12-08-2007, 17:18 | #1 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Karachi Pakistan Age: 38
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | Mt6228 P3360 _________ When i Power ON the phone , it shows the percentage bar & when it reaches to 100% phone went OFF Phone is not connecting ON SAFE Format He is all the logs SAFE FORMAT ______________ COM1 [Serial0] selected Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6228:8A02:8A02]... chip: 0031:0000:0101 Connecting, wait... error: can't finalize test moide Operation failed ! Finished, time used: 30 sec Remove/Install battery now ! COMPLETE FORMAT __________________ COM1 [Serial0] selected Device: Autodetect 6228 NAND Checking data, wait... Action: NAND reset Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6228:8A02:8A02]... chip: 0031:0000:0101 boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.1 NAND id: ADF1801D page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00AD:00F10080001D [08400000] NOR chip is not installed Initialize Done Set baud... 115200 Set baud Done Identification... reading... detecting structure... converting data... done 0x00080000 bytes identification#1 protocol ver: 04 ver. sw1: BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_320_6680_INF _HY64_V2_2.BIN ver. sw2: R888_320_6680_Inf_Hy64_V2.2 ffs offset/size: 02000000/02000000 id-page Ok nfi area detection finished: Ok identification#1 structure: 2nd [enhanced] (or higher) generation security area#1 Ok security area backup saved: id.27EADFDB.[BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_320_6680_INF _HY64_V2_2.BIN_CBB3CFCA].rpl New firmware detected: BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_320_6680_INF _HY64_V2_2.BIN - make "Repair security area" operation - send "backup_system_log_..." file to support - make "Read full flash" operation - send flash backup file(s) to support - include in your e-mail full text from phone back label (phone name etc.) identification#1 detection finished Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... formatting... Write Done file saved: backup_system_log_27EADFDB_BXWY28_06B_PCB04_GPRS_M T6228_S02.R888_320_6680_INF_HY64_V2_2.BIN_CBB3CFCA _20071208-185559.B4X.bin Finished, time used: 77 sec Remove/Install battery now ! READ FULLFLASH _________________ COM4 [VCP0] selected Device: Autodetect 6228 NAND Checking data, wait... Action: read NAND flash Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6228:8A02:8A02]... chip: 0031:0000:0101 boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.1 NAND id: ADF1801D page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00AD:00F10080001D [08400000] NOR chip is not installed Initialize Done Set baud... 921600 Set baud Done Identification... reading... detecting structure... converting data... done 0x00080000 bytes identification#1 protocol ver: 04 ver. sw1: BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_320_6680_INF _HY64_V2_2.BIN ver. sw2: R888_320_6680_Inf_Hy64_V2.2 ffs offset/size: 02000000/02000000 id-page Ok nfi area detection finished: Ok identification#1 structure: 2nd [enhanced] (or higher) generation error: unexpected answer: error: unexpected answer: security area#1 damaged, recalculation required identification#1 detection finished reading... error: unexpected answer: warning: probably errors exist during flash read operation Finished, time used: 50 sec Remove/Install battery now ! I think most Hardwares of MT6228 is not supported ... |
12-08-2007, 19:34 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Please, send backup_system_log_27EADFDB_BXWY28_06B_PCB04_GPRS_M T6228_S02.R888_320_6680_INF_HY64_V2_2.BIN_CBB3CFCA _20071208-185559.B4X.bin to [email protected] Did you tried to use 115200 baud instead of 921600 ? |
help nedded for cect p3360 | aliakbar | Infinity-Box | 6 | 03-13-2008 20:33 |
not formate MT6228 | reaz.com | Infinity-Box | 6 | 10-30-2007 16:31 |
17 Sep 2007: "Chinese Miracle" v1.51 released: MT6228 CPU, NAND flash supported... | InfinitySupport | Infinity-Box | 32 | 09-26-2007 21:36 |
Mt6228 | solazo | Infinity-Box | 1 | 09-26-2007 17:46 |
@SUPPORTER@ plz sp MT6228 based chinese miracle | halongmobile | Infinity-Box | 1 | 06-20-2007 11:27 |
