04-16-2008, 23:21 | #1 (permalink) |
Crazy Poster Join Date: Dec 2005
Member: 207023 Status: Offline Thanks Meter: 0 | Motorola C168i - Infiniti cannot read flash I am trying to "Read Flash" a Motorola C168i and it is just not working. I've tried to read" Full flash, EEprom, firmware and flex with no success. Do I need a specific setting to do that?? Also, can I load that backup (once done ) in different phones with same software version?? below you can find the error log when truing to do a full read. Thank you all in advance!!!!!! COM4 [VCP0] selected Device: Motorola C168i "advanced chip detection" active Action: read full flash Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection... Check connection done Set baud... 115200 Set baud done Check hardware... flash: 208810FFFFFFFF:20881000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb version sw: 1230-000 version sw: TTA-4- Check hardware done Read data... reading Motorola C168i_flash_part_1_of_1... warning: wrong data size at 0x00000000, retry... read error recovered warning: wrong data size at 0x00004400, retry... warning: wrong cs at 0x00004400, retry... warning: wrong data size at 0x00004400, retry... warning: wrong cs at 0x00004400, retry... warning: wrong data size at 0x00004400, retry... warning: wrong cs at 0x00004400, retry... warning: wrong data size at 0x00004400, retry... warning: wrong cs at 0x00004400, retry... warning: wrong data size at 0x00004400, retry... error: too many retries during read operation Probably errors exist during flash read operation. Do you want to repeat read operation ? operation canceled by user file saved: C:\Program Files\InfinityBox\HModule\backup_Motorola C168i_flash_part_1_of_1_20080416-181812.69X.bin Finished, time used: 124 sec Remove/Install battery now ! |
04-21-2008, 16:04 | #3 (permalink) |
Member: 207023 Status: Offline Thanks Meter: 0 | Thank for your reply. I have only one V191 cable. It seems to be cause I am able to flash the a C139 with the same cable, with no problem. Any ideas what can I do have the back up done??? About the other question... Am I able to load the backup to a different phone (same make, model and version) to make a copy of it?? I need a few phones (C168i) with the same wap settings. Thanks again!!!!!! I am waiting for your response. |
04-21-2008, 16:33 | #6 (permalink) |
Member: 207023 Status: Offline Thanks Meter: 0 | Thanks guys, I did every combination of ports, speed and protocols possible. I just tried to flash the phone instead just backup and I got the same warning on every single process I do. I must be doing something wrong. I will try again, any other ideas?? Tks in advance. |
ns dongle cannot read flash from P730 | apple inside | NSPRO | 6 | 08-05-2005 05:12 |
TotalMoto cannot read flash from V3??? | DAVI_1 | TotalMoto | 1 | 07-07-2005 07:39 |
S55 - cannot read flash | vsv | E-Gold Based Phones | 1 | 08-12-2004 23:56 |
CANNOT read flash with FREIA | tibi_lord2 | E-Gold Based Phones | 7 | 08-03-2004 11:23 |
cannot read flash from this 3210 | Dark Lemming | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 16 | 02-10-2001 16:53 |
