10-09-2008, 04:25
#1 (permalink)
Member: 486305
Thanks Meter: 465 | Mp4 Mini China Phone Dead Done by Infinity!! Mp4 Mini China Phone Dead Done by Infinity!!
Problem;
Dead
Tool's
Inifnity
Rj45 Pinout's
Solution;
-Pinout's -Format Quote:
COM6 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: "format ffs"
Boot...
19200 fixed
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
high speed boot disabled
chip: 0031:FBC1:1AF6
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: 01227E22202200:29EA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
460800
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area#1 is Ok
security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.F9F563E4.[T6226_05C_PCB01_GPRS_MT6226_S01.D200_U2_SD_CLOSE_V 2_4_1.BIN_1C31DE33].rpl
New firmware detected:
- make "Read full flash" operation
- send "system_log_..." file to support: [email protected]
- send flash backup file(s) to support: [email protected]
- include in your e-mail full text from phone back label (phone name etc.)
identification#1 detection finished
device-id: F9F563E4
identification#1 protocol ver: 04
ver. sw1: T6226_05C_PCB01_GPRS_MT6226_S01.D200_U2_SD_CLOSE_V 2_4_1.BIN
ver. sw2: D200_U2_SD_CLOSE_V2.4.1, CC21CEE3
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading: eeprom[T6226_05C_PCB01_GPRS_MT6226_S01.D200_U2_SD_CLOSE_V 2_4_1.BIN]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[T6226_05C_PCB01_GPRS_MT6226_S01.D200_U2_SD_CLOSE_V 2_4_1.BIN]_20081007-134144.B0E.bin
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
Write Done
Finalization...
formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_F9F563E4_T6226_05C_PCB01_GPRS_MT6226_S01 .D200_U2_SD_CLOSE_V2_4_1.BIN_1C31DE33_20081007-134208.B0X.bin
Finished, time used: 341 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
| -Write Imei Quote:
Action: imei
Model: Autodetect 6205-6227 NOR
Phone should be Switched ON !
Connecting, wait...
Phone detected, wait...
Hardware version: MT6226, E02
Software version: D200_U2_SD_CLOSE_V2.
Software date: 2005.04.12
Barcode: MT012345678901234567
imei: 135790246811220
imei write method: mode-1
imei write channel: imei #1 for dual sim/mono-CPU
new imei: 352369004929520
imei verified Ok
Finished, time used: 9 sec
Power off phone now !
| Done; RG;
TSAMBAKOL TEAM |
