06-10-2016, 09:55 | #1 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Hatfield Harare Zimbabwe Age: 42
Member: 2377686 Status: Offline Sonork: 100.1668474 Thanks Meter: 315 | Movitel M8410 Network Locked but cant Unlock Help me Agent when trying to unlock it. Here is Info Log: Code: Operation : Check/Read Info [ v1.18 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 20 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 eMMC loader v1.1 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : P172D04 Model Brand : ZTE Model Device: P172D04 AndrVersion : 4.4.2 BaseBand CPU: SCX15_SP7715EA CompileDate : 3/7/2016 11:49:56 AM Project Ver : MOV_MZ_QB18D_P172D04V1.0.1 Model Ext : Movitel M8410 ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:18 Reconnect Power/Cable! Code: Operation : Read NV [ v1.18 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 20 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 eMMC loader v1.1 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! Detected eMMC Flash , Structure detect Ok! Read GSM NV Read WCN NV Read Ok , 0x00031D88 Saved to : C:\InfinityBox\CM2SPD\Flash\Movitel M8410\NVM\CX_SPDNV.spdnv Elapsed: 00:01:12 Reconnect Power/Cable! Code: Operation : Read FullFlash [ v1.18 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 20 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 eMMC loader v1.1 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Detected eMMC Flash , Structure detect Ok! [FW_READER] : Step #1 Passed! [FW_READER] : Step #2 Passed! [FW_READER] : Step #3 Passed! Phone found! [ 20 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 eMMC loader v1.1 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! Model Name : P172D04 Model Brand : ZTE Model Device: P172D04 AndrVersion : 4.4.2 BaseBand CPU: SCX15_SP7715EA Project Ver : MOV_MZ_QB18D_P172D04V1.0.1 Model Ext : Movitel M8410 [Read Mode] : HSUSB : 0x3000 [FW_READER] : Reading Firmware Now ... [Read Ok] : u-boot-spl-16k.bin [Read Ok] : u-boot.bin [Read Ok] : prodnv.img [Read Ok] : sc7715_modem.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : nvitem_w.bin [Read Ok] : CP2._CP2_WCN_14C_W15.34.2_Release.bin [Read Ok] : nvitem_wcn.bin [Read Ok] : logo_320x480.bin [Read Ok] : fblogo_320x480.bin [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : userdata.img AndroidInfo created Firmware Size : 1196 MiB Saved to : C:\InfinityBox\CM2SPD\Flash\Movitel M8410\Firmware Pac\SCX15_SP7715EA_P172D04_4.4.2_MOV_MZ_QB18D_P172D04V1.0.1_Movitel_M8410\ Done! Elapsed: 00:13:42 Reconnect Power/Cable! Code: Operation : SP Unlock [ v1.18 ] Mode : DirectUnlock 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 20 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 eMMC loader v1.1 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! Detected eMMC Flash , Structure detect Ok! Checking Structure ... SimLock state : Not Locked! Nothing to do! Elapsed: 00:00:20 Reconnect Power/Cable! https://mega.nz/#!5FABgDgZ Waiting For yr Support Response Thank you. |
06-10-2016, 11:19 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Do you try insert different SIM cards ( different ServiceProviders )? Also, when posting files with decryption keys - add keys as well in text. |
06-10-2016, 11:44 | #3 (permalink) | |
Member: 2377686 Status: Offline Sonork: 100.1668474 Thanks Meter: 315 | Quote:
https://mega.nz/#!5FABgDgZ!vGengw-_K...rmtRh4AKZ2Vros I tried its locked I think it needs patch file or open firmware | |
06-12-2016, 20:48 | #8 (permalink) |
Member: 2377686 Status: Offline Sonork: 100.1668474 Thanks Meter: 315 | Unlocking Done with Feed back Support Mobile now fully permanently network unlocked By ur Software CM2SPD you PM Here is logs with no Errors : Info : Code: Chinese Miracle II [SPD module] v 1.19 Operation : Check/Read Info [ v1.19 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 20 ] Open Port Failed! Reconnect Power/Cable! Operation : Check/Read Info [ v1.19 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 20 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 eMMC loader v1.1 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : P172D04 Model Brand : ZTE Model Device: P172D04 AndrVersion : 4.4.2 BaseBand CPU: SCX15_SP7715EA CompileDate : 3/7/2016 11:49:56 AM Project Ver : MOV_MZ_QB18D_P172D04V1.0.1 Model Ext : Movitel M8410 ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:20 Reconnect Power/Cable! Code: Operation : Read NV [ v1.19 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 20 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 eMMC loader v1.1 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! Detected eMMC Flash , Structure detect Ok! Read GSM NV Read WCN NV Read Ok , 0x00031D88 Saved to : F:\Temp Files\MOVITEL M8410\CX_SPDNV.spdnv Elapsed: 00:01:40 Reconnect Power/Cable! Code: Operation : SP Unlock [ v1.19 ] Mode : DirectUnlock 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 20 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 eMMC loader v1.1 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! Detected eMMC Flash , Structure detect Ok! Checking Structure ... SimLock state : Locked! Unlocking ... Unlock Done! Elapsed: 00:00:23 Reconnect Power/Cable! |
The Following 8 Users Say Thank You to johnmadzeka1 For This Useful Post: |
