07-20-2009, 23:00 | #1 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | 21 Jul 2009: Huawei-T202, Alcatel-S121 models supported .Huawei-T202 model supported .Alcatel-S121 model supported Flash files for T202 will be uploaded in support area in 1-2 days. Please, post here T202 unlock test reports due to software was tested with limited number of phones. Please, if you have on hands other locked Huawei phones (f.e. T202C,T520,T521,T565), contact to [email protected] so we will be able to make support for these models. T202 pinout: |
The Following 65 Users Say Thank You to InfinitySupport For This Useful Post: |
07-20-2009, 23:19 | #2 (permalink) |
Freak Poster Join Date: Jan 2006 Location: colombia Age: 45
Member: 220008 Status: Offline Thanks Meter: 95 | buebo thanks for this new update is very good and told her what my hands ake a t521, t565 and a g2200 huewei so I will try this version to see if I can read the flash and EPROM in order to send greetings |
The Following User Says Thank You to quimera For This Useful Post: |
07-21-2009, 00:04 | #3 (permalink) |
Member: 220008 Status: Offline Thanks Meter: 95 | backup of Huawei t521 which I did with the new update 1.35 and I read it as a model T202 I backup fullflash, EPROM, firmware and flex so that they can endure to unlock this model because you do attempt to unlock this model and can not I went to do this in the process http://rapidshare.com/files/25812705..._venezuela.rar COM8 [VCP0] selected module v1.35 Device: Huawei-T202 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... Boot done Check connection ... Check connection done Set baud ... 203125 Set baud done Check hardware ... flash: 012C7E2C352C00:9FEA0000000000 flash: AMD/Fujitsu std [T 007Fx020000 0004x008000] 16Mb Check hardware done Read data ... reading Huawei-T202_eeprom_calibration-1... file saved: C:\Archivos de programa\InfinityBox\HModule\Huawei-T202_eeprom_calibration-1_20090720-174610.80E.bin Read data done Check data ... Check data done Write ... ............ ............ error: unknown structure, read flash and send to support ! Write fail error: operation failed Finished, time used: 52 sec Remove/Install battery now ! |
The Following 7 Users Say Thank You to quimera For This Useful Post: |
07-21-2009, 00:19 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @quimera Thanks for test ! As I can see from log, T521 has bigger flash chip than T202 so we need to modify software to read T521 correctly. If you can keep phone with you for 1-2 days, please, wait new software. If you do not have enough time, please, try to read full flash like "Calypso 16m" model in "HModule". Please, send me full flash (or any other report about results) to [email protected] Also, what pinout you have used for T521 ? |
The Following 2 Users Say Thank You to InfinitySupport For This Useful Post: |
07-21-2009, 01:39 | #6 (permalink) |
Member: 220008 Status: Offline Thanks Meter: 95 | I could do the backup but locosto 16m and the other I will leave here Salia failed backup and transaction log http://rapidshare.com/files/25815139...costo_16mb.rar ==== log: [20/07/2009 19:01:20] ==== COM8 [VCP0] selected module v1.35 Device: Calypso 16m "advanced chip detection" active Action: read full flash Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... Boot fail error: operation failed Finished, time used: 7 sec Remove/Install battery now ! ==== log: [20/07/2009 19:01:52] ==== COM8 [VCP0] selected module v1.35 Device: Calypso 16m "advanced chip detection" active Action: read full flash Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... Boot fail error: operation failed Finished, time used: 6 sec Remove/Install battery now ! Device: Locosto 16m ==== log: [20/07/2009 19:02:21] ==== COM8 [VCP0] selected module v1.35 Device: Locosto 16m "advanced chip detection" active Action: read full flash Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 012C7E2C352C00:9FEA0000000000 flash: AMD/Fujitsu std [T 007Fx020000 0004x008000] 16Mb Check hardware done Read data ... reading Locosto 16m_flash_part_1_of_1... file saved: C:\Archivos de programa\InfinityBox\HModule\Locosto 16m_flash_part_1_of_1_20090720-190249.80X.bin Finished, time used: 25 sec Remove/Install battery now ! ==== log: [20/07/2009 19:03:03] ==== COM8 [VCP0] selected module v1.35 Device: Locosto 16m "advanced chip detection" active Action: read full flash Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... Boot done Check connection ... Check connection done Set baud ... 203125 Set baud done Check hardware ... flash: 012C7E2C352C00:9FEA0000000000 flash: AMD/Fujitsu std [T 007Fx020000 0004x008000] 16Mb Check hardware done Read data ... reading Locosto 16m_flash_part_1_of_1... file saved: C:\Archivos de programa\InfinityBox\HModule\t521 v2\Locosto 16m_flash_part_1_of_1_20090720-191955.80X.bin Finished, time used: 1488 sec Remove/Install battery now ! |
The Following 5 Users Say Thank You to quimera For This Useful Post: |
07-21-2009, 10:26 | #12 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Dar es Salaam TANZANIA
Member: 53263 Status: Offline Sonork: gsm master Thanks Meter: 326 | Huawei T202 test with T303 sony ericsson COM3 [VCP0] selected module v1.32 Device: Sony-Ericsson-T303 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 012A7E2A242A00:31EA0000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb software version: %!@i(qx software version: eH0! Check hardware done Read data ... reading Sony-Ericsson-T303_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-T303_eeprom_calibration-1_20090721-122335.80E.bin Read data done Check data ... Check data done Write ... .................................................. .............. .................................................. .............. error: unknown structure, read flash and send to support ! Write fail error: operation failed Finished, time used: 112 sec Remove/Install battery now ! |
07-21-2009, 10:43 | #15 (permalink) |
Member: 53263 Status: Offline Sonork: gsm master Thanks Meter: 326 | it is working fine and faster COM3 [VCP0] selected module v1.35 Device: Huawei-T202 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 012A7E2A242A00:31EA0000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... reading Huawei-T202_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Huawei-T202_eeprom_calibration-1_20090721-124517.80E.bin Read data done Check data ... Check data done Write ... ..... flash: 012A7E2A242A00:31EA0000000000 Write: simlock Write done Finished, time used: 81 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to MGT SOFTWARE For This Useful Post: |
23 Nov 2009: Huawei-T710, Bird-S230a models supported | InfinitySupport | Infinity-Box | 38 | 02-18-2011 14:22 |
Infinity Box : 21 Jul 2009: Huawei-T202, Alcatel-S121 models supported | Infinity-Box | Service Products News & Updates | 0 | 07-21-2009 16:11 |
13 Jul 2009: I-Mobile, Alcatel models supported | InfinitySupport | Infinity-Box | 0 | 07-17-2009 12:50 |
27 Jul 2008: Alcatel-S211 model supported | InfinitySupport | Infinity-Box | 20 | 08-03-2008 18:03 |
16 Jul 2008: Alcatel-S210 model supported, MyWay-MW200, UTStarcom-GPRS568 in test | InfinitySupport | Infinity-Box | 20 | 07-26-2008 11:17 |
