(((((( motorola c261 sim not valid )))))) I flashed mot-c261 set with infinity box after flash its showing sim not valid. I tried different version but problem is still there plz help me what to do ??????? Thanks in advance z.k mob |
write eeprom file ya sp unlock try this ok dear Hariom |
did you try to sp unlock sir.....?? |
no solution for C168i At&T |
1. Start software 2. Select phone model 3. Go to "Flash" page 4. Press "Load Flex" button and select file: C261_Flex_90_62_3C01 5. Go to "Service" page 6. Press "Unlock" button -------------- IF TRACEFONE THEN CHECK DOCUMENTS C:\Program Files\InfinityBox\Documentation\Infinity-Box_How_to_unlock_Moto-C261_TracFone.htm |
The phone will be dead i am sure 100% ;) i have worked in this phone with All Box but No solution if u u want to unlock it with Log u will lost the signal |
You must use 1.0.32 firmware version for flashing but NOT 6.x.x !!! 6.x.x firmware is customized for American network operator ! @MDK23 Please, explain more detailed what you talk about. I can not understand your idea because C261 can be unlocked with Infinity-Box without any problems. |
COM5 [VCP0] selected Action: unlock Device: C261 Checking data, wait... Connect... Press and HOLD Power button... Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 460800 Set Baud Done Check Flash-1... SW version: 6.6.61 HW version: MOTOROLA_E58S LP ver: LPNA_6661 Flex ver: C 73'DAF n cpu id: 08B6 imei eeprom: 35860500525285 required SW version: 6.6.61 user confirmed unlock for non-locked phone Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Documents and Settings\ZK MOBILE\Desktop\C261 MOTOROLA\backup_eeprom_calibration_35860500525285_ 20081225-110304.34E.bin unlock step-1 Ok unlock step-2 Ok unlock step-3 Ok unlock step-4 Ok error: unlock step-5.1 failed: 5220 error: errorcode#20: can't find required data, eeprom damaged Finished, time used: 35 sec Remove/Install battery now Quote:
Flashed with this 1.0.32 version flash is ok and also unlock is okey but after flash there is no display on the phone ??????????????? Quote:
Hello, You can try to flash phone with 0.1.76 firmware/lp version. Are you sure that phone LCD is Ok ? |
Yes LCD is 100% okey cause when i flashed it with 6.6 version its showing all the things on lcd and give sim not valid and emergency call only Quote:
Hello, Any luck with 0.1.76 ? |
use this link , may be all will ok . tc http://forum.gsmhosting.com/vbb/show...261+insert+sim |
