Old 02-25-2011, 21:52   #1 (permalink)
carlos32's Avatar
Member: 1166261
Sonork: 100.1623881
Thanks Meter: 266
Question motorola v171 unlock fail...
==== log opened: [25-02-2011 20:10:42] ====
Application: C:\Users\Desktop\InfinityBox\Moto01\Moto01.exe
Loading data, wait...
[Infinity Box] v1.48
S/N: xxxx:xxxx
Current model: C113(a),C114,C115,C116,C117,C118
Ready
COM28 [Root#PORTS#0000#{86e0d1e0-8089-11d0-9ce4-08003e301f73}] selected
Action: unlock
Device: C113(a),C114,C115,C116,C117,C118
Checking data, wait...
Connect...
Press and HOLD Power button...
connection mode: 00
error: boot failure[02]:
Release Power button !
Connect Fail
Failed !
Finished, time used: 12 sec
Remove/Install battery now !
Action: unlock
Connect...
connection mode: 00
Connect Fail
Failed !
Finished, time used: 99 sec
Action: read code
Connect...
connection mode: 00
Connect Fail
Failed !
Finished, time used: 35 sec
Action: unlock
Connect...
connection mode: 00
Connect Fail
Failed !
Finished, time used: 28 sec
Action: unlock
Connect...
connection mode: 00
Connect Fail
Failed !
Finished, time used: 39 sec
COM29 ready
COM29 [Root#PORTS#0001#{86e0d1e0-8089-11d0-9ce4-08003e301f73}] selected
Action: unlock
Connect...
connection mode: 00
Connect Fail
Failed !
Finished, time used: 26 sec
COM8 ready
COM8 [0000006e] selected
Action: unlock
Connect...
connection mode: 00
Connect Fail
Failed !
Finished, time used: 48 sec
==== log opened: [25-02-2011 20:30:16] ====
S/N: xxxx:xxxxx
Ready
==== log opened: [25-02-2011 20:31:24] ====
S/N: xxxx:xxxx
Ready
error: can't open COM4
COM28 ready
Action: unlock
Connect...
connection mode: 00
Connect Fail
Failed !
Finished, time used: 169 sec
Action: unlock
Connect...
connection mode: 00
Connect Fail
Failed !
Finished, time used: 41 sec
Action: unlock
Connect...
connection mode: 00
Connect Fail
Failed !
Finished, time used: 21 sec
Action: unlock
Connect...
connection mode: 00
Connect Fail
Failed !
Finished, time used: 76 sec
Action: format
Connect...
connection mode: 00
Connect Fail
Failed !
Finished, time used: 19 sec
Action: read code
Connect...
connection mode: 00
cables use is:
motorola 191
LG G1800
panasonic x60
what code by problem?????????????'
Old 02-25-2011, 22:06   #2 (permalink)
Member: 1043909
Thanks Meter: 60,909
Dear Friend,
Please, select correct VCP COM port and correct model name !
Old 02-25-2011, 22:17   #3 (permalink)
carlos32's Avatar
Member: 1166261
Sonork: 100.1623881
Thanks Meter: 266
wen y select 4 com vcp come windo and say ( COM 4 NOT AVAILBLE))...heven so y select but no result
COM4 [VCP0] selected
Action: unlock
Device: V170,V171,V172,V173
Connect...
connection mode: 00
error: boot failure[02]: 00
Connect Fail
Failed !
Finished, time used: 103 sec
Old 02-25-2011, 22:18   #4 (permalink)
Member: 1043909
What is phone firmware version ?
#02# w/o sim card
Old 02-25-2011, 22:39   #5 (permalink)
carlos32's Avatar
Member: 1166261
Sonork: 100.1623881
Thanks Meter: 266
it say
001C4458
513207869463
Who:sw_cm
Time: mon feb 21:02:33 2005
sw ver:4.4.58...
Customer:
Motorola
FLASH: N/A
Version info.
CODE.90.01
BOOT.90.05
FMGR.90.63
FLEX_90_61_3D03
LangPack:
LP3_V171_4458
Chip Ver X
DOM:200503230320
DOM2:200503240320
DOM3:200504260544
TFT: 686D 3H50m
FBI:0
W_Dogn
DSC:flex OFF
P117693897
Old 02-25-2011, 23:00   #6 (permalink)
Member: 1043909
It should be no problem with this firmware, try to repeat unlock process several times.
Also, try to adjust port settings:
The Following User Says Thank You to YellowBoss For This Useful Post:
Old 02-25-2011, 23:16   #7 (permalink)
carlos32's Avatar
Member: 1166261
Sonork: 100.1623881
Thanks Meter: 266
Y try now then post here result
Old 02-25-2011, 23:33   #8 (permalink)
carlos32's Avatar
Member: 1166261
Sonork: 100.1623881
Thanks Meter: 266
SUCCESS.....
CABLEanasonic x60
here´s log:
Action: unlock
Connect...
connection mode: 00
Connect Done
Boot...
Boot Done
Set Baud...
115200
Set Baud Done
Check Flash-1...
SW version: 4.4.58..
HW version: MOTOROLA_C071
Flex ver: FLEX_90_61_3D03
Check Flash-1 Done
Check Flash-2...
reading ...
file saved: C:\Users\Desktop\InfinityBox\Moto01\backup_eeprom_ calibration__20110225-223057.20E.bin
Check Flash-2 Done
Write...
Write Done
Finished, time used: 44 sec
The Following User Says Thank You to carlos32 For This Useful Post:
Old 01-29-2016, 01:35   #9 (permalink)
yocomic's Avatar
Member: 1948841
Sonork: yocomic
Thanks Meter: 45
this is log but no susses
COM70 [VCP0] selected
Action: unlock
Connect...
connection mode: 00
Connect Done
Boot...
Boot Done
Set Baud...
115200
Set Baud Done
Check Flash-1...
SW version: 7.5.63..
Flex ver: FLEX_90_61_1106
Check Flash-1 Done
Check Flash-2...
reading ...
file saved: C:\InfinityBox\Moto01\backup_eeprom_calibration__2 0160128-183257.20E.bin
Check Flash-2 Done
Write...
Write Done
after operation the devices show masager
emergency only
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
$50 Reward for unlocking my 6150!!! TheDon Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 03-23-2015 14:21
FAQ about unlock n0kia man0n Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:06
Page generated in 0.27607 seconds with 9 queries
