Old 08-02-2008, 06:45   #1 (permalink)
Member: 568700
Thanks Meter: 52
mpeg4-8283=3gnet help
COM4 [VCP1] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: write NOR flash
"smart write" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
Boot...
19200 fixed
Connecting, wait...
Initializing[6219:8B02:8B01]...
CPU: MT6219
high speed boot enabled
CPU: MT6226MA detected
chip: 0031:47DD:9A0E
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 89881200010001:89881200000000
flash: Intel Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
921600
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
Warning: probably flash chip empty, erased, incorrectly flashed or damaged.
What to do:
1. go to software "Settings" page
2. set "Advanced chip detection method" box UN-CHECKED !
3. make flash write operation
If still no luck: send mail to support ([email protected]) with detailed description of problem,
attach the next files in your e-mail:
1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log
2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_***x_***x.bin
it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset assigned: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
Can't detect eeprom/ffs area
Do you want to use standard ffs address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs address selected by user
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading [eeprom]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom_20080802-124040.B0E.bin
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
.damaged firmware
.damaged hardware
Area: Firmware
Write: Firmware
Write Done
Finalization...
Finalization Done
Finished, time used: 315 sec
Remove/Install battery now !
help me ...................
Old 08-02-2008, 07:52   #2 (permalink)
.::BHATTI::.'s Avatar
Member: 203158
Sonork: 100.1592032
Thanks Meter: 358
Looks like phone is completely erased by someone..............
Old 08-02-2008, 11:17   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
Yes, I agree with Mr. .::BHATTI::.
You must flash phone.
Old 08-02-2008, 11:22   #4 (permalink)
Member: 568700
Thanks Meter: 52
infinity support not firmware this brand/type brother!!!!!!!!
Infinity Team Have Firmware For Mpeg4 A960?????? Please Help torpedo_seluler Infinity-Box 6 06-03-2008 08:23
infinity team pls help mpeg4 p888 jbbasha Infinity-Box 1 03-27-2008 16:43
Need Help From Infinity For Mpeg4 Pinout sartaj Infinity-Box 3 02-19-2008 20:15
Mpeg4 k1 Infinity team need dire help ziasim Infinity-Box 1 09-04-2007 12:58
Please Help For My Pda Mpeg4 EASYTECH Infinity-Box 1 02-03-2007 20:58
Page generated in 0.23973 seconds with 10 queries
