02-11-2009, 06:46 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: on forum
Member: 566122 Status: Offline Thanks Meter: 322 | MOTOROLA C-118 connect problem COM7 selected Action: format Device: C113(a),C114,C115,C116,C117,C118 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 any body can help me to sort out this problem. Let me tell that bat is FULL and CABLE is fine working with other models very well. |
02-11-2009, 07:54 | #2 (permalink) |
Member: 566122 Status: Offline Thanks Meter: 322 | I am sorry for my above thread it has been solved but in some method else here is Action: format Device: C113(a),C114,C115,C116,C117,C118 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 1.0.65.E. HW version: _E88 imei otp: 357679009910530 Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration _357679009910530_20090211-114726.18E.bin imei eeprom: 357679009910530 Check Flash-2 Done Write... Write Done Finished, time used: 36 sec Remove/Install battery now ! first i run software then PRESS FFS button , then insert cable and press hold POWER SWITCH and into last i put BATTERY instantly, result connected successfuly and job done. |
The Following 2 Users Say Thank You to aminnovelty For This Useful Post: |
Motorola Phone Connectivity Problems in ET-BoX | nonu_don | ET-BoX | 22 | 01-01-2009 09:10 |
motorola c115,118 cable problem | toptech | Multi-Box | 4 | 03-21-2007 13:16 |
Motorola Acer Model Connection Problem? | ethiomobile | Motorola ODM | 0 | 01-02-2007 08:18 |
unlock code for motorola c 118 | dino_d | Phone Unlocking Codes & Maps | 1 | 07-13-2006 23:40 |
1.118 download problem | nausahad | Sonics Box | 3 | 07-27-2005 06:29 |
