Old 09-18-2008, 05:12   #1 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,822
motorola c123
motorola c123 unlock succes but not unlock plz help
Old 09-18-2008, 06:31   #2 (permalink)
Chandreshswami's Avatar
Member: 370998
Sonork: 100.1582579
Thanks Meter: 219
please post detailed log here, i have just ulocked c123
COM15 [Serial2] selected
Action: unlock
Device: C122, C123
Checking data, wait...
Connect...
Press and HOLD Power button...
connection mode: 00
Release Power button !
Connect Done
Boot...
Boot Done
Set Baud...
115200
Set Baud Done
Check Flash-1...
SW version: 2.4.78.N.
HW version: _E88
imei otp: 356470010938210
Check Flash-1 Done
Check Flash-2...
reading ...
file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration _356470010938210_20080716-154815.18E.bin
imei eeprom: 356470010938210
extra method pass-1...
reading ...
extra method pass-2...
Check Flash-2 Done
Write...
Write Done
Finished, time used: 40 sec
Remove/Install battery now !
detailed log will helpful to support you by infinity team
The Following User Says Thank You to Chandreshswami For This Useful Post:
Old 09-18-2008, 07:55   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
@maanarman
also in some cases it is need to flash phone to make it unlocked
Old 09-19-2008, 17:45   #4 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,822
sir its says connection mode00 whene not connect how can flash plz help
Old 09-19-2008, 18:36   #5 (permalink)
Cheater -Don't Deal with him-
Member: 265129
Thanks Meter: 281
How to unlock Motorola c123
Originally Posted by InfinitySupport View Post
@maanarman
Sir can u tell me the procedure of Motorola c123 Unlocking.
tell me in detail.
thanks.
Old 09-19-2008, 19:55   #6 (permalink)
Member: 130995
@faizanbhatti94
1. connect cable
2. run software
3. press "unlock" button
4. follow instruction given by software
Don't forget to check this folder at your PC: C:\Program Files\InfinityBox\Documentation
@maanarman
Now I can not understand your problem.
In first message you to;ld that unlock is Ok but now you talk about connection problems.
So, what is the real situation ?
Old 09-20-2008, 19:09   #7 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,822
c123 unlock
sir ufone is locked c123 when i unlock job unlock done now still lock mobile other wise i do any job example change imei or flash mobile now show error connection mode00 plz sir help me
Old 09-21-2008, 09:00   #8 (permalink)
Member: 130995
Hello,
Please, explain what you have tried to do step by step !
motorola c123 phone is locked harisa Motorola ODM 21 12-30-2009 18:07
Motorola c123 unlocking solotion need yousaf benjamin Motorola ODM 2 10-25-2008 19:05
Motorola C123 Unlock zubairok IQ-Box 3 06-16-2007 19:00
v1.22 Released - Added Support for Motorola C123, C155, C156, C157, V170, V171 & V172 .:ET-BoX.net:. ET-BoX 5 04-12-2007 09:12
Page generated in 0.21108 seconds with 9 queries
