08-27-2016, 12:11 | #1 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | MT6255 : Factory FW Read, Service and etc! Code: Operation : Check / Read Info [ v1.55 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 14 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6255 BB_CPU_HW : CA03 BB_CPU_SW : 0002 BB_CPU_SB : 8A00 BB_CPU_NM : [MediaTek] MT6255_S0000 BROM Protocol Version : 05 Setting... Setting done , result code 0x0000 BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : 0100 B100 8000 5500 DEV[1] : 0100 B100 8000 5500 Select EMI : 01B1805500000000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x85 SOC_VERIFY : 0xC1 BOOT_STYLE : NAND_FLASH_BOOT NAND Flash IC initialized FLASH_VEN : 0x0070 , [FILDEX] FMN1SD5SBS_50IA FLASH_DIE0 : 0001 00B1 0080 0055 FLASH_DIE1 : 0001 00B1 0080 0055 FLASH_LEN : 0x08000000 INT_RAM : 0x00007000 EXT_RAM : 0x02000000 Done! Elapsed: 00:00:15 Reconnect Power/Cable! Code: Operation : Format FileSystem [ v1.55 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 14 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6255 BB_CPU_HW : CA03 BB_CPU_SW : 0002 BB_CPU_SB : 8A00 BB_CPU_NM : [MediaTek] MT6255_S0000 BROM Protocol Version : 05 Setting... Setting done , result code 0x0000 BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : 0100 B100 8000 5500 DEV[1] : 0100 B100 8000 5500 Select EMI : 01B1805500000000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x85 SOC_VERIFY : 0xC1 BOOT_STYLE : NAND_FLASH_BOOT NAND Flash IC initialized FLASH_VEN : 0x0070 , [FILDEX] FMN1SD5SBS_50IA FLASH_DIE0 : 0001 00B1 0080 0055 FLASH_DIE1 : 0001 00B1 0080 0055 FLASH_LEN : 0x08000000 INT_RAM : 0x00007000 EXT_RAM : 0x02000000 Executing FFS FORMAT now... FAT_RANGE : 0x03A00000-0x07FFFFFF , LEN : 0x04600000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE NAND Status : 03A00000 / 04600000 / 00000230 / 00000001 Done! Elapsed: 00:00:17 Reconnect Power/Cable! Code: Operation : Read Flash [ v1.55 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 14 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6255 BB_CPU_HW : CA03 BB_CPU_SW : 0002 BB_CPU_SB : 8A00 BB_CPU_NM : [MediaTek] MT6255_S0000 BROM Protocol Version : 05 Setting... Setting done , result code 0x0000 BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : 0100 B100 8000 5500 DEV[1] : 0100 B100 8000 5500 Select EMI : 01B1805500000000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x85 SOC_VERIFY : 0xC1 BOOT_STYLE : NAND_FLASH_BOOT NAND Flash IC initialized FLASH_VEN : 0x0070 , [FILDEX] FMN1SD5SBS_50IA FLASH_DIE0 : 0001 00B1 0080 0055 FLASH_DIE1 : 0001 00B1 0080 0055 FLASH_LEN : 0x08000000 INT_RAM : 0x00007000 EXT_RAM : 0x02000000 Reading Flash Content now ... Read Ok, make firmware now ... Scatter Configuration info : MT6255 / NAND / DDR Saved to : MT6255_NAND_A20D_PCB01_gprs_MT6255_S00.MAUI_11BW1216SP_W13_02 Read Done! Done! Elapsed: 00:02:04 Reconnect Power/Cable! Read UserCode : Code: Operation : Read UserCode [ v1.55 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 14 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6255 BB_CPU_HW : CA03 BB_CPU_SW : 0002 BB_CPU_SB : 8A00 BB_CPU_NM : [MediaTek] MT6255_S0000 BROM Protocol Version : 05 Setting... Setting done , result code 0x0000 BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : 0100 B100 8000 5500 DEV[1] : 0100 B100 8000 5500 Select EMI : 01B1805500000000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x85 SOC_VERIFY : 0xC1 BOOT_STYLE : NAND_FLASH_BOOT NAND Flash IC initialized FLASH_VEN : 0x0070 , [FILDEX] FMN1SD5SBS_50IA FLASH_DIE0 : 0001 00B1 0080 0055 FLASH_DIE1 : 0001 00B1 0080 0055 FLASH_LEN : 0x08000000 INT_RAM : 0x00007000 EXT_RAM : 0x02000000 Active : No , Code : 0000 Done! Elapsed: 00:01:14 Reconnect Power/Cable! Code: Operation : Repair Security [ v1.55 ] 1. Phone must be powered ON and WITHOUT SIM! 2. Insert USB cable. Select "COM PORT" or "MODEM" mode! Wait for phone... Phone found! [ 31 ] Sync... Init Ok, waiting for phone ... Phone Initial Info : BB : MT6255, E03 SW : MAUI.11BW1216SP.W13.02 HW : A20_HW IMEI[1] : 350305260000001 IMEI[2] : 350305260000001 Update IMEI[1] to : 008097086896683 Done! Done! Elapsed: 00:00:37 Reconnect Power/Cable! |
The Following 10 Users Say Thank You to JayDi For This Useful Post: |
08-28-2016, 17:04 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Update with MT6255 support released : http://forum.gsmhosting.com/vbb/f296...-more-2127702/ |
