Old 10-20-2015, 11:06   #1 (permalink)
BISMILLAH MOBILES's Avatar
Member: 610502
Sonork: 100.1618428
Thanks Meter: 161
Voice V10 NAND Unsupported Team Please Check This...
Hi to all,
The Mobile is ON and Hang on Voice Logo I try to read Information but failed.
I have tried almost every available Option But the answer is same.
"Where is NIM_Px-2 or NIM_Px-1 mean which one need try.
If NIM_Px-2 - then need try P1-2 , P2-2 , P3-2
If NIM_Px-1 - then need try P1-1 , P2-1 , P3-1"
If i will post whole Logs much of forum Space will be wasted,
Only One Log that will represent all Options.
Operational Log:
Operation : Check / Read Info [ v1.34 ]
Wait for phone...
Phone found! [ 9 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6572_S00
Processing BROM stage
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
DA Ver : MTK_AllInOne_DA_v7.1533.03
NAND_ID : 00AD00BC00900055005600AD00BC0000
eMMC_ID : 00000000000000000000000000000000
DA Stat : v4.2 on BBID : 0x88
DA Sent. Configure setting now ...
DA started successuflly
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x009A , [Hynix] H9TA4GH2GDMCPR
[NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0056 00AD 00BC
[NAND] : FLASH_LEN : 0x20000000
[NAND] : FLASH_EXT : 0800/0040/01/NIM_Px-2
INT RAM : 0x00020000
EXT RAM : 0x10000000
BOOT TYPE : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Info read not done Erased phone or unsupported FlashIc?
You can change settings : Settings -> Other -> NAND init Mode
Done!
Elapsed: 00:00:12
Reconnect Power/Cable!
TEAM PLEASE GUIDE ME...
B/R
Sheraz...
Old 10-20-2015, 11:18   #2 (permalink)
kabul's Avatar
Member: 433097
Sonork: 100.1661890
Thanks Meter: 8,074
check it bro test reports Voice V10
Voice V10 NAND Factory Firmware & NV read By CM 2
http://forum.gsmhosting.com/vbb/11345411-post16.html
Write with SPTool Hang on logo phone success Done
http://forum.gsmhosting.com/vbb/11345429-post17.html
work for CM 2 Voice V10 NAND invalid imei repair Successfully Don
http://forum.gsmhosting.com/vbb/11345777-post22.html
The Following 4 Users Say Thank You to kabul For This Useful Post:
Old 10-20-2015, 12:34   #3 (permalink)
Member: 610502
Sonork: 100.1618428
Thanks Meter: 161
My Problem Solved Thanks To
special thanks for your help Mr.Kabul
IMEI WRITE DONE WITH CM2K
Old 10-20-2015, 13:21   #4 (permalink)
.::MAHABUB::.'s Avatar
Member: 939797
Sonork: 100.1601089
Thanks Meter: 359
how to solve your problem ?please tell me details .
Old 10-20-2015, 13:55   #5 (permalink)
Member: 610502
Sonork: 100.1618428
Thanks Meter: 161
Respected Bro...MAHABUB...
Respected Brother,
First of all Recharge Your Mobile Battery Near About 70% then once go for Read Info if info Successful Well and Good If Not Do not be Panic,
But Keep in Mind Mobile should have NAND6572 CPU.
Download this flash file
Voice_V10__MT6572__NAND__hct72_wet_lca By Kabul
You can contact Mr.Kabul for flash file and its password
His Sonork ID is 100.1661890
Now open SPFT Tool Load the Scattered File and Use the Option Format All+Download And wait until finish.
You are Done.
Repair IMEI With CM2K After Flash You are now Fully Done...
Any thing Else Bro?
B/R
Sherazz...
Old 10-20-2015, 14:01   #6 (permalink)
Member: 939797
Sonork: 100.1601089
Thanks Meter: 359
you success read flash this phone ?
Old 10-20-2015, 14:04   #7 (permalink)
Member: 610502
Sonork: 100.1618428
Thanks Meter: 161
Bro...MAHABUB
My Mobile is working fine but unfortunately i do not read its flash file cause its Battery Is too low to read the flash file..
I will report you about read when battery will be charged...
B/R
Sheraz...
Old 10-20-2015, 14:12   #8 (permalink)
Member: 939797
Sonork: 100.1601089
Thanks Meter: 359
oky thanks for information.
Old 10-20-2015, 14:41   #9 (permalink)
Member: 610502
Sonork: 100.1618428
Thanks Meter: 161
Yes I am Succeed in Read Flash File After Recharge The Battery.
Here are Logs Of Read Flash File.
Wait for phone...
Phone found! [ 9 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Done!
Elapsed: 00:00:17
Operation : Read Flash [ v1.34 ]
Wait for phone...
Phone found! [ 9 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Reading Flash Conent now ...
[Read Ok] : preloader_hct72_wet_lca.bin
[Read Ok] : lk.bin
[Read Ok] : boot.img
[Read Ok] : recovery.img
[Read Ok] : secro.img
[Read Ok] : logo.bin
[Read Ok] : system.img
[Read Ok] : cache_empty.img
[Read Ok] : usrdata_empty.img
[ScatCFG] : MT6572 / V1.1.1 / hct72_wet_lca / NAND
FW Size : 378 MiB
Scatter saved to : C:\Users\Mobile Shop\Desktop\MT6572__NAND__hct72_wet_lca
Done!
Elapsed: 00:03:34
The Following User Says Thank You to BISMILLAH MOBILES For This Useful Post:
Old 10-20-2015, 15:21   #10 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
From DEAD firmware phone - sure it will not read.
The Following 2 Users Say Thank You to JayDi For This Useful Post:
Old 10-21-2015, 02:37   #11 (permalink)
Member: 1166901
Sonork: Ginerz
Thanks Meter: 28
yes many 6572 nand chips dead phone hard to revive even if u have good
bkup.
how to solve this using cm2?
i have here 3units in hand all mt6572 nand
Old 10-21-2015, 05:02   #12 (permalink)
Member: 610502
Sonork: 100.1618428
Thanks Meter: 161
Respected Bro....
bkup.
Please Read the Whole Thread Carefully you will sure Revive your 3 Units..
If you do not have their Good And Working Backup just Request at Forum with Logs and you will get your desired Flash files from any Friend who use Infinity CM2K.
Hope you got my Point..
B/R
Sheraz...
Old 10-21-2015, 05:07   #13 (permalink)
Member: 610502
Sonork: 100.1618428
Thanks Meter: 161
Respected Jaydi Thanks..
BUT One question is still there,
As you know every Person make backup before any operation for Emergency Case either it is MTK or SPD.
It is strongly recommended by every team that make Backup for emergency before any operation.
Is there any chance of mismatch firmware or Boot loader in NAND Chip like MTK rest Chip?
Waiting for reply..
Sheraz...
Old 10-21-2015, 08:21   #14 (permalink)
JayDi's Avatar
Member: 462970
SW asking make backup only in one case - Smart AV now. Because we still improving it.
In other cases it useless. Just because we are sure in our work.
Page generated in 0.28798 seconds with 8 queries
