Old 01-28-2010, 16:37   #1 (permalink)
Burebista's Avatar
Member: 235325
Sonork: 100.1593552
Thanks Meter: 521
Motorola WX395 it's possible to be unlocked?!?
I've got this phone that's locked on Orange Romania and isn't supported by infinity.
This phone it's aproximatly like alcatel ot600:
http://www.gsmarena.com/compare.php3...&idPhone2=3062
and I read info's,eeprom area and fullflash from it by conecting it like alc ot600 to pc.
I post here the log from it and I wanna know if will be any chance to support it in the next updates and if the files readed from the phone I must send them to support area or is enough only this log:
COM3 [VCP3] selected
module  v3.04
Device: Alcatel-600
Checking data, wait...
Action: read/check information
====>  Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
chip: 0001:DB03:A003
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
====>  Initialize ...
flash: EC240200000000:08EA0000000000
flash: Samsung K5L2833ATA T 16Mb
Initialize Done
====>  Set baud ...
115200
Set baud Done
====>  Initialize bootcode ...
Initialize bootcode Done
====>  Check firmware integrity ...
usb bootloader detect...
usb bootloader (chip) is present: 00010000
searching rom info...
search rom info finished
rom info structure: 2nd [enhanced] generation
TCL-ID is present
startup code area #1 is damaged, recalculation required
rom info detection finished
TCL-ID detection...
TCL-ID detection done
device-id: 8B480BFE
rom info ver: 05
sw version: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP1_V38.BIN
project-id: MAUI.06B.W07.28.SP1.V38, AC55EAAD
code offset: 00010000
ffs offset/size [01]: 00C00000/00400000
TCL-ID identification
version: 27G
provider: M395X-2BRGRO1
customization: CJ27YP72
customization: XJ27YP72
TCL-ID identification done
TCL-ID is present
ffs/eeprom address assigned: 00C00000
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
product id: JRD_COMMUNICATION_B82X_PRODUCTS
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
searching sec info#2...
search sec info#2 finished
sim-lock status: enabled
area1 is valid
area2 is valid
area3 is valid
area4 is invalid
searching sec info#3...
search sec info#3 finished
area1 is valid
area2 is valid
area3 is valid
area4 is valid
number of sec info areas: 3
detecting firmware version...
firmware version: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP1_V38.BIN
detecting firmware build...
firmware build: $%&'()*MAUI.06B.W07.28.SP1.V38JRD25_06B_HW2009-10-2722-31
detecting product-id...
product-id: B82X
detecting languages...
language parameters detected
detected languages: En Gr Ro Shqip Bg
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
area1 is valid
area2 is valid
area3 is valid
area4 is invalid
area1 is valid
area2 is valid
area3 is valid
area4 is valid
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-600_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP1_V38__system_log_8B480BFE_ADEA55AC_20100128-165130.B0X.bin
Finished, time used: 3 min 32 sec
Remove/Install battery now !
I hope this are helpfull info's!
Old 01-28-2010, 17:23   #2 (permalink)
Member: 1043909
Thanks Meter: 51,302
Hi,
we need to get full flash backup to check how to make it supported.
pls send files or link to [email protected]
Old 01-28-2010, 17:45   #3 (permalink)
Burebista's Avatar
Member: 235325
Sonork: 100.1593552
Thanks Meter: 521
Done,fullflash backup also backup eeprom I sent them to mail suport.
Regards!
The Following User Says Thank You to Burebista For This Useful Post:
Old 01-28-2010, 21:25   #4 (permalink)
Member: 1043909
Hello,
Please, try to use this new software:
http://www.infinity-box.com/download...e_v3.05_v1.rar
1. make full flash backup once again for emergency case
2. try to make "sp-unlock"
Waiting for your results.
The Following User Says Thank You to YellowBoss For This Useful Post:
Old 01-29-2010, 14:22   #5 (permalink)
Member: 155639
Thanks Meter: 8
I have also a phone like this, unlock with new soft, all is ok
The Following User Says Thank You to istism2003 For This Useful Post:
Old 01-29-2010, 16:53   #6 (permalink)
Burebista's Avatar
Member: 235325
Sonork: 100.1593552
Thanks Meter: 521
Sorry for the delay to answer but I've got something to solve;
This version it's working 100%.
Still I'm receiving message with unknown cpu/firmware but I read again fullflash and sent it to suport area.
module  v3.05
Device: Motorola-WX395
Action: rebuild security area
====>  Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
status: 01
Boot Done
otp offset: 00FF0000
Initialize Done
====>  Set baud ...
460800
Set baud Done
TCL-ID is present
TCL-ID detection...
device-id: 8B480BFE
rom info ver: 05
version: 27G
TCL-ID is present
startup code area #1 check...
rpl file not found: C:\Program Files\InfinityBox\MModule\id.8B480BFE.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP1_V38.BIN_ADEA55AC].rpl
rpl file not found: C:\Program Files\InfinityBox\MModule\id.8B480BFE._JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP1_V38.BIN_ADEA55AC_.rpl
rpl file not found: C:\Program Files\InfinityBox\MModule\backup_security\id.8B480BFE.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP1_V38.BIN_ADEA55AC].rpl
rpl file not found: C:\Program Files\InfinityBox\MModule\backup_security\id.8B480BFE._JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP1_V38.BIN_ADEA55AC_.rpl
warning: unknown rom info structure: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP1_V38.BIN_ADEA55AC
Unknown firmware detected (v.3.05, database date: ), user action required:
1. download latest software from support area and try again
2. if no still luck follow the next procedure:
- find good working phone with the same firmware:
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
- be little bit patient and wait update
error: startup code area #1 can't be fixed
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
area1 is valid
area2 is valid
area3 is valid
area4 is invalid
area1 is valid
area2 is valid
area3 is valid
area4 is valid
security area (sec info, part #2) calculation...
error: security area (sec info, part #2) header is invalid
security area (sec info, part #1) calculation...
use default security area (sec info, part #1) pattern
max address is too big, should be recalculated: 08BF8000->00006F54
error: can not recalculate address range, allowed offset is too small: 00006F54
error: can't calculate security area (sec info, part #1)
identification header detected
customization name adjusted
Write: security area (sec info, part #2)
security area (sec info, part #2) calculation done
max address is too big, should be recalculated: 08BF8000->08BF4004
..................security area (sec info, part #1) detecting size...
security area (sec info, part #1) detecting parameters...
security area (sec info, part #1) encoding...
done
Write: security area (sec info, part #1)
security area (sec info, part #1) calculation done
done
Check firmware integrity Done
====>  Check firmware content ...
Check firmware content Done
====>  Backup required data ...
original imei: FFFFFFFFFFFFFF
Backup required data Done
====>  Patch required data ...
Patch required data Done
====>  Special operation ...
Special operation Done
====>  Write ...
Write Done
====>  Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Motorola-WX395_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP1_V38__system_log_8B480BFE_ADEA55AC_20100129-174739.B0X.bin
Finished, time used: 3 min 2 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Thanks a lot!
Old 01-29-2010, 18:36   #7 (permalink)
Member: 1043909
Please, read full flash from your phone and send full flash backup (or link) to [email protected]
Old 01-29-2010, 19:33   #8 (permalink)
Member: 1043909
@Burebista
please, if you can, keep phone with you some more time.
I hope to send you today updated software for flash reading so we will fix a problem with error message during unlock.
Old 01-29-2010, 20:13   #9 (permalink)
Member: 1043909
@Burebista
@istism2003
Please, try to use this new software: http://www.infinity-box.com/download...e_v3.05_v2.rar
Thank you !
Are it's possible to unlock LG U960 with FG? Zoosman FuriousGold 2 06-20-2008 00:56
it's possible to unlock lg u310 permament? tuli LG 3 03-18-2008 21:17
U Want To Localize Mobile Phone ? Now It's Possible But Be Carreful DEBLOQUETOUT Off Topic Zone 5 12-10-2006 17:12
Benq A500. Is it possible to be unlocked ? doctormike FuriouS II 0 08-18-2005 21:01
It's possible to unlock a ME45 CE20? partner44 x1x to x45/x50 5 08-28-2002 20:12
Page generated in 0.38926 seconds with 8 queries
