Old 12-05-2014, 23:57   #1 (permalink)
Member: 220595
Thanks Meter: 258
MT6571 Blu d140K
Need flash file for this phone
I tried to write one with spflashtool and could not succed, result phone is erased
BLU dash D140k
Card found: S/N 7557:0128
Chinese Miracle II  [MTK module] v 1.07
Operation : Check / Read Info [ v1.07 ]
Wait for phone...
Phone found! [ 160 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6571
BB_CPU_HW : CA00
BB_CPU_SW : 8D00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6571_S00
Processing BROM stage
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
NAND_ID : 002C00BC009000660054000000000000
eMMC_ID : 00000000000000000000000000000000
DA Stat : v4.2 on BBID : 0x8B
DA Sent. Configure setting now ...
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x007A , [Micron] NAND_MT29C4G48MAAHBAAKS
[NAND] : FLASH_DIE : 002C 00BC 0090 0066 0054 0000 0000
[NAND] : FLASH_LEN : 0x20000000
INT RAM    : 0x00020000
EXT RAM    : 0x10000000
BOOT TYPE  : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
NAND : Detecting structure now... Please, wait.
NAND : Structure detect done
Initial info read Ok!
Done!
Elapsed: 00:03:30
Reconnect Power/Cable!
Operation : Read Flash [ v1.07 ]
Wait for phone...
Sync...
Boot Info :
BB_CPU_ID : 6571
BB_CPU_HW : CA00
BB_CPU_SW : 8D00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Reading Flash Conent now ...
NAND settings not exists, will check now ...
Settings read Ok!
 - > Re-connect battery and start operation again!
Done!
Elapsed: 00:00:19
Wait for phone...
Phone found! [ 142 ]
Sync...
Boot Info :
BB_CPU_ID : 6571
BB_CPU_HW : CA00
BB_CPU_SW : 8D00
BB_CPU_SB : 0000
BLVersion : 0xFE
BromVersion : 0x05
BLVersion : 0xFE
Preloader Status : Not active (Erased)
Processing DA stage
NAND_ID : 009800BC009000660076001600080000
Configure emi settings
[NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1
[NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008
SOC VERIFY : C1
Boot Ok!
NAND : Structure detect failed! Send report to support!
Info read not done :( Erased phone or unsupported FlashIc?
Done!
Elapsed: 00:06:21
please help guys, have 3 pieces of this phone in same situation.
Old 12-06-2014, 08:32   #2 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,181
Hello!
Take alive one and make FlashRead , after send file to me. I will check it and try making repair.
Old 12-06-2014, 12:19   #3 (permalink)
.:MobileLife:.'s Avatar
Member: 188260
Sonork: 100.1590438
Thanks Meter: 419
Originally Posted by Dzirt View Post
Hello!
Dzirt, may you repair UBISLATE 7CZ MTK8312 CPU ID 6571 android 4.4.2 file tab is hang on logo tried with format "0" but same I searched that file everywhere but not found many other member have same problem with same tab if you repair we will be great.
BR.
Siddeque.
Old 12-06-2014, 13:07   #4 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,181
I can't repair SYSTEM images yet. And seek and solve problems without test samples - impossible mostly if talk about android.
The Following User Says Thank You to Dzirt For This Useful Post:
Old 12-06-2014, 17:46   #5 (permalink)
Member: 220595
Thanks Meter: 258
Hi
I dont have a working set
but I tried to read a blu d140t, almost same phone , same CPU 6571, slightly different Flash IC, just supported on new cm2mtk universal flash IC algorithm, and I could not read the flash.
It can identify well, and I formatted that set (which was stuck at boot logo) after format is working well...
I did Read info Again and then tried to read full flash from phpne and Infinity cant read the file, and give no error.
here log from reading attempt of blu d140t mt6571 micron flash IC
Start  at : [05/12/2014 / 17:25:46]
Wait for phone...
Sync...
Boot Info :
BB_CPU_ID : 6571
BB_CPU_HW : CA00
BB_CPU_SW : 8D00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Settings read Ok!
Done!
Elapsed: 00:00:19
Finish at : [05/12/2014 / 17:26:05]
SO, I believe It will not work for reading from blu d140k k1ngston flash IC
Old 12-06-2014, 19:04   #6 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,181
Did you try read log?
It ask read now flash.
CM2 uses new loaders, which are requires some thing to working, so, that is reason why some operation require 2 steps.
Old 12-06-2014, 20:06   #7 (permalink)
Member: 220595
Thanks Meter: 258
Please read my post once again and you will notice that YES, I used the READ INFO function again before attempting reading the flash file
Old 12-07-2014, 06:45   #8 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,181
Wait for phone...
Sync...
Boot Info :
BB_CPU_ID : 6571
BB_CPU_HW : CA00
BB_CPU_SW : 8D00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Settings read Ok!
Done!
Elapsed: 00:00:19
Old 12-08-2014, 20:56   #9 (permalink)
Member: 220595
Thanks Meter: 258
Yes, you are right, read operation has to be done twice for cm2mtk to really read the flash, looks like on first read it reads some necessary info from phone nand, etc, in sencond time it applies this configuration and goes straight to read nand,.
log here from seocond atempt
Wait for phone...
Phone found! [ 35 ]
Sync...
Boot Info :
BB_CPU_ID : 6571
BB_CPU_HW : CA00
BB_CPU_SW : 8D00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Read Ok , collect info
MTKxCPU   : MT6571
MTKxPRJ   : zechin71_e_lca
Saved to : E:\boxes\InfinityBox\CM2MTK\Flash\MT6571__zechin71_e_lca.ispff
Done!
Elapsed: 00:04:26
I think that message to reconnect the phone should be a Popup Window, instead of log item...
It would give more importance to it and will be more readable, since it is a mandatory operation to succed the flash reading.
Now, I know someone with a healthy blu d140K, will read the full flash and post it elsewhere
thanks
The Following User Says Thank You to yurais For This Useful Post:
Old 12-08-2014, 20:58   #10 (permalink)
Member: 220595
Thanks Meter: 258
and lastly, can this full flash read file be written on another phone using infinity? or it has to be uploaded to infinity guys for them to insert it into support area after doing some sanity stuff to the file ?
Old 12-08-2014, 21:51   #11 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,181
Yes. Will add a message.
Writing - at now trying finishing some things to enable it for NAND phones.
Old 12-10-2014, 22:54   #12 (permalink)
Member: 220595
Thanks Meter: 258
@Dzirt
Is it writing supported on this phone we have been talking about?
I tested reading full flash and tested Formatting, but am not sure if writing is possible, can you confirm please?
Old 12-11-2014, 09:24   #13 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,181
Yes, writing not supported yet, because nand phone is really piece of...
Working on them right now and soon will be.
Old 12-11-2014, 17:22   #14 (permalink)
Member: 220595
Thanks Meter: 258
Well, I have made backup of blu d140k (Kingston) and blu d140t (not remember) both NAND and mt6571, both 512MB.
Old 12-11-2014, 17:29   #15 (permalink)
Member: 220595
Thanks Meter: 258
I have couple dead blu d140K (kingston nand) waiting for you here, let me know if you need me to make any test on any beta software? just let me know, am available to spend some time on it. I just dont want to pay these two piece of crap
Page generated in 0.39033 seconds with 7 queries
