Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #2 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2006 Location: dword ptr [ebp-1C], edx
Member: 322417 Status: Offline Thanks: 0
| If infiniti says this model is not supportet or something like that than u can't unlock try wia smart-clip otherwise use infinity com1 serial cable t191 press unlock power button thats all the best way is post log hear if not unlocked |
| | #4 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2006 Location: Agrabad,Chittagong,Bangladesh Age: 30
Member: 402075 Status: Offline Thanks: 9
| here it is the log COM6 [VCP0] selected "smart write" active Action: flash Write: Firmware Write: Language Pack Write: Flex Skip: Eeprom Device: C261 Checking data, wait... Connect... Press and HOLD Power button... Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 921600 Set Baud Done Check Flash-1... SW version: 0.1.32 HW version: MOTOROLA_E58S LP ver: LP2_0132 Flex ver: FLEX_90_64_4601 cpu id: 08B6 imei eeprom: 35860500606695 required SW version: 0.1.66 sp-locked: 23410. You want to write Flex in sp-locked[23410.] phone, Make this only when you understand what you want to do ! Are you sure you want to continue ? user confirmed Flex write operation for sp-locked phone Check Flash-1 Done Check Flash-2... reading ... file saved: backup_eeprom_calibration_35860500606695_20070909-135249.34E.bin Check Flash-2 Done Write... Writing: Firmware Writing: Language Pack Writing: Flex Write Done Finished, time used: 333 sec Remove/Install battery now ! |
| | #7 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jan 2007 Location: @ planet EARTH
Member: 433173 Status: Offline Sonork: 100.1590587 Thanks: 15
| hi.. mate flash it with the latest version.. and ur problem solved!!! no need to try with any other boxes... infinity is the best and u dnt need to rely on ny other products regards recallrules |
| | #9 (permalink) |
| ok listen carefuly go to support are take this flex FLEX_90_64_4601 flash with this flex you phone will become alive don't wory about restarting..... then try to unlock with motorola.... post results............ Last edited by Formingus; 09-10-2007 at 17:44. Reason: ok |
| | #11 (permalink) | |
| Quote: Three month ago not all models of c261 supported so i stuck in this way... SO the solution was that. Restarting wbr Formingus | |
| | #14 (permalink) |
| I downloaded 1.42 moto01 updates from support, now it is very easy to unlock. I successfully unlocked it. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| how can I unlock motorola V975? | c.m.g | Motorola Hardware Repair Section | 7 | 06-01-2007 20:23 |
| please how can i unlock my Motorola 104!! | Wesleyraff | P2k Series | 1 | 08-23-2006 09:46 |
| HOW CAN I UNLOCK MY MOTOROLA IDEN i850 NEXTEL? | LOMAWITT | Phone Unlocking Codes & Maps | 2 | 02-22-2006 10:06 |
| how can i unlock my motorola A830 | nobal1976 | P2k Series | 0 | 11-22-2004 09:58 |
| how can i unlock motorola c-350 | lorcand | P2k Series | 2 | 05-08-2003 16:04 |
