mt6571 error plz help me ... PHP Code: |
NAND phone : Read Info Do need operation after |
1 Idenity Info 2 Then Format |
Format : UserData Only (Factory Reset) Format UDA block ERASE_CMD not allowed! Something wrong with HW or DA? Operation Failed Elapsed: 00:01:16 Reconnect Power/Cable! |
MT6571 FORMAT FS... Failed ALWAYS.. Card found: S/N 17AC:0128 Chinese Miracle II [MTK module] v 1.08 Operation : Format FileSystem [ v1.08 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 009800BC009000660076001500010000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x8B DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x007F , [TOSHIBA] TYBC0A111557KC [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0015 0001 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Format : UserData Only (Factory Reset) Format UDA block ERASE_CMD not allowed! Something wrong with HW or DA? Operation Failed Elapsed: 00:01:16 Reconnect Power/Cable! |
Format : Cache and UserData (Full Factory Reset) Format CACHE block ERASE_CMD not allowed! Something wrong with HW or DA? Operation Failed Elapsed: 00:00:16 Reconnect Power/Cable! |
Read Again http://forum.gsmhosting.com/vbb/10775092-post2.html |
Please give firmware for this phone. |
What model...?? Show log of operation.... |
Logs are the same as in the first post. Model: SM-G900F, CPU: MT6571 ,Flash:MT29C4G96MAZAPCJA_5IT, MB: S877-01A .Condition- restarts on the splash screen Mediatek. With a firmware read and written with no errors Chinese Miracle II [MTK module] v 1.35 Operation : Check / Read Info [ v1.35 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 11 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 002C00BC009000550056000000000000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x8B DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0087 , [Micron] MT29C4G96MAZAPCJA_5IT [NAND] : FLASH_DIE : 002C 00BC 0090 0055 0056 0000 0000 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/00/NIM_Px-2 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Done! Elapsed: 00:00:15 Reconnect Power/Cable! Please give firmware for this phone. |
