MOTOROLA C-118 connect problem dear supporter very regret to sat that once again C-118 connection problem getting occured, here is log-: COM7 selected Action: format Device: C113(a),C114,C115,C116,C117,C118 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 any body can help me to sort out this problem. Let me tell that bat is FULL and CABLE is fine working with other models very well. |
I am sorry for my above thread it has been solved but in some method else here is Action: format Device: C113(a),C114,C115,C116,C117,C118 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 1.0.65.E. HW version: _E88 imei otp: 357679009910530 Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration _357679009910530_20090211-114726.18E.bin imei eeprom: 357679009910530 Check Flash-2 Done Write... Write Done Finished, time used: 36 sec Remove/Install battery now ! first i run software then PRESS FFS button , then insert cable and press hold POWER SWITCH and into last i put BATTERY instantly, result connected successfuly and job done. |
