Old 12-24-2008, 17:53   #1 (permalink)
zubairok's Avatar
Member: 294200
Sonork: 100.1586184
Thanks Meter: 648
(((((( motorola c261 sim not valid ))))))
I flashed mot-c261 set with infinity box after flash its showing sim not valid. I tried different version but problem is still there plz help me what to do ???????
Thanks in advance
z.k mob
Old 12-24-2008, 18:00   #2 (permalink)
Registered User
Member: 804452
Thanks Meter: 248
write eeprom file ya sp unlock try this ok dear
Hariom
Old 12-24-2008, 18:21   #3 (permalink)
Member: 619475
Thanks Meter: 63
did you try to sp unlock sir.....??
Old 12-24-2008, 18:41   #4 (permalink)
MDK23's Avatar
Member: 467636
Sonork: Double Kanon
Thanks Meter: 2,634
no solution for C168i At&T
Old 12-24-2008, 18:41   #5 (permalink)
TURNING POINT's Avatar
Member: 71721
Sonork: 100.106320
Thanks Meter: 139
1. Start software
2. Select phone model
3. Go to "Flash" page
4. Press "Load Flex" button and select file: C261_Flex_90_62_3C01
5. Go to "Service" page
6. Press "Unlock" button
IF TRACEFONE THEN CHECK DOCUMENTS C:\Program Files\InfinityBox\Documentation\Infinity-Box_How_to_unlock_Moto-C261_TracFone.htm
The Following User Says Thank You to TURNING POINT For This Useful Post:
Old 12-24-2008, 18:51   #6 (permalink)
MDK23's Avatar
Member: 467636
Thanks Meter: 2,634
The phone will be dead i am sure 100%
i have worked in this phone with All Box but No solution
if u u want to unlock it with Log u will lost the signal
Old 12-24-2008, 19:26   #7 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,296
Thanks in advance
z.k mob
Hello,
You must use 1.0.32 firmware version for flashing but NOT 6.x.x !!!
6.x.x firmware is customized for American network operator !
@MDK23
Please, explain more detailed what you talk about. I can not understand your idea because C261 can be unlocked with Infinity-Box without any problems.
Old 12-25-2008, 07:08   #8 (permalink)
zubairok's Avatar
Member: 294200
Sonork: 100.1586184
Thanks Meter: 648
COM5 [VCP0] selected
Action: unlock
Device: C261
Checking data, wait...
Connect...
Press and HOLD Power button...
Connecting...
initial boot phase complete
Release Power button !
Connect Done
Boot...
Boot Done
Set Baud...
460800
Set Baud Done
Check Flash-1...
SW version: 6.6.61
HW version: MOTOROLA_E58S
LP ver: LPNA_6661
Flex ver: C 73'DAF n
cpu id: 08B6
imei eeprom: 35860500525285
required SW version: 6.6.61
user confirmed unlock for non-locked phone
Check Flash-1 Done
Check Flash-2...
reading ...
file saved: C:\Documents and Settings\ZK MOBILE\Desktop\C261 MOTOROLA\backup_eeprom_calibration_35860500525285_ 20081225-110304.34E.bin
unlock step-1 Ok
unlock step-2 Ok
unlock step-3 Ok
unlock step-4 Ok
error: unlock step-5.1 failed: 5220
error: errorcode#20: can't find required data, eeprom damaged
Finished, time used: 35 sec
Remove/Install battery now
Originally Posted by InfinitySupport View Post
Hello,
@MDK23
Old 12-25-2008, 07:55   #9 (permalink)
zubairok's Avatar
Member: 294200
Sonork: 100.1586184
Thanks Meter: 648
Flashed with this 1.0.32 version flash is ok and also unlock is okey but after flash there is no display on the phone ???????????????
Hello,
@MDK23
Old 12-25-2008, 16:50   #10 (permalink)
Member: 130995
Hello,
You can try to flash phone with 0.1.76 firmware/lp version.
Are you sure that phone LCD is Ok ?
Old 12-25-2008, 19:19   #11 (permalink)
zubairok's Avatar
Member: 294200
Sonork: 100.1586184
Thanks Meter: 648
Yes LCD is 100% okey cause when i flashed it with 6.6 version its showing all the things on lcd and give sim not valid and emergency call only
Hello,
Old 12-25-2008, 19:27   #12 (permalink)
Member: 130995
Hello,
Any luck with 0.1.76 ?
Old 03-14-2009, 08:48   #13 (permalink)
jagdish puri's Avatar
Member: 573120
Thanks Meter: 145
use this link , may be all will ok . tc
Moto-C261 Insert SIM card
The Following User Says Thank You to jagdish puri For This Useful Post:
Motorola c261 Sim Not valid after flashing with Infinity-Box gsm_surya Infinity-Box 7 02-08-2011 22:33
Moto C261 Sim not Valid eko_java_cell Infinity-Box 6 05-28-2008 06:52
c261 sim not valid faizan15 Infinity-Box 8 03-17-2008 21:24
c261 sim not valid solution ..::GsmEasy::.. Smart-Clip 4 10-09-2007 21:11
C261 sim not Valid after unlock (Tracfone) S/C hakeemtucker Smart-Clip 8 07-21-2007 10:24
Page generated in 0.40046 seconds with 8 queries
