01-28-2007, 22:55 | #1 (permalink) |
Junior Member Join Date: Nov 2006
Member: 385518 Status: Offline Thanks Meter: 0 | motorola c139 unlock I am a newbie. I just bought c139 and want to unlock motorola c139. I have read all of the thread in the forum, but there is no clear, step-by-step instruction for the unlocking procedure - from setup to finish. I have downloaded the neccessary files from the supported area, but I do not know how to use the module program. The infinity box is connected via USB port, but the program asks for com port. Since the product did not come with any, I would appreciate a detailed step-by-step instruction. I have searched this site and read all the thread extensively and did not come up with a solution. This product should be user-friendly, and easy to use, but I am having a lot of difficulties. thank you |
01-28-2007, 23:03 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Yes, you are right ! Product should be user-friendly and we have made this kind of product. In fact I think that you should get some additional knowledges because if you don't know what is "COM port" it's not so easy for you to use even The Most User Friendly Product for mobile phones service. Anyway, we have really good description of basic procedures that you have to make to use Infinity-Box w/o any problem even if you see PC first time. You must know only words "click" and "keyboard" to start work. You can read detailed descriptions of all procedures here: http://forum.gsmhosting.com/vbb/showthread.php?t=342807 Please, read this link carefully, you will find A LOT of really interesting info. After you read all by above given link please and if (want to repeat, if) you will have any questions (I say if because chance is very small) you are always welcome to ask more questions. One request to you: please, don't ask me to explain you "what is COM port". We will refuse this kind of questions because here is product support discussion but not basic PC school. |
02-08-2011, 17:15 | #4 (permalink) | |
How to write flash (upgrade/downgrade firmware, change language): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Flash" page and load required files 8. press "Write" button and follow instruction given by software How to read flash: 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "Read flash" (or "Read full flash") button and follow instruction given by software How to unlock (remove sp-lock, provider lock etc.): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "SP-Unlock" button and follow instruction given by software How to reset/format ffs (reset setting to default values, repair freez/restart etc.): - at first try to make "safe format" (if this option exist) - if "safe" option is not works try to make "complete" format (if this option exist) 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. select format mode "safe" or "complete" (if mode is available) 9. press "Reset" or "Format" button and follow instruction given by software | |
How do i build a motorola c139 unlock cable? | reactos | Motorola Hardware Repair | 11 | 06-12-2009 16:02 |
Motorola c139 unlock | Macko GSM | Motorola ODM | 238 | 05-29-2008 16:43 |
motorola c139 unlocking isnt supported??? | SicilianBoy | Smart-Clip | 9 | 07-11-2006 22:19 |
Motorola C139 unlock???? | dog_baby | Smart-Clip | 2 | 02-11-2006 09:43 |
Motorola C139 Unlock possible? | gsmbase.de | Smart-Clip | 3 | 12-03-2005 18:31 |
