now what it can be. It's really strange that readed phone code was wrong. also very strange that phone can't be flashed so I think there is a reason to check hardware. |
07-10-2006, 22:59 | #6 (permalink) |
No Life Poster Join Date: Feb 2006 Location: campioni del mondo
Member: 235881 Status: Offline Thanks Meter: 221 | plz help i have the some problem i don't know what i can do plz this is flash procedure COM5 selected Device: C168 Checking data, wait... Action: Flash write Write: Firmware Write: Flex Write: Language Pack Skip: FFS/File system Skip: Images Skip: Melody Smart Write active Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 203125 Set Baud Done Check Flash... SW ver: HW ver: Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0020:8810FFFFFFFF Check Space Done Check Data... Check Data Done Erasing... Erasing Done Writing... Write: Firmware Flash: 0020:8810FFFFFFFF try to recovery write error [00:54:00000000] try to recovery write error [01:5D:00000000] Err: no any answer Writing Fail Finished Remove/Install battery now ! Time used: 39 sec !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!! |
07-13-2006, 22:22 | #8 (permalink) |
No Life Poster Join Date: Jan 2002 Location: Bad Cluster Age: 45
Member: 8426 Status: Offline Thanks Meter: 17 | nothing to reflow or to rehot ..... exacltly same problem here battery was full charged phone 100% was ok now phone dead in prepare Writing... Write: Firmware Flash: 0089:886400010001 Err: error flash command try to recover erase error#43 pls need fix that problem as soon as possible best regards |
07-14-2006, 01:06 | #9 (permalink) |
Banned Join Date: Sep 2003 Location: Cambodia
Member: 39069 Status: Offline Sonork: 100.1606677 Thanks Meter: 190 | If all here after flash phone dead please try to flash deferent version.Here I use version _1280_ all files (main, flex, lp, mel and amage the same _1280_) Loading file [version 02]... C168_Main_7-1280-000_2006-Feb-22.69M.bin Loaded Loading file [version 02]... C168_Flex_1280-007_T676FC_8V33_V1.69F.bin Loaded Loading file [version 02]... C168_LP_1280-005_T676FB_8V33_V1_En_Cn_Ml.69P.bin Loaded Loading file [version 02]... C168_Melody_1280-004_T676EW_8V33_V1.69G.bin Loaded Loading file [version 02]... C168_Images_1280-004_T676EW_8V33_V1.69G.bin Loaded |
07-26-2006, 18:24 | #11 (permalink) |
Freak Poster Join Date: Dec 2003
Member: 46116 Status: Offline Thanks Meter: 4 | Iam also having the same problem Pls help me too.... Here is my log COM1 selected Device: C168 Checking data, wait... Action: Flash write Write: Firmware Write: Flex Write: Language Pack Skip: FFS/File system Skip: Images Skip: Melody Smart Write active Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... SW ver: 1280-000 HW ver: TCT-7- Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0020:8810FFFFFFFF Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Firmware Flash: 0020:8810FFFFFFFF Err: error flash command try#1 to recover erase error#43 Err: error try#00 to recover write error at 00000000 Writing Fail Finished Remove/Install battery now ! Time used: 129 sec Actually aim posting this for third time pls help me to recover my phones, I have two phones same error.... |
07-26-2006, 18:43 | #12 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Please, send me full log file to [email protected] |
Savvy 168 after flashing... | qido | Philips | 5 | 01-31-2001 21:29 |
