Old 10-24-2007, 21:48   #1 (permalink)
vadimv's Avatar
Member: 106887
Thanks Meter: 48
Motorola c121 dead!!!!
Hi to everyone! today came to me a motorola c121! Unlock and flash, simple isn't it?
unlocked ok, but after trying to flash the soft gived me a error, after that computer simply doesn't see the phone! just no reaction! what can i do? tried even to cut testpoint! noting...
COM1 ready
COM1 [Serial0] selected
Action: unlock
Device: C121
Checking data, wait...
Connect...
Press and HOLD Power button...
connection mode: 00
error: boot failure[04]: general communication fault.
Release Power button !
Connect Fail
Finished, time used: 10 sec
Remove/Install battery now !
Action: unlock
Device: C121
Connect...
connection mode: 00
Connect Done
Boot...
Boot Done
Set Baud...
115200
Set Baud Done
Check Flash-1...
SW version: 1.0.75.E.
HW version: _E88
imei otp: 353290016876609
Check Flash-1 Done
Check Flash-2...
reading ...
file saved: backup_eeprom_calibration_353290016876609_20071021-150839.18E.bin
imei eeprom: 353290016876609
Check Flash-2 Done
Write...
Write Done
Finished, time used: 17 sec
Loading file v.01...
C115_1.0.38_Main.18M.bin loaded
C115_1.0.38_LP_T10_132.18P.bin loaded
C115_1.0.38_Flex_15_132.18F.bin loaded
"smart write" active
Action: flash
Write: Firmware
Write: Language Pack
Write: Flex
Skip: Eeprom
Device: C121
Connect...
connection mode: 00
Connect Done
Boot...
Boot Done
Set Baud...
115200
Set Baud Done
Check Flash-1...
HW version: _E88
Check Flash-1 Done
Check Flash-2...
reading ...
file saved: backup_eeprom_calibration_353290016876609_20071021-151139.18E.bin
Check Flash-2 Done
Write...
Writing: all flash areas
error: write at 00002000:
error: write at 00002000: FF
Write Done
Failed !
Finished, time used: 53 sec
Action: flash
Write: Firmware
Write: Flex
Skip: Eeprom
Device: C121
Connect...
connection mode: 00
error: boot failure[02]: 00
Connect Fail
Failed !
Finished, time used: 32 sec
Old 10-24-2007, 22:46   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
you must cut test point and use connection method "repair" to get communication with phone
Old 10-24-2007, 22:50   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
need to cut track. if you tried and nothing this means that wrong track cutted or not enough cutted.
Motorola C121 unlock help help cecogsm Ultima Box Light 17 07-22-2007 08:33
Motorola C121 faustus Sell ur Old and Used Stuff 0 05-10-2007 22:12
motorola c121 new cell phone unlock??? Siemens man Infinity-Box 33 03-02-2007 13:21
Unlock Motorola C121 hitibiti Multi-Box 4 02-11-2007 11:44
how to unlock new motorola c121???? Siemens man Motorola ODM 7 01-13-2007 23:42
Page generated in 0.13213 seconds with 10 queries
