07-14-2008, 04:19 | #1 (permalink) |
Insane Poster Join Date: Dec 2007 Location: santiago city,philippines
Member: 655303 Status: Offline Thanks Meter: 117 | motorola w375 direct unlock by infinity Action: unlock Device: W375 Checking data, wait... Connect... Press and HOLD Power button... Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 0.0.72 HW version: MOTOROLA_H80S LP ver: 0072_017 Flex ver: FLEX_BU_003 cpu id: 08B6 imei eeprom: 35583801149280 required SW version: 0.0.72 sp-locked: 27202. Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration _35583801149280_20080711-231622.34E.bin unlock step-1 Ok unlock step-2 Ok unlock step-3 Ok unlock step-4 Ok unlock step-5 Ok finished Ok Finished, time used: 38 sec Remove/Install battery now ! |
The Following User Says Thank You to megatech10 For This Useful Post: |
07-14-2008, 13:03 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
07-19-2008, 16:27 | #3 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | COM13 [Serial2] selected Action: unlock Device: W375 Checking data, wait... Connect... Press and HOLD Power button... rom version: 0411 Connecting... rom code version: 0411 initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 0.0.64 HW version: MOTOROLA_H80S LP ver: 0064_A07 Flex ver: FLEX_AA_005 cpu id: 08B6 imei eeprom: 3532970128723706 required SW version: 0.0.64 sp-locked: 50502. Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration _35329701287237_20080719-205638.34E.bin unlock step-1 Ok unlock step-2 Ok unlock step-3 Ok unlock step-4 Ok unlock step-5 Ok finished Ok Finished, time used: 39 sec Remove/Install battery now ! |
The Following User Says Thank You to sahil2000ind For This Useful Post: |
motorola I776 can unlock by infinity? | MUTUAL | Infinity-Box | 1 | 02-09-2010 12:39 |
Motorola W376g can't unlock by Infinity | Unicom | Infinity-Box | 2 | 12-23-2008 08:33 |
w375 unlock by infinity | ashok2 | Infinity-Box | 8 | 06-21-2007 21:42 |
w375 unlock by infinity ... post results here.. | ZIYAAD STRYKER | Infinity-Box | 2 | 05-13-2007 19:46 |
