10-05-2010, 19:01 | #1 (permalink) |
Banned Join Date: Sep 2008 Location: Dc-serviceteam Age: 38
Member: 857234 Status: Offline Sonork: Dc Thanks Meter: 197 | MT6223Psupport b infinity ? -HUIYUE23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.6223D_ C20F_KYX_QCIF_8M_A_ML_V07__ |
10-06-2010, 10:51 | #2 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Quote:
Waiting for your comments and detailed explanation due to right now our own Telepat is at short vacancy and we have to get an information directly from you. | |
10-06-2010, 14:13 | #3 (permalink) | |
Member: 857234 Status: Offline Sonork: Dc Thanks Meter: 197 | Quote:
after format it's same problem . i got support not find firmware for flash . | |
10-07-2010, 11:55 | #7 (permalink) |
Member: 857234 Status: Offline Sonork: Dc Thanks Meter: 197 | ==== [05/10/2010 18:32:30] ==== COM3 [VCP0] selected module v3.24 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:747B:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 208810FFFFFFFF:20881000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb otp offset: 007F0000 detecting chip #01 in region #00... flash: 208810FFFFFFFF:20881000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb otp offset: 007F0000 detecting chip #02 in region #00... flash: 208810FFFFFFFF:20881000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb otp offset: 007F0000 detecting chip #03 in region #00... flash: 208810FFFFFFFF:20881000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb otp offset: 007F0000 detecting chip #04 in region #00... flash: 208810FFFFFFFF:20881000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb otp offset: 007F0000 detecting chip #05 in region #00... flash: 208810FFFFFFFF:20881000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb otp offset: 007F0000 detecting chip #06 in region #00... flash: 208810FFFFFFFF:20881000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb otp offset: 007F0000 detecting chip #07 in region #00... flash: 208810FFFFFFFF:20881000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb otp offset: 007F0000 number of flash chip/regions detected: 08/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 208810FFFFFFFF:20881000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb otp offset: 007F0000 detecting chip #01 in region #00... flash: 208810FFFFFFFF:20881000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb otp offset: 007F0000 it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent ==================== New firmware found (v.3.24, database date: 01.10.2010): HUIYUE23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.6223D_ C20F_KYX_QCIF_8M_A_ML_V07.BIN ( wanted ) This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 04 sw version: HUIYUE23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.6223D_ C20F_KYX_QCIF_8M_A_ML_V07.BIN project-id: 6223D_C20F_KYX_QCIF_8M_A_ML_v07, 00000000 code offset: 00000000 ffs offset/size [01]: 00700000/00100000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00700000 standard ffs/eeprom offset confirmed: 00700000 detecting ffs/eeprom size... ffs/eeprom size: 00100000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00700000-007FFFFF firmware area: 00000000-006FFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: HUIYUE23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.6223D_ C20F_KYX_QCIF_8M_A_ML_V07__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\HUIYUE23C_08A_GEM INI_PCB01_GPRS_MT6223P_S00.6223D_C20F_KYX_QCIF_8M_ A_ML_V07__ffs_20101005-183401.B0E.bin flash: 208810FFFFFFFF:20881000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 208810FFFFFFFF:20881000000000 Finalization Done Finished, time used: 1 min 35 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
10-07-2010, 21:28 | #8 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,536 | hello! make full backup and try to flash phone with this similar firmware: flashfiles/ChineseMiracle/_MT6223/8m/HUIYUE23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.6223D_ C61_ALX_1_03_N02_ML_A_BT_DORADO_V01_8m_En_Fr_Farsi _Ar.B0M.bin |
10-08-2010, 10:37 | #9 (permalink) | |
I try with it : HUIYUE23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.6223_C 20D_HPG_ML_Z7_V01__Genxt_16m_En_Fr_Id_Hi_Farsi_Ar. B0M and this : HUIYUE23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.6223D_ C61_ALX_1_03_N02_ML_A_BT_DORADO_V01_8m_En_Fr_Farsi _Ar.B0M | |
Need schematic Infinity USB Phoenix | homer66 | Off Topic Zone | 0 | 05-25-2004 18:34 |
Animated GIF Loops only infinate on X100! | masterdwarf01 | SYSOL Platform | 2 | 03-04-2004 11:01 |
Infinity USB | brain2kx | Hardware Equipments for GSM | 0 | 12-04-2003 13:19 |
infinity usb... | voransoy | Sim Cloning and Scaning | 2 | 02-19-2003 09:43 |
URGENT : can i read imsi & ki by Infinity USB ? | sadom | Sim Cloning and Scaning | 4 | 02-10-2003 08:31 |
