10-04-2016, 22:36 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: Morocco-Khenifra
Member: 198621 Status: Offline Sonork: 100.1591649 Thanks Meter: 1,083 | MT6572 Erased/damaged phone? I'm trying to flash it but i get errors reading firmware backup 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 138 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : 009800BC009000660076001500010000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0097 , NAND_UNKNOWN [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0015 0001 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/00/NIM_Px-1 DEV RID : 0x09C0E74CEF53D7C1DAEE1A190FBB199B INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Info read not done Erased/damaged phone? You can change settings : Settings -> Other -> NAND init Mode Done! Elapsed: 00:00:08 Reconnect Power/Cable! |
10-04-2016, 23:06 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Read log for more info. For read FW - tick "NAND Extra" and make FW read. |
10-06-2016, 08:59 | #5 (permalink) |
Freak Poster Join Date: Mar 2014 Location: sargodha,Pakistan
Member: 2141372 Status: Offline Thanks Meter: 14 | sir here u mean use sp flash tool i think but if u use complete word it will be better for us to understand .sir we are not good nd not expert like You great sir |
10-06-2016, 19:49 | #9 (permalink) |
Member: 198621 Status: Offline Sonork: 100.1591649 Thanks Meter: 1,083 | do you mean by identify log,the log readed by CM2 ? it says damaged or erased phone It also gives error when I try to flash it so how to restore the backup i readed if something goes wrong and how to read phone partitions addresses thank you again |
10-06-2016, 22:16 | #10 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | 1. You can flash NAND phones FW by SP Flash Tool. 2. I have no idea what mean under "partition adress" , but SW clearly make advise what need to do for make it able pass identify sucessfully. |
10-06-2016, 23:39 | #11 (permalink) |
Member: 198621 Status: Offline Sonork: 100.1591649 Thanks Meter: 1,083 | i mean when i open scatter file i see partitions adresses:uboot,recovery,system... the question is what if the phone is dead after flash with spft ? and CM2 gives errors when trying to flash the phone,if dead how to write back the backup ? |
10-07-2016, 13:46 | #12 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Backup DUMP is same as BACKUP FW - if after SPFT flashing it dead - try erase whole flash and reflash again. If not - bad FW ( damaged already in phone or wrong model ) or HW. |
05-22-2017, 15:42 | #13 (permalink) |
Junior Member Join Date: Jun 2016
Member: 2581869 Status: Offline Thanks Meter: 5 | after flash my mobile dead pls any salution q mobile x800 Wait for phone... Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 6592 BB_CPU_NME : [MediaTek] MT6592_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8A NAND Flash : NOT INSTALLED eMMC Flash : 90014A4838473264040501A10DA981B7 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d2G8 [eMMC] : FLASH_CID : 90014A4838473264040501A10DA981B7 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xA3671DA5A2FDDC7C6EB255C583CA24CB INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Info read not done Erased/damaged phone? |
05-22-2017, 19:30 | #14 (permalink) |
Member: 198621 Status: Offline Sonork: 100.1591649 Thanks Meter: 1,083 | flash it using this firmware https://mega.nz/#!aIFlDCjI!vhR-YT8nO...29jzZ3EIzfTays next time check skip preloader , it kills phones if you get errors use spflashtool http://www.mediafire.com/download/77...v5.1408.00.rar |
The Following User Says Thank You to jawad8305 For This Useful Post: |
11-20-2018, 16:06 | #15 (permalink) |
Junior Member Join Date: Dec 2017 Location: Bangladesh
Member: 2788256 Status: Offline Sonork: 100.650601 Thanks Meter: 2 | ait for phone... Phone found! [ 9 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A48344731640486140010809253 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A48344731640486140010809253 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0xD08813318FF8BF1A4AC529354EB0BF74 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Info read not done Erased/damaged phone? Done! Elapsed: 00:00:07 Reconnect Power/Cable! Have any idea plz help me |
