01-23-2010, 06:54 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Location: raigarh india Age: 51
Member: 108186 Status: Offline Thanks Meter: 241 | write imei failed inside firmwere ==== log: [1/23/2010 11:04:02 AM] ==== COM3 [VCP0] selected module v3.07 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "repair imei" imei write channel: imei #1 (default imei inside firmware) new imei: 357263025428577 ====> Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:A62C:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info ver: 05 sw version: QING_S07_PCB01_GPRS_MT6223P_S00.QING-S07_MICROMAX_L1EN_206_090107_CAM010_MCP128+32_BT_F M.BIN project-id: QING-S07_MICROMAX_L1EN_206_090107_CAM010_MCP128+32_BT_F M, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: EC257E25082501:2BEA0000000000 Backup required data Done ====> Patch required data ... detecting ffs/eeprom structure pass 2... ......................... detect standard ffs/eeprom location pass #1... .................................................. ...... detect extended ffs/eeprom location pass #1... ................................... detect standard ffs/eeprom offset pass #1... ffs/eeprom record offset detected detect standard ffs/eeprom data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok element #2 imei default found: 13579024681122 Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: EC257E25082501:2BEA0000000000 flash: EC257E25082501:2BEA0000000000 Write: imei error: error# 000000FF error: flash write error: 00640000:00002000 error: no any expected answer error: flash write error: 00640000:00002000 error: can't write required area |
01-26-2010, 06:43 | #8 (permalink) |
Member: 108186 Status: Offline Thanks Meter: 241 | my pin finder give me trouble some time give me message pin finder not found but i remove the usb cable from infinity box and put again than find but when search command again show pinfinder not found |
01-29-2010, 18:34 | #10 (permalink) |
Member: 108186 Status: Offline Thanks Meter: 241 | i download driver from infinity support site and try to giving new driver many many times to spiderman through device manager but not successsed . please give me correct method to give new driver |
01-29-2010, 20:21 | #11 (permalink) | |
we do not provide any kind of support for spider box. if you have a problem with spider box installation, pls, ask help from Spider supporters. If you have a problem with PinFinder, pls explain the problem in details due to I can not understand well what is the problem now. | |
8310 cannot write imei..... | kickthepenguin | BlackBerry (RIM) | 20 | 03-21-2011 13:34 |
Failed to write imei..????? | sky_finder | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-30-2010 15:45 |
6230 write imei failed | beega | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 08-26-2006 12:12 |
D500 solution for write imei failed | imo | TST Dongle | 0 | 12-16-2005 15:18 |
2100 write imei failed | hyper_wamir | Nokia Hardware & Hardware Repair | 5 | 11-18-2003 03:19 |
