10-19-2014, 19:23 | #1 (permalink) | |||
No Life Poster Join Date: Nov 2008 Location: InFiNiTy CM2 For EvER!!
Member: 901711 Status: Offline Sonork: 100.1606138 Thanks Meter: 427 | Mt6572 avvio 768 & avvio 775 READ INFO Quote:
READ FLASH (DROID 4.4.2) Quote:
AVVIO 775 READ FLASH (DROID 4.2.2) Quote:
>>Mao<< | |||
The Following User Says Thank You to maomatrix For This Useful Post: |
10-21-2014, 05:46 | #5 (permalink) |
Member: 901711 Status: Offline Sonork: 100.1606138 Thanks Meter: 427 | |
02-13-2015, 04:35 | #6 (permalink) |
Freak Poster Join Date: Dec 2011 Location: In The New World With it/Colom Age: 44
Member: 1709174 Status: Offline Sonork: gokuu2011 Thanks Meter: 431 | This is other flash id....please check. Code: Wait for phone... Phone found! [ 107 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage Will use Secure DA for boot target DA Select done , sending DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164040501A182B081A1 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Initial info read Ok! Done! Elapsed: 00:00:16 Reconnect Power/Cable! |
02-15-2015, 01:16 | #8 (permalink) | ||
Member: 1709174 Status: Offline Sonork: gokuu2011 Thanks Meter: 431 | I need this flash file for this type cpu. cpu Maomatrix Quote:
cpu is my. Quote:
02-16-2015, 01:47 | #10 (permalink) |
Member: 901711 Status: Offline Sonork: 100.1606138 Thanks Meter: 427 | @zzkey, are you talkin about of AVVIO 768??? If yes, i check tomorrow if i have this version... I have in my hand this model that i buy this week |
02-16-2015, 22:39 | #11 (permalink) |
Member: 901711 Status: Offline Sonork: 100.1606138 Thanks Meter: 427 | @ZZkeyhelp... i have same flash emmc, in this new block of phones.. Code: Operation : Check / Read Info [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A483447316404050CA2B24BA1EB DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A483447316404050CA2B24BA1EB [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Initial info read Ok! Brand : Avvio 768 ProdName : Avvio 768 ProdModel : Avvio 768 Device : Avvio 768 AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP7.V1 Done! Elapsed: 00:00:11 |
