11-09-2015, 10:58 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | Mtk 6260 flashing error with cm2 1.36 but done with 1.34:- Code: Chinese Miracle II [MTK module] v 1.36 Load File File_Info : R035_MMX_PCB01_gprs_MT6260_S00.R016_R035_MMX_X353_V011.bin FileVersion : R016_R035_MMX_X353_V011 Load File Ok Start at : [11/9/2015 / 3:15:52 PM] Operation : Flash [ v1.36 ] ======= Flash Files set for flashing : [ MCU ] : R035_MMX_PCB01_GPRS_MT6260_S00.R016_R035_MMX_X353_V011.BIN 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 28 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 1418395A2728E6FA8864CF34E149BFAB BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : 2C00 CB00 1800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EE , [Numonyx] N25W128 [0] : FLASH_DIE : 002C 00CB 0018 0000 [0] : FLASH_LEN : 0x01000000 INT_RAM : 0x0000D000 EXT_RAM : 0x00800000 SDS_INFO : Not exists File_Info : R035_MMX_PCB01_gprs_MT6260_S00.R016_R035_MMX_X353_V011.bin FileVersion : R016_R035_MMX_X353_V011 Flash now Erase region , wait ... [ERROR] : Write data , wait ... [ERROR] : DONE Flash Error! Check Cable, Battery , try again Operation Failed Elapsed: 00:01:10 Reconnect Power/Cable! FLASHING LOGS CM2 1.34 Code: Chinese Miracle II [MTK module] v 1.34 Load File File_Info : R035_MMX_PCB01_gprs_MT6260_S00.R016_R035_MMX_X353_V011.bin FileVersion : R016_R035_MMX_X353_V011 Load File Ok Start at : [11/9/2015 / 3:19:17 PM] Operation : Flash [ v1.34 ] ======= Flash Files set for flashing : [ MCU ] : R035_MMX_PCB01_GPRS_MT6260_S00.R016_R035_MMX_X353_V011.BIN 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 28 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 1418395A2728E6FA8864CF34E149BFAB BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : 2C00 CB00 1800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : DONE NOR Flash IC initialized [0] : FLASH_VEN : 0x00EE , [Numonyx] N25W128 [0] : FLASH_DIE : 002C 00CB 0018 0000 [0] : FLASH_LEN : 0x01000000 INT_RAM : 0x0000D000 EXT_RAM : 0x00800000 [ERROR] : DA_BLANK_FLASH SDS_INFO : Not exists File_Info : R035_MMX_PCB01_gprs_MT6260_S00.R016_R035_MMX_X353_V011.bin FileVersion : R016_R035_MMX_X353_V011 Flash now Erase region , wait ... Write data , wait ... Write : R035_MMX_PCB01_GPRS_MT6260_S00.R016_R035_MMX_X353_V011.BIN Done! Elapsed: 00:01:23 Reconnect Power/Cable! PHONE RECOVERED WITH CM2 1.34 HOPE ALL THE BUGS WILL BE REMOVED IN FUTURE UPDATES. WBR sahil2000ind |
11-09-2015, 11:47 | #2 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Hello, Post phone model/Condition ? Try again with Fully battery( with V 1.36) Because MTK 6260 Working good (QMobile E50) Read Code: Operation : Check / Read Info [ v1.36 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 59 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : C0A865957FF468C48DE42A45ED5FD74D BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C200 2500 3600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E [0] : FLASH_DIE : 00C2 0025 0036 0000 [0] : FLASH_LEN : 0x00400000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 Done! Elapsed: 00:00:15 Reconnect Power/Cable! Operation : Read Flash [ v1.36 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 59 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : C0A865957FF468C48DE42A45ED5FD74D BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C200 2500 3600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E [0] : FLASH_DIE : 00C2 0025 0036 0000 [0] : FLASH_LEN : 0x00400000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 Reading Flash Conent now ... Read Flash now Read Ok , 4194304 bytes read Check and collect compile info File_Info : BESTONE60D_11B_PCB01_gsm_MT6260_S00.A8_D_YH_QMB_L2412_EUAP_V0_1_0.bin FileVersion : A8_D_YH_QMB_L2412_EUAP_V0.1.0 Saved to : C:\InfinityBox\CM2MTK\Read_out\BESTONE60D_11B_PCB01_gsm_MT6260_S00.A8_D_YH_QMB_L2412_EUAP_V0_1_0.bin Done! Elapsed: 00:00:18 Reconnect Power/Cable! Code: Load File File_Info : BESTONE60D_11B_PCB01_gsm_MT6260_S00.A8_D_YH_QMB_L2412_EUAP_V0_1_0.bin FileVersion : A8_D_YH_QMB_L2412_EUAP_V0.1.0 Load File Ok Operation : Flash [ v1.36 ] ======= Flash Files set for flashing : [ MCU ] : BESTONE60D_11B_PCB01_gsm_MT6260_S00.A8_D_YH_QMB_L2412_EUAP_V0_1_0.bin 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 59 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : C0A865957FF468C48DE42A45ED5FD74D BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C200 2500 3600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E [0] : FLASH_DIE : 00C2 0025 0036 0000 [0] : FLASH_LEN : 0x00400000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 File_Info : BESTONE60D_11B_PCB01_gsm_MT6260_S00.A8_D_YH_QMB_L2412_EUAP_V0_1_0.bin FileVersion : A8_D_YH_QMB_L2412_EUAP_V0.1.0 Flash now Erase region , wait ... Write data , wait ... Write : BESTONE60D_11B_PCB01_gsm_MT6260_S00.A8_D_YH_QMB_L2412_EUAP_V0_1_0.bin Done! Elapsed: 00:00:50 Reconnect Power/Cable! |
11-09-2015, 13:50 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | It because on some reason phone first erase attempt failed, but it finish it during process. On second try all done. Not matter version, matter sequence. |
