01-12-2006, 04:01 | #1 (permalink) |
No Life Poster Join Date: Jul 2003
Member: 33804 Status: Offline Thanks Meter: 22 | X300: [Err: Imei not found or damaged!!!!] I received one piece X300 with imei problem.I 've tried to reflash with few flash/flex/map then repair imei with no luck(in some newest firmware version software says changing imei done but really doesn't) . Here is the log: Code: COM6 selected Device: X300 Checking data, wait... Action: IMEI repair Boot... Press Power button now ! Connecting, wait... Boot Done Parameters... Parameters Done Check Boot block... Check Boot block Done Check space... Check space Done Check Flash-1... FLASH[410702]: 98:0074 Check Flash-1 Done Check Flash-2... Check Flash-2 Done Check Flash-3... Err: Imei not found or damaged Check Flash-3 Fail Finished Remove/Install battery now ! Time used: 29 sec So I guess I must have a good eeprom file to repair this one.Am I right? If yes,where can I get this good eeprom file? If no,do you have any solution for me? Thanks in advance and hope will get your answer a.s.a.p. B/r |
01-12-2006, 16:46 | #4 (permalink) |
Member: 33804 Status: Offline Thanks Meter: 22 | Hi again! I'm so sure phone hardware is 100% in state of original. Second,customer(he is a mobile repairer also) had flashed this phone with UFO tool(not so sure coz that's all of the information I've got from him ;-) ) Anyways,now this phone was returned to his customer and I have received my money for repairing network problem:-) And I hope it can't be changing Imei coz it has hardware problem. Thanks for your customer care and just keep it up! B/r |
Bootkey was not found or invalid. always Error | powerplay83 | DreamBox | 7 | 02-17-2009 18:31 |
CRYPTO-BOX not found or contains not valid data | Dayratel | NSPRO | 2 | 05-11-2006 13:09 |
Repairing redbox with key not found or sn error | ::.::HITGSM::.:: | Redbox | 1 | 10-31-2005 07:27 |
