09-22-2007, 10:52 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: JSR, BD
Member: 310155 Status: Offline Thanks Meter: 1,313 | C168 dead ! i have a motorola c168 restart phone. i flashed it with infinity. now it is dead. here is log................................. COM9 [VCP1] selected Device: Motorola C168 Checking data, wait... Action: flash write Write: Firmware Write: Flex Write: Language Pack Skip: FFS/File system Write: Images Write: Melody Skip: Eeprom Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 812500 Set Baud Done Check Flash... SW ver: HW ver: Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0089:886400010001 flash: Intel 28F640W18-T T 8Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Firmware Flash: 0089:886400010001 flash: Intel 28F640W18-T T 8Mb error: answer#00 try#1 to recover write error at 00000000 error: error checksum try#2 to recover write error at 00000000 error: error try#3 to recover write error at 00000000 error: answer#00 try#4 to recover write error at 00000000 error: answer#00 try#5 to recover write error at 00000000 error: answer#00 try#6 to recover write error at 00000000 error: answer#00 try#1 to recover write error at 00002000 error: answer#00 try#2 to recover write error at 00002000 error: answer#00 try#3 to recover write error at 00002000 error: answer#00 try#4 to recover write error at 00002000 error: answer#00 try#5 to recover write error at 00002000 error: answer#00 try#6 to recover write error at 00002000 error: answer#00 try#1 to recover write error at 00004000 error: answer#00 try#2 to recover write error at 00004000 error: answer#00 try#3 to recover write error at 00004000 error: answer#00 try#4 to recover write error at 00004000 error: answer#00 try#5 to recover write error at 00004000 error: answer#00 try#6 to recover write error at 00004000 error: answer#00 try#1 to recover write error at 00006000 error: answer#00 try#2 to recover write error at 00006000 error: answer#00 try#3 to recover write error at 00006000 error: answer#00 try#4 to recover write error at 00006000 error: answer#00 try#5 to recover write error at 00006000 error: answer#00 try#6 to recover write error at 00006000 error: answer#00 try#1 to recover write error at 00008000 error: answer#00 try#2 to recover write error at 00008000 error: answer#00 try#3 to recover write error at 00008000 error: answer#00 try#4 to recover write error at 00008000 error: answer#00 try#5 to recover write error at 00008000 error: answer#00 try#6 to recover write error at 00008000 error: answer#00 try#1 to recover write error at 0000A000 error: answer#00 try#2 to recover write error at 0000A000 error: answer#00 try#3 to recover write error at 0000A000 error: answer#00 try#4 to recover write error at 0000A000 error: answer#00 try#5 to recover write error at 0000A000 error: answer#00 try#6 to recover write error at 0000A000 error: answer#00 try#1 to recover write error at 0000C000 error: answer#00 try#2 to recover write error at 0000C000 error: answer#00 try#3 to recover write error at 0000C000 error: answer#00 try#4 to recover write error at 0000C000 error: answer#00 try#5 to recover write error at 0000C000 error: answer#00 try#6 to recover write error at 0000C000 error: answer#00 try#1 to recover write error at 0000E000 error: answer#00 try#2 to recover write error at 0000E000 error: answer#00 try#3 to recover write error at 0000E000 error: answer#00 try#4 to recover write error at 0000E000 error: answer#00 try#5 to recover write error at 0000E000 error: answer#00 try#6 to recover write error at 0000E000 Writing Fail Finished, time used: 399 sec Remove/Install battery now ! |
09-23-2007, 07:39 | #3 (permalink) |
Member: 310155 Status: Offline Thanks Meter: 1,313 | thanks infinity. my phone is now alive. the phone want with sim-card "Specific IMSI PUK:" here is some code............. COM9 selected Model: Motorola C168 Action: read unlock codes Phone must be POWERED-ON ! Connecting, wait... Phone connected. Working... imei: 3519550164723449 file saved: backup_unlock_log_3519550164723449_20070923-123158.69F.bin detecting codes... net [active]: 00800101 net sub [inactive]: 10010005 sp [active]: 63146314 corp [active]: 63146314 pck [active]: 46314631 fs [active]: 345005 phone code: 3123439 Finished this code not recive the phone.................... |
09-23-2007, 11:28 | #5 (permalink) |
Member: 310155 Status: Offline Thanks Meter: 1,313 | sir. i alrady did "repair unauthorized" COM9 selected Device: Motorola C168 Checking data, wait... Action: unlock (prepare) Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 812500 Set Baud Done Check Flash... SW ver: 1490-000 HW ver: TCT-9- Check Flash Done Check Parameters... file saved: backup_eeprom_calibration_20070923-162044.69E.bin file saved: backup_repair_20070923-162047.69F.bin error: already repaired Check Parameters Fail Finished, time used: 21 sec Remove/Install battery now ! can u please say that which flash file will be used for solved this problem ??? |
09-26-2007, 10:02 | #6 (permalink) | |
Freak Poster Join Date: Sep 2007 Location: bd
Member: 596177 Status: Offline Thanks Meter: 156 | Quote:
i have thia problem. i cant unlock my C168 phone. please help. | |
09-26-2007, 17:54 | #8 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! please check if this will work for you. http://forum.gsmhosting.com/vbb/show...7&postcount=25 |
help c168 dead!!!!!!!!!!!!! | GSM PAVIA | Infinity-Box | 13 | 06-13-2008 17:19 |
c168 dead | enterprises | Infinity-Box | 27 | 04-24-2007 03:02 |
motorola C168 dead help | therocky8 | Infinity-Box | 3 | 11-29-2006 10:35 |
C168 dead in change language | ARC | Infinity-Box | 9 | 11-23-2006 18:36 |
c168 dead for unlock | gabriel148 | Infinity-Box | 11 | 11-11-2006 18:29 |
