10-12-2018, 17:14 | #1 (permalink) |
No Life Poster Join Date: Jul 2013 Location: Pakistan. Rahim Yar Khan
Member: 1977629 Status: Offline Thanks Meter: 429 | Mr Jaydi need ur help first set restart again and again then i follow these steps. in memory tool wipe user data and cache and after that wipe the set from recovery . then set is working well but when customer reboot the mobile problem again come . i proceed the following steps again but when reboot the mobile problem again back . i made the backup before so i decide to write user data and cache from its own backup to revert mobile to its previous state. so i write the user data and cache file with mtk2 r4 but mobile stuck on boot loop and after that i wipe data from memory tool and wipe from recovery then working but with same problem , if mobile reboot then its restart again and again. i have its own backup and i want to repair this mobile . plz kindly suggest me what i do to do this mobile? BR |
10-13-2018, 05:39 | #2 (permalink) |
Member: 1977629 Status: Offline Thanks Meter: 429 | here is the format log other logs are deleted due to new window instalation Card found : BC555F6F , v0137 Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.00 r4 Operation : Memory Tool Init [ v2.00 r4 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM8) MODE : BOOTROM PORT : 8 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+SEL BROM : BOOTROM MODE : Oppo : A3 | Manual : Disabled BROM : SLA BROM : SLA Passed! AGENT : Look for suitable BootChain in DA ... AGENT : DA_BR_HIGH.bin AGENT : Found MT6771 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0 EMI : CNT : 000E EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 90014A484347386134A24BB0F67DB49B EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HCG8a4 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 816CE45D3522D27422393F40BB6253D9 DA : USB : HIGH-SPEED Boot done! Set default path : C:\InfinityBox\CM2MT2\phdata\ Ready! Operation : Erase Memory [ v2.00 r4 ] Erase selected partitions [2] [0] Erase partition : CACHE Erase partition Ok! [1] Erase partition : USERDATA Erase partition Ok! Operation finished! |
10-19-2018, 15:52 | #5 (permalink) |
Member: 1977629 Status: Offline Thanks Meter: 429 | still waiting for team reply to fix this issue . download file form gsm hosting reded by cm2 and write on phone but problem not solve . have any chance to fix this Operation : Write Flash [ v2.00 r4 ] Repartition : Enabled Flash Verify : Disabled Pre-Erase : Enabled Verify HW/SW : Enabled XData Backup : Disabled Files :23 [FL] : Set : preloader_oppo6771_17331.bin [FL] : Set : preloader_oppo6771_17331.bin [FL] : Set : recovery.img [FL] : Set : md1rom.img [FL] : Set : spmfw.img [FL] : Set : tinysys-scp.bin [FL] : Set : tinysys-scp.bin [FL] : Set : tinysys-sspm.bin [FL] : Set : tinysys-sspm.bin [FL] : Set : cam_vpu1.img [FL] : Set : cam_vpu2.img [FL] : Set : cam_vpu3.img [FL] : Set : lk.bin [FL] : Set : lk.bin [FL] : Set : boot.img [FL] : Set : logo.bin [FL] : Set : odmdtbo.img [FL] : Set : tz.img [FL] : Set : tz.img [FL] : Set : odm.img [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0x118A9F6D0 [ 4.39 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM8) MODE : BOOTROM PORT : 8 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+SEL BROM : BOOTROM MODE : Oppo : F7 | Manual : Disabled BROM : SLA BROM : SLA Passed! AGENT : Look for suitable BootChain in DA ... AGENT : DA_BR_HIGH.bin AGENT : Found MT6771 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6752 EMI : SRC : preloader_oppo6771_17331.bin EMI : CNT : 000E EMI : [00] : eMCP : eMMC+LP/DDR4 , ID : 90014A484347386134 : VEN : HYNIX | DEV : HCG8a4 : RAM : [ 4.00 GB ] EMI : [01] : eMCP : eMMC+LP/DDR4 , ID : 150100444836444D42 : VEN : SAMSUNG | DEV : DH6DMB : RAM : [ 4.00 GB ] EMI : [02] : eMCP : eMMC+LP/DDR3 , ID : 90014A484247346132 : VEN : HYNIX | DEV : HBG4a2 : RAM : [ 3.00 GB ] EMI : [03] : eMCP : eMMC+LP/DDR3 , ID : 150100525836344D42 : VEN : SAMSUNG | DEV : RX64MB : RAM : [ 4.00 GB ] EMI : [04] : eMCP : eMMC+LP/DDR3 , ID : 150100524436344D42 : VEN : SAMSUNG | DEV : RD64MB : RAM : [ 4.00 GB ] EMI : [05] : eMCP : eMMC+LP/DDR4 , ID : 150100445636444D42 : VEN : SAMSUNG | DEV : DV6DMB : RAM : [ 4.00 GB ] EMI : [06] : eMCP : eMMC+LP/DDR4 , ID : 150100334836434D42 : VEN : SAMSUNG | DEV : 3H6CMB : RAM : [ 6.00 GB ] EMI : [07] : eMCP : eMMC+LP/DDR4 , ID : 150100335636434D42 : VEN : SAMSUNG | DEV : 3V6CMB : RAM : [ 6.00 GB ] EMI : [08] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344142 : VEN : SAMSUNG | DEV : RH64AB : RAM : [ 4.00 GB ] EMI : [09] : eMCP : eMMC+LP/DDR4 , ID : 150100444836444142 : VEN : SAMSUNG | DEV : DH6DAB : RAM : [ 4.00 GB ] EMI : [0A] : eMCP : eMMC+LP/DDR4 , ID : 90014A684445615033 : VEN : HYNIX | DEV : hDEaP3 : RAM : [ 6.00 GB ] EMI : [0B] : eMCP : eMMC+LP/DDR3 , ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3.00 GB ] EMI : [0C] : eMCP : eMMC+LP/DDR4 , ID : 13014E53304A394B39 : VEN : UNKNOWN | DEV : S0J9K9 : RAM : [ 4.00 GB ] EMI : [0D] : eMCP : eMMC+LP/DDR4 , ID : 13014E53304A394438 : VEN : UNKNOWN | DEV : S0J9D8 : RAM : [ 4.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 90014A484347386134A24BB0F67DB49B EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HCG8a4 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 816CE45D3522D27422393F40BB6253D9 DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER Write : PRELOADER_BACKUP Write : RECOVERY Write : MD1IMG Write : SPMFW Write : SCP1 Write : SCP2 Write : SSPM_1 Write : SSPM_2 Write : CAM_VPU1 Write : CAM_VPU2 Write : CAM_VPU3 Write : LK Write : LK2 Write : BOOT Write : LOGO Write : ODMDTBO Write : TEE1 Write : TEE2 Write : ODM Write : SYSTEM Write : CACHE Write : USERDATA [FL] : Flashing finished! Done! Elapsed: 00:03:23 Reconnect Power/Cable! |
