04-21-2009, 18:03 | #1 (permalink) |
Registered User Join Date: Jun 2006 Location: Jamaica
Member: 292907 Status: Offline Sonork: None Thanks Meter: 51 | Motorola C261 restart problem COM5 selected Action: format Device: C261 Checking data, wait... Connect... Press and HOLD Power button... rom version: 0411 Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 460800 Set Baud Done Check Flash-1... SW version: 0.1.31 HW version: MOTOROLA_E58S LP ver: LPA3_0132 Flex ver: FLEX_90_64_3903 cpu id: 08B6 Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration __20090421-115506.34E.bin Check Flash-2 Done Write... unexpected answer: 54 Write Done Finished, time used: 117 sec Remove/Install battery now ! What other way is there to fix this. i even try writing the backed up eeprom, but still the same thing. Help. |
The Following User Says Thank You to curtisbcm For This Useful Post: |
04-21-2009, 18:14 | #2 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Amoude-syria Age: 49
Member: 98928 Status: Offline Thanks Meter: 463 | Write... unexpected answer: 54 Write Done her is your problem! try to flash your phone full flash and try unlock after it good luck |
The Following User Says Thank You to bavesore For This Useful Post: |
04-21-2009, 19:40 | #6 (permalink) | |
Member: 292907 Status: Offline Sonork: None Thanks Meter: 51 | Quote:
COM5 selected Action: unlock Device: C261 Checking data, wait... Connect... Press and HOLD Power button... rom version: 0411 Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 460800 Set Baud Done Check Flash-1... SW version: 0.1.76 HW version: MOTOROLA_E58S LP ver: LPNA_0176 Flex ver: FLEX_90_64_3903 cpu id: 08B6 Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration __20090421-133757.34E.bin unlock step-1 Ok unlock step-2 Ok unlock step-3 Ok unlock step-4 Ok error: unlock step-5.1 failed: A410 error: errorcode#10: can't find required data, eeprom damaged Finished, time used: 36 sec Remove/Install battery now ! Is there a next way to try. | |
04-23-2009, 00:41 | #9 (permalink) |
No Life Poster Join Date: Sep 2007 Location: In front of my pc
Member: 586318 Status: Offline Thanks Meter: 112 | Dear friend, I spent more than one month trying to fix this problem and the only way I could solve it was using the eeprom repair option with the smart moto software from smart clip. Do not waste your time, look for someone who own smart clip and get your phone fixed. PD. Writing the original eeprom does not work. I tried all those steps, BR FROM NICARAGUA. |
The Following User Says Thank You to tavoonly For This Useful Post: |
04-23-2009, 01:03 | #10 (permalink) |
Freak Poster Join Date: Aug 2007
Member: 560185 Status: Offline Thanks Meter: 101 | sir is the supply of the unit good? are you just using battery or regulated power supply? cause if your only using battery maybe the supply is nit enough... if the supply is good, then try to repair eeprom using smart clip via infinity interface.. b.r |
The Following User Says Thank You to amats211 For This Useful Post: |
04-24-2009, 16:50 | #13 (permalink) |
Member: 292907 Status: Offline Sonork: None Thanks Meter: 51 | Here is log: COM5 selected "smart write" active Action: flash Skip: Firmware Skip: Language Pack Skip: Flex Write: Eeprom Device: C261 Checking data, wait... Connect... Press and HOLD Power button... rom version: 0411 Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 460800 Set Baud Done Check Flash-1... SW version: 0.1.32 HW version: MOTOROLA_E58S LP ver: LP12_0132 Flex ver: C 73'DAF n cpu id: 08B6 Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration __20090424-093808.34E.bin Check Flash-2 Done Write... Writing: Eeprom eeprom write address adjusted Write Done Finished, time used: 31 sec Remove/Install battery now ! COM5 selected Action: format Device: C261 Checking data, wait... Connect... Press and HOLD Power button... rom version: 0411 Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 460800 Set Baud Done Check Flash-1... SW version: 0.1.32 HW version: MOTOROLA_E58S LP ver: LP12_0132 Flex ver: C 73'DAF n cpu id: 08B6 Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration __20090424-094102.34E.bin Check Flash-2 Done Write... Write Done Finished, time used: 89 sec Remove/Install battery now ! As you can see I did exactly what you instructed me to do, now all I see on phone screen for the passed hour is this message: 'FMGR_Waiting for Total Completion MMI' What next should I do? Thank you. |
04-24-2009, 19:45 | #14 (permalink) |
Freak Poster Join Date: Apr 2008
Member: 744454 Status: Offline Sonork: shakil Thanks Meter: 26 | I did lots of c261 of this problem just by formatting no need to flash full or eeprom. this happens because mostly many people use camera to capture photos and this phone has inbulid memory area which goes full with no space or little space so it restarts. |
04-24-2009, 20:04 | #15 (permalink) |
No Life Poster Join Date: Feb 2007 Location: philippines
Member: 448980 Status: Offline Thanks Meter: 136 | Hi! I've been encountered that problem few weeks ago after unlocked. and I fix it using infinity box by fullflash with firmwares 0.1.69 then format ffs again after flash, but be sure your battery is full while flashing or use power supply adapter. BR, PS_tech |
c261 restart problem | matrix1 | Motorola ODM | 13 | 07-24-2007 20:05 |
motorola c261 restart | sanjeewa57 | Infinity-Box | 7 | 03-15-2007 20:11 |
motorola c261 restart problem . | evil.zone | Infinity-Box | 1 | 01-19-2007 12:35 |
i have 1 pieces motorola c261 restart problem | aurelmarius1 | Infinity-Box | 2 | 08-28-2006 14:30 |
C261 restart problem.. please help.. | dlanor0221 | Infinity-Box | 0 | 06-18-2006 10:33 |
