Old 10-21-2015, 02:20   #1 (permalink)
Member: 1166901
Sonork: Ginerz
Thanks Meter: 28
mt6571 nand chip w/o data lose how to?
Any guide for this kind of chip mt6571 nand
pin code problem and need to open w/o data lose
this is very important to my customer is matter of life and death to her
i want to know how to perform this w/o data lose?
cause today i will activate my long time sleeping box if u can really do this ..
tnx infinty team for ur time...
Old 10-21-2015, 03:57   #2 (permalink)
Member: 1166901
Sonork: Ginerz
Thanks Meter: 28
Box/Dongle type selected: inf
Box/Dongle found: inf
---------- Process started: 10/21/2015 12:53:19 PM ----------
DongleManager [Infinity-Box] v1.59 [10/21/2015 12:53:19 PM]
PC HWID: DB0202B79FA4042809F62B02CCA958EF
Card-Reader: Gemalto e-gate Smart Card 0
HWID: 0001D71600001942
Type: inf S/N: 96XXXXX Version: 0116.02
Connecting to server
Server connection successfully established
Checking DongleManager version...
Your DongleManager is up-to-date
Checking Dongle Identification...
Authenticating on server...
Authentication successfull
Servicing card - Stage 1...
Stage 1 completed
Servicing card - Stage 2...
Stage 2 completed. Card serviced ok
Securing session...
Session secured ok
Upgrading dongle...
DO NOT disconnect Box/Dongle !
WAIT 3-4 minutes !
Applet upgrade ok
Identification Ok. Finalizing...
Finalizing ok
Process completed
---------- Process finished: 10/21/2015 12:54:41 PM ----------
DongleManager [Infinity-Box] v1.59 [10/21/2015 12:54:44 PM]
HWID: 0001D716
Box/Dongle Serial No (S/N): 96XXXXXXX
Firmware version: 0129.02
Active modules:
- 00: inf v.0129
Online Service Account: Infinity-Box - Online Service
- Username:
- Passw
WELCOME HOME!!!
dongle updated
tnx infinity team
Old 10-21-2015, 05:20   #3 (permalink)
BISMILLAH MOBILES's Avatar
Member: 610502
Sonork: 100.1618428
Thanks Meter: 160
Respected Bro Ginerz...
Yes you can Reset user Locks without Data Loos but,
First of all Use Latest version Of Infinity CM2K Version 1.34
Then
Make Backup or Read full Backup along with NVRM for an emergency case
Then
Go for User Locks Reset according to the Picture.
Kindly Post Results Here...
BEST OF LUCK...
B/R
Sheraz...
The Following User Says Thank You to BISMILLAH MOBILES For This Useful Post:
Old 10-21-2015, 06:13   #4 (permalink)
Member: 1166901
Sonork: Ginerz
Thanks Meter: 28
Wait for phone...
Phone found! [ 17 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6571
BB_CPU_HW : CA00
BB_CPU_SW : 8D00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6571_S00
Processing BROM stage
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
DA Ver : MTK_AllInOne_DA_v7.1533.03
NAND_ID : 00AD00BC00900055005600AD00BC0000
eMMC_ID : 00000000000000000000000000000000
DA Stat : v4.2 on BBID : 0x8B
DA Sent. Configure setting now ...
DA started successuflly
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x009A , [Hynix] H9TA4GH2GDMCPR
[NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0056 00AD 00BC
[NAND] : FLASH_LEN : 0x20000000
[NAND] : FLASH_EXT : 0800/0040/01/NIM_Px-2
INT RAM : 0x00020000
EXT RAM : 0x10000000
BOOT TYPE : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Info read not done Erased phone or unsupported FlashIc?
You can change settings : Settings -> Other -> NAND init Mode
Done!
Elapsed: 00:00:23
Reconnect Power/Cable!
not suported why mt6571 chip?
Old 10-21-2015, 06:19   #5 (permalink)
Member: 610502
Sonork: 100.1618428
Thanks Meter: 160
Wait for phone...
Phone found! [ 17 ]
Sync...
Boot Info :
BB_CPU_ID : 6571
BB_CPU_HW : CA00
BB_CPU_SW : 8D00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Done!
Elapsed: 00:00:23
First of all try to check your Battery it should 60 to 70% charge
Second is your mobile Completely in working Condition?
Third try to adjust settings like
I had change NAND init to other way.
Now there is 6 setting level ( Instead of 3 old )
But, in log you will see now hint - which one need to select, it looks like :
DA Stat : v4.2 on BBID : 0x88
SOC VERIFY : C1
Boot Ok!
Where is NIM_Px-2 or NIM_Px-1 mean which one need try.
If NIM_Px-2 - then need try P1-2 , P2-2 , P3-2
If NIM_Px-1 - then need try P1-1 , P2-1 , P3-1
Need check correct one! And when "Read Info" made without any errors - you can service phone.
It takes near 50 second to try all, but it cover all phones. Sure, autodetect still exists and improved.
So, when read info is done - you can do any operations, which supported : Format FS, Reset Privacy Lock , Read PatternLock, NVRAM operations.
And now post results..
B.O.L
Sheraz..
Old 10-21-2015, 06:40   #6 (permalink)
Member: 1166901
Sonork: Ginerz
Thanks Meter: 28
yes the phone is in good condition
ok i try to dl first all update cause i got only 4 init to chose in cpu p;latform
Old 10-21-2015, 06:48   #7 (permalink)
Member: 610502
Sonork: 100.1618428
Thanks Meter: 160
Select only second SP Auto 6571....6595.
Bro first try auto if not success then try one by one from setting
Setting NAND init Mode.
hope this time you will get success.
B.O.L
Sheraz..
Old 10-21-2015, 07:43   #8 (permalink)
Member: 1166901
Sonork: Ginerz
Thanks Meter: 28
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
NAND not supported yet for selected operation!
Done!
Elapsed: 00:00:08
sucess read info but format user code faild
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Done!
Elapsed: 00:00:08
only emmc not nand suported for this kind of chip
i did everything sad to say not suported for this king of chip
Old 10-21-2015, 07:56   #9 (permalink)
Member: 1166901
Sonork: Ginerz
Thanks Meter: 28
mt6571 pin lock problem sucess read info
then reset user lock but faild
Old 10-21-2015, 07:58   #10 (permalink)
Member: 610502
Sonork: 100.1618428
Thanks Meter: 160
Respected Brother,
Just go for ask the Team Product Manager or Supporter for check this Error if it is at your End if not just ask the team for Support This C.P.U...
Hope Team will batter Help now in this situation..
B.O.L
Sheraz..
Old 10-21-2015, 08:01   #11 (permalink)
Member: 610502
Sonork: 100.1618428
Thanks Meter: 160
Respected Brother...
Try these 3 options with User data safe Tick but make backup first hope CM2K will show Miracle..
B/R
Sheraz...
Old 10-21-2015, 08:03   #12 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,040
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Done!
Elapsed: 00:00:08
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Done!
Elapsed: 00:00:08
Hello,
Nand not supported for user Data safe reset operation for now.
Br.
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post:
Old 10-21-2015, 08:04   #13 (permalink)
Member: 610502
Sonork: 100.1618428
Thanks Meter: 160
have you noticed that in my first reply with picture they show that Reset Google Account, Pattern Lock,Pin Code, Password Code etc
if it is not working for NAND then you should ask the team for support..
B/R
Sheraz...
Old 10-21-2015, 08:26   #14 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 16,233
I add some way for nand. But update with this feature come only on next week.
The Following 3 Users Say Thank You to JayDi For This Useful Post:
Old 10-21-2015, 08:37   #15 (permalink)
Member: 1166901
Sonork: Ginerz
Thanks Meter: 28
i guest i hav no lock for my miracle box
hope next time i got lucky
close this tread pls... return to owner
Page generated in 0.47208 seconds with 7 queries
