motorola c168,pls help i am flashing a motorola c168,phone does not dispay after flash.below is d progress of d flashing. COM15 selected Device: C168 Checking data, wait... Action: Flash write "smart write" active Write: Firmware Write: Flex Write: Language Pack Skip: FFS/File system Write: Images Write: Melody Skip: Eeprom Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... SW ver: 1490-000 HW ver: TCT-9- Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0089:886400010001 flash: Intel 28F640W18-T T 8Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Firmware Flash: 0089:886400010001 flash: Intel 28F640W18-T T 8Mb Write: Flex flash: Intel 28F640W18-T T 8Mb Write: Language Pack flash: Intel 28F640W18-T T 8Mb Write: Images flash: Intel 28F640W18-T T 8Mb Write: Melody flash: Intel 28F640W18-T T 8Mb Writing Done Finished, time used: 29 sec Remove/Install battery now ! please help |
ffs /file system formate also select then flash Amit Tank |
try to use other flash files sets. |
flash main and fs.................... |
Hello all, Facing problem flashing motorola c168, here under I paste log :- --------------------------------------------------------- COM5 selected Device: C168 Checking data, wait... Action: Flash write "smart write" active Write: Firmware Write: Flex Write: Language Pack Skip: FFS/File system Write: Images Write: Melody Skip: Eeprom Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... SW ver: 1390-000 HW ver: TCT-9- Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0089:886400010001 flash: Intel 28F640W18-T T 8Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Firmware Flash: 0089:886400010001 flash: Intel 28F640W18-T T 8Mb error: error flash vpp try#1 to recover write error at 00000000 error: flash end try#2 to recover write error at 00000000 error: answer#00 try#3 to recover write error at 00000000 error: answer#00 try#4 to recover write error at 00000000 error: answer#00 try#5 to recover write error at 00000000 error: answer#00 try#6 to recover write error at 00000000 error: answer#00 try#1 to recover write error at 00002000 error: answer#00 try#2 to recover write error at 00002000 error: answer#00 try#3 to recover write error at 00002000 error: answer#00 try#4 to recover write error at 00002000 error: answer#00 try#5 to recover write error at 00002000 error: answer#00 try#6 to recover write error at 00002000 error: answer#00 try#1 to recover write error at 00004000 error: answer#00 try#2 to recover write error at 00004000 error: answer#00 try#3 to recover write error at 00004000 error: answer#00 try#4 to recover write error at 00004000 error: answer#00 try#5 to recover write error at 00004000 error: answer#00 try#6 to recover write error at 00004000 error: answer#00 try#1 to recover write error at 00006000 error: answer#00 try#2 to recover write error at 00006000 error: answer#00 try#3 to recover write error at 00006000 error: answer#00 try#4 to recover write error at 00006000 error: answer#00 try#5 to recover write error at 00006000 error: answer#00 try#6 to recover write error at 00006000 error: answer#00 try#1 to recover write error at 00008000 error: answer#00 try#2 to recover write error at 00008000 error: answer#00 try#3 to recover write error at 00008000 error: answer#00 try#4 to recover write error at 00008000 error: answer#00 try#5 to recover write error at 00008000 error: answer#00 try#6 to recover write error at 00008000 error: answer#00 try#1 to recover write error at 0000A000 error: answer#00 try#2 to recover write error at 0000A000 error: answer#00 try#3 to recover write error at 0000A000 error: answer#00 try#4 to recover write error at 0000A000 error: answer#00 try#5 to recover write error at 0000A000 error: answer#00 try#6 to recover write error at 0000A000 error: answer#00 try#1 to recover write error at 0000C000 error: answer#00 try#2 to recover write error at 0000C000 error: answer#00 try#3 to recover write error at 0000C000 error: answer#00 try#4 to recover write error at 0000C000 error: answer#00 try#5 to recover write error at 0000C000 error: answer#00 try#6 to recover write error at 0000C000 error: answer#00 try#1 to recover write error at 0000E000 error: answer#00 try#2 to recover write error at 0000E000 error: answer#00 try#3 to recover write error at 0000E000 error: answer#00 try#4 to recover write error at 0000E000 error: answer#00 try#5 to recover write error at 0000E000 error: answer#00 try#6 to recover write error at 0000E000 Writing Fail Finished, time used: 441 sec Remove/Install battery now ! --------------------------------------------------------- What is my fault, please help. Thanks/ |
Hello, Please, use fully charged battery. Also check phon hardware. |
