Old 01-03-2015, 09:43   #1 (permalink)
Member: 2095587
Thanks Meter: 32
mt6571 error
plz help me ...
PHP Code:
Check Drivers
Try again
Boot Error
Elapsed00:00:39
Reconnect Power
/Cable!
1. Power Off Phone Remove battery Insert back
2. Insert USB cable
In some cases require hold BootKey
Wait
for phone...
Phone found! [ 22 ]
Sync...
Inital regs read done
Boot Info
BB_CPU_ID 6571
BB_CPU_HW
CA00
BB_CPU_SW
8D00
BB_CPU_SB
0000
BB_CPU_NM
: [MediaTekMT6571_S00
Processing BROM stage
BLVersion
0x01
SecCfgVal
0x00000000
BromVersion
0xFF
BLVersion
0x01
Preloader Status
Alive
Processing DA stage
DA Select done
sending
NAND_ID
002C00BC009000550056000000000000
eMMC_ID
00000000000000000000000000000000
DA Stat
v4.2 on BBID 0x8B
DA Sent
Configure setting now ...
NAND FlashIC initialized
[NAND] : FLASH_VEN 0x0079 , [MicronMT29C4G96MAZAPCJA_5IT
[NAND] : FLASH_DIE 002C 00BC 0090 0055 0056 0000 0000
[NAND] : FLASH_LEN 0x20000000
INT RAM
0x00020000
EXT RAM
0x10000000
BOOT TYPE
NAND_FLASH_BOOT
SOC VERIFY
C1
Boot Ok
Format UserData Only (Factory Reset)
Format UDA block
ERASE_CMD not allowed
Something wrong with HW or DA?
Operation Failed
Elapsed
00:00:20
Reconnect Power
/Cable
Old 01-03-2015, 09:51   #2 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,181
NAND phone :
Read Info
Do need operation after
Old 01-03-2015, 09:51   #3 (permalink)
pradeep_kus's Avatar
Member: 459784
Sonork: 100.1592448
Thanks Meter: 1,456
Originally Posted by hamim ctg View Post
plz help me ...
PHP Code:
Check Drivers
Try again
Boot Error
Elapsed00:00:39
Reconnect Power
/Cable!
2. Insert USB cable
Wait
for phone...
Phone found! [ 22 ]
Sync...
Boot Info
BB_CPU_ID 6571
BB_CPU_HW
CA00
BB_CPU_SW
8D00
BB_CPU_SB
0000
BB_CPU_NM
BLVersion
0x01
SecCfgVal
0x00000000
BromVersion
0xFF
BLVersion
0x01
Preloader Status
Alive
Processing DA stage
DA Select done
sending
NAND_ID
eMMC_ID
DA Stat
v4.2 on BBID 0x8B
DA Sent
INT RAM
0x00020000
EXT RAM
0x10000000
BOOT TYPE
NAND_FLASH_BOOT
SOC VERIFY
C1
Boot Ok
Format UDA block
Operation Failed
Elapsed
00:00:20
Reconnect Power
/Cable
Idenity Info Done?? Try Agian
1 Idenity Info
2 Then Format
Old 01-03-2015, 10:15   #4 (permalink)
Member: 2095587
Thanks Meter: 32
Format : UserData Only (Factory Reset)
Format UDA block
ERASE_CMD not allowed! Something wrong with HW or DA?
Operation Failed
Elapsed: 00:01:16
Reconnect Power/Cable!
Old 01-03-2015, 10:17   #5 (permalink)
Member: 2095587
Thanks Meter: 32
MT6571 FORMAT FS... Failed ALWAYS..
Card found: S/N 17AC:0128
Chinese Miracle II [MTK module] v 1.08
Operation : Format FileSystem [ v1.08 ]
Wait for phone...
Phone found! [ 17 ]
Sync...
Boot Info :
BB_CPU_ID : 6571
BB_CPU_HW : CA00
BB_CPU_SW : 8D00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6571_S00
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
NAND_ID : 009800BC009000660076001500010000
eMMC_ID : 00000000000000000000000000000000
DA Stat : v4.2 on BBID : 0x8B
DA Sent. Configure setting now ...
[NAND] : FLASH_VEN : 0x007F , [TOSHIBA] TYBC0A111557KC
[NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0015 0001
[NAND] : FLASH_LEN : 0x20000000
INT RAM : 0x00020000
EXT RAM : 0x10000000
BOOT TYPE : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Format UDA block
Operation Failed
Elapsed: 00:01:16
Old 01-03-2015, 10:19   #6 (permalink)
Member: 2095587
Thanks Meter: 32
Format : Cache and UserData (Full Factory Reset)
Format CACHE block
Operation Failed
Elapsed: 00:00:16
Old 01-03-2015, 11:13   #7 (permalink)
Member: 459784
Sonork: 100.1592448
Thanks Meter: 1,456
Format UDA block
Operation Failed
Elapsed: 00:01:16
Wait for phone...
Phone found! [ 17 ]
Sync...
Boot Info :
BB_CPU_ID : 6571
BB_CPU_HW : CA00
BB_CPU_SW : 8D00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Format UDA block
Operation Failed
Elapsed: 00:01:16
Format CACHE block
Operation Failed
Elapsed: 00:00:16
Read Again
mt6571 error
Old 11-06-2015, 01:30   #8 (permalink)
Member: 1036725
Thanks Meter: 31
Please give firmware for this phone.
Old 11-06-2015, 05:04   #9 (permalink)
maomatrix's Avatar
Member: 901711
Sonork: 100.1606138
Thanks Meter: 423
What phone???
What model...??
Show log of operation....
Old 11-06-2015, 10:27   #10 (permalink)
Member: 1036725
Thanks Meter: 31
Logs are the same as in the first post. Model: SM-G900F, CPU: MT6571 ,Flash:MT29C4G96MAZAPCJA_5IT, MB: S877-01A .Condition- restarts on the splash screen Mediatek. With a firmware read and written with no errors
Chinese Miracle II [MTK module] v 1.35
Operation : Check / Read Info [ v1.35 ]
Wait for phone...
Phone found! [ 11 ]
Sync...
Boot Info :
BB_CPU_ID : 6571
BB_CPU_HW : CA00
BB_CPU_SW : 8D00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
DA Ver : MTK_AllInOne_DA_v7.1533.03
NAND_ID : 002C00BC009000550056000000000000
DA started successuflly
[NAND] : FLASH_VEN : 0x0087 , [Micron] MT29C4G96MAZAPCJA_5IT
[NAND] : FLASH_DIE : 002C 00BC 0090 0055 0056 0000 0000
[NAND] : FLASH_EXT : 0800/0040/00/NIM_Px-2
SOC VERIFY : C1
Boot Ok!
Done!
Elapsed: 00:00:15
Page generated in 0.38182 seconds with 7 queries
