06-26-2009, 07:12 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: ***'S OWN COUNTRY;NIGERIA
Member: 268772 Status: Offline Thanks Meter: 102 | Motorola W220-Unlocking Can Somebody help me ;on how to unlock it with Infinity ? l had unlocked this model before but this gives error. |
The Following User Says Thank You to pastorsam For This Useful Post: |
06-26-2009, 17:00 | #5 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Quote:
what is the problem exactly ? | |
06-27-2009, 12:19 | #6 (permalink) |
Member: 268772 Status: Offline Thanks Meter: 102 | Motorola w220 unlocking Problem Here are the errors and logs : Infinity Team pls help me to provide the solution... COM3 [VCP0] selected module v1.30 Device: Motorola-W220 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection ... Check connection done Set baud ... 812500 Set baud done Check hardware ... flash: 208810FFFFFFFF:20881000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb software version: 1270-000 software version: SCY-7- Check hardware done Read data ... reading Motorola-W220_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Motorola-W220_eeprom_calibration-1_20090627-040919.6AE.bin Read data done Check data ... error: not locked or unknown eeprom Check data done Write ... .error: required data not found or unknown eeprom structure Write fail error: operation failed Finished, time used: 13 sec Remove/Install battery now ! |
06-27-2009, 14:42 | #7 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: india
Member: 618404 Status: Offline Thanks Meter: 311 | Quote:
The Following User Says Thank You to rajesh_ch For This Useful Post: |
06-27-2009, 15:25 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | you must flash phone with repair eeprom file and thn make "repair" operation. |
motorola w220 unlock | $unil1989 | Infinity-Box | 22 | 04-06-2011 07:30 |
motorola w220 unlock | shockboy | Motorola ODM | 78 | 03-26-2010 16:46 |
Motorola W220 Unlock Using UFS3 ?? | klantech | UFS2 + UFS3-Tornadoflasher | 5 | 05-01-2007 06:03 |
Motorola W220 unlocking problem | vali.rusu | Infinity-Box | 2 | 12-29-2006 16:06 |
motorola w220 unlock | $unil1989 | Smart-Clip | 3 | 12-23-2006 14:47 |
