Old 04-27-2007, 11:16   #1 (permalink)
Member: 312863
Thanks Meter: 2
Red face motorola c168,pls help
i am flashing a motorola c168,phone does not dispay after flash.below is d progress of d flashing. COM15 selected
Device: C168
Checking data, wait...
Action: Flash write
"smart write" active
Write: Firmware
Write: Flex
Write: Language Pack
Skip: FFS/File system
Write: Images
Write: Melody
Skip: Eeprom
Boot...
Press Power button now !
Connecting...
Boot Done
Check Connection...
Check Connection Done
Set Baud...
Set Baud Done
Check Flash...
SW ver: 1490-000
HW ver: TCT-9-
Check Flash Done
Check Parameters...
Check Parameters Done
Check Space...
Flash: 0089:886400010001
flash: Intel 28F640W18-T T 8Mb
Check Space Done
Check Data...
Check Data Done
Erasing...
erase operation not required
Erasing Done
Writing...
Write: Firmware
Write: Flex
Write: Images
Write: Melody
Writing Done
Finished, time used: 29 sec
Remove/Install battery now !
please help
Old 04-27-2007, 11:46   #2 (permalink)
Amit Tank's Avatar
Member: 219831
Thanks Meter: 104
ffs /file system formate also select
then flash
Amit Tank
Old 04-27-2007, 17:36   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
try to use other flash files sets.
Old 04-27-2007, 17:40   #4 (permalink)
Cheater -Don't Deal with him-
::gsmcoder::'s Avatar
Member: 172434
Sonork: 100.161280
Thanks Meter: 577
flash main and fs....................
Old 05-22-2007, 10:28   #5 (permalink)
Dilip_Nath's Avatar
Member: 387110
Sonork: Not Use
Thanks Meter: 630
Hello all,
Facing problem flashing motorola c168, here under I paste log :-
COM5 selected
Device: C168
Action: Flash write
Write: Firmware
Write: Flex
Write: Images
Write: Melody
Skip: Eeprom
Boot...
Connecting...
Boot Done
Check Connection...
Set Baud...
Set Baud Done
Check Flash...
SW ver: 1390-000
HW ver: TCT-9-
Check Flash Done
Check Parameters...
Check Space...
Check Space Done
Check Data...
Check Data Done
Erasing...
Erasing Done
Writing...
Write: Firmware
error: error flash vpp
try#1 to recover write error at 00000000
error: flash end
try#2 to recover write error at 00000000
error: answer#00
try#3 to recover write error at 00000000
error: answer#00
try#4 to recover write error at 00000000
error: answer#00
try#5 to recover write error at 00000000
error: answer#00
try#6 to recover write error at 00000000
error: answer#00
try#1 to recover write error at 00002000
error: answer#00
try#2 to recover write error at 00002000
error: answer#00
try#3 to recover write error at 00002000
error: answer#00
try#4 to recover write error at 00002000
error: answer#00
try#5 to recover write error at 00002000
error: answer#00
try#6 to recover write error at 00002000
error: answer#00
try#1 to recover write error at 00004000
error: answer#00
try#2 to recover write error at 00004000
error: answer#00
try#3 to recover write error at 00004000
error: answer#00
try#4 to recover write error at 00004000
error: answer#00
try#5 to recover write error at 00004000
error: answer#00
try#6 to recover write error at 00004000
error: answer#00
try#1 to recover write error at 00006000
error: answer#00
try#2 to recover write error at 00006000
error: answer#00
try#3 to recover write error at 00006000
error: answer#00
try#4 to recover write error at 00006000
error: answer#00
try#5 to recover write error at 00006000
error: answer#00
try#6 to recover write error at 00006000
error: answer#00
try#1 to recover write error at 00008000
error: answer#00
try#2 to recover write error at 00008000
error: answer#00
try#3 to recover write error at 00008000
error: answer#00
try#4 to recover write error at 00008000
error: answer#00
try#5 to recover write error at 00008000
error: answer#00
try#6 to recover write error at 00008000
error: answer#00
try#1 to recover write error at 0000A000
error: answer#00
try#2 to recover write error at 0000A000
error: answer#00
try#3 to recover write error at 0000A000
error: answer#00
try#4 to recover write error at 0000A000
error: answer#00
try#5 to recover write error at 0000A000
error: answer#00
try#6 to recover write error at 0000A000
error: answer#00
try#1 to recover write error at 0000C000
error: answer#00
try#2 to recover write error at 0000C000
error: answer#00
try#3 to recover write error at 0000C000
error: answer#00
try#4 to recover write error at 0000C000
error: answer#00
try#5 to recover write error at 0000C000
error: answer#00
try#6 to recover write error at 0000C000
error: answer#00
try#1 to recover write error at 0000E000
error: answer#00
try#2 to recover write error at 0000E000
error: answer#00
try#3 to recover write error at 0000E000
error: answer#00
try#4 to recover write error at 0000E000
error: answer#00
try#5 to recover write error at 0000E000
error: answer#00
try#6 to recover write error at 0000E000
Writing Fail
Finished, time used: 441 sec
What is my fault, please help.
Thanks/
Old 05-22-2007, 12:49   #6 (permalink)
Member: 130995
Hello,
Please, use fully charged battery. Also check phon hardware.
motorola c168 plssss help................ rk19801 Infinity-Box 1 07-05-2008 11:51
motorola C168 dead help therocky8 Infinity-Box 3 11-29-2006 10:35
How to flash motorola V60? pls help Maurone Smart-Clip 4 07-27-2005 22:16
All motorola whiz pls help eeprom_flash Motorola P2k 0 08-06-2004 14:03
2 motorola V70 pls help me with codes melsoft Phone Unlocking Codes & Maps 1 07-15-2003 07:28
Page generated in 0.27924 seconds with 9 queries
