motorola c123 motorola c123 unlock succes but not unlock plz help |
please post detailed log here, i have just ulocked c123 COM15 [Serial2] selected Action: unlock Device: C122, C123 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 2.4.78.N. HW version: _E88 imei otp: 356470010938210 Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration _356470010938210_20080716-154815.18E.bin imei eeprom: 356470010938210 extra method pass-1... reading ... extra method pass-2... Check Flash-2 Done Write... Write Done Finished, time used: 40 sec Remove/Install battery now ! detailed log will helpful to support you by infinity team |
@maanarman also in some cases it is need to flash phone to make it unlocked |
sir its says connection mode00 whene not connect how can flash plz help |
How to unlock Motorola c123 Quote:
Sir can u tell me the procedure of Motorola c123 Unlocking. tell me in detail. thanks. |
@faizanbhatti94 1. connect cable 2. run software 3. press "unlock" button 4. follow instruction given by software Don't forget to check this folder at your PC: C:\Program Files\InfinityBox\Documentation @maanarman Now I can not understand your problem. In first message you to;ld that unlock is Ok but now you talk about connection problems. So, what is the real situation ? |
c123 unlock sir ufone is locked c123 when i unlock job unlock done now still lock mobile other wise i do any job example change imei or flash mobile now show error connection mode00 plz sir help me |
Hello, Please, explain what you have tried to do step by step ! |
